I have a maytag model
I have a maytag washer model A511 ser# 117859 nc, I have no idea how old it is. It will not pump the wash water out, it will add more water in the rinse cycle and it spins in the spin cycle. some water must go out as it does not run over. Also, when the washing cycle is over the timer does not shut off it simply rolls into the next cycle and keeps on going. Do I fix it or buy a new one? Thank You
    Genius:
  • 1,073 Answers
The machine is several years old and may have multiple problems one could be the timer since it is not cutting off, and either a problem with the water pump or something blocking it
probally time for a new washer
Posted on May 05, 2008
Maytag Neptune "nd" code
It is a drain pump issue, it is either a blocked or faulty pump or a fault in the electronic controller.
Mar 12, 2012 | Maytag Neptune MAH6500A Front Load Washer
Maytag washer model # MAVT236AWW Ser # 11354800GV This thing will not wash or drain or spin. It will fill up with water. I have smelled a burning smell and smoke filled the back room. To me it has...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 20, 2011 | Maytag Washing Machines
I have a Maytag Dishwasher, Model # WU482, ser # 01625706XT. The Water is not being pumped out , I checked Belt, and it is oK.
water pump out drain hose to sink kinked /stopped up if new disposol was installled and the installer did not take the dis/washer plug out it can not pump water to the drain
Mar 18, 2011 | Maytag Dishwashers
Maytag A511 has worked faithfully for 26 years.
Either the engine or the drum bearing are worn out and the rotor/drum is touching the stator/tub. It's normal wear and since replacement parts are no longer fabricated i think it's time to buy a new one.
Jan 30, 2010 | Washing Machines
Model A511 washer Agitator is not moving as vigorously as it used to. Removed front and found excessive oil residue in the bottom. Repair or buy ?
excessive oil . is usualy found under the machine / if inside / on side's of shell this could be water seal leakage . the 511 is a very good machine but its also very old . . agit problem is usualy in the belts and motor roller base . /try cleaning the pulleys and replace belt set / 2011124 and 2011125 / put a roller base set w springs . this will perk it up ,,use info on belt package for belt adjustment. they run loose. ( do not over tighten .)
Dec 18, 2009 | Washing Machines
Washer overflowed, water all over the floor, any
you have a leaking pump and need to replace it.
Sep 14, 2009 | Maytag Performa PAV2200
Maytag A511 washer tub vibration
The tub should not become unbalanced over time. There suspension springs may wear unevenly, however. Replace all of the suspension springs and it should be fine.
Jul 31, 2009 | Whirlpool LSQ8000 Top Load Washer
Water still in Maytag Washer
Hello.
You will need to replace the pump on your unit. The part number for your pump is 6-2022030. This will fix your unit up and your problems will disappear.
Jul 22, 2009 | Washing Machines
Old machine; model A511. wash cycle won't
Should be worth fixing. Belt kits for Maytag A511 washers are still available on line (about $30).
Jul 08, 2009 | Washing Machines
How do i open the top on an old maytag A511 washer?
Hi, Remove the two screws holding the front panel to the cabinet. The screws are in the slanted part if the front panel.
After the [anel is removed, locate the two 3/8" screws in the upper corners holding the top to the cabinet. The top will raise up. I hope this helps.
Please let me know if I can assist you further.
Vic
Jun 19, 2009 | Whirlpool LSQ8000 Top Load Washer
Washing Machines Logo
129 people viewed this question
Top Washing Machines Experts
