Question about Westinghouse Electric LCM-22W2 Monitor
What and how much is a power supply board for the westington lcm-22w2 monitor. my tv went out i took it apart checked the circutry to me doesnt look like anythings rong. dont know what the caps are the fuse is fine. and no black spots so nothing blew in it. i think the power suplie just went to ****. could you guys give me info on what type of power board i need to buy for it and how much it is thanks. my
  • 11,361 Answers
Check here: <a rel='nofollow' href="http://www.shopjimmy.com/catalogsearch/result/?q=Westinghouse+LCM-22W2">http://www.shopjimmy.com/catalogsearch/result/?q=Westinghouse+LCM-22W2</a><br /> <br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">If you are going to DIY and have proper tools and know safety precaution then please read on:</span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: <a rel='nofollow' href="http://s807.photobucket.com/home/budm/allalbums">http://s807.photobucket.com/home/budm/allalbums</a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">Post back what you see inside so we can guide you further and it will help out other people in the future also.</span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'"><a rel='nofollow' href="http://en.wikipedia.org/wiki/Capacitor_plague">http://en.wikipedia.org/wiki/Capacitor_plague</a><span style="mso-tab-count: 1"> </span></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">Capacitors kit: <span style="mso-spacerun: yes"> </span><a rel='nofollow' href="http://lcdalternatives.auctivacommerce.com/">http://lcdalternatives.auctivacommerce.com/</a><span style="mso-spacerun: yes"> </span>he can make you a set of caps for you.</span><br />
Posted on Aug 26, 2010
Trying to program my Westinghouse LCM-22w2 ComputerMonitor/TV with my AT&T U-Verse Remote Control. What's the code?
There is no tuner in the monitor, it only works as a TV with a tuner added. The remote would work with the tuner, not the monitor !
Dec 11, 2010 | Westinghouse LCM-22w2 Television
My LCM-22w2 monitor will now rarely start up. It powers up white-screen and won't do anything. Occasionally it powers up OK and works fine.
wford451, You should open up the unit and inspect the "switch-mode-power-supply"/"CCFL inverter supply" printed circuit board for the common 2 problems that create symptoms like yours. Do some reading in my and other CCFL back-lit lcd monitor technicians fixya profiles. They are loaded with solutions to fix your unit. Your LCM 22W2 is no different than any other brand in it's basic design and operation!!! 12fixlouie
Mar 17, 2010 | Westinghouse 22" Widescreen LCD Flat Panel...
Monitor Brightness
most user manuals for these moniters you can get on line (free downloads)
it will explain how to use the buttons on your monitor
Feb 02, 2010 | Westinghouse LCM-19v1 Monitor
White screen
I fixed it! It's the power supply board.
The Westinghouse LCM 22w2 has bad capacitors on the yellow power supply board. This is a common problem plaguing motherboards and LCD flatpanels that use capacitors from Taiwan. If you know how to solder, or know somebody that can, it's actually a pretty easy fix. Take out the yellow circuit board on the inside, write down the specifications for each of the capacitors (the cylindrical things) go to the electronics supply store and get the replacement capacitors. You can go over the voltage specification (not under), but keep the capacitance value matching. Replace one at a time. Go to www.badcaps.net for advice, tutorials and training on doing this. *You really should replace all the capacitors*, but the very large one next to the power plug I did leave on the board because I couldn't find a match. To my delight, the white screen of death went away and it was working as new!
I saved a ton of money fixing this, it's definitely worth learning how to solder to do this.
www.ctcco.com for professional hosting solutions
Feb 21, 2009 | Westinghouse LCM-22w2 Television
Monitor Won't Turn Off
I fixed it! The 'white screen of death' is fixable! It's the power supply board.
The Westinghouse LCM 22w2 has bad capacitors on the yellow power supplyboard. This is a common problem plaguing motherboards and LCDflatpanels that use capacitors from Taiwan. If you know how to solder,or know somebody that can, it's actually a pretty easy fix. Take outthe yellow circuit board on the inside, write down the specificationsfor each of the capacitors (the cylindrical things) go to theelectronics supply store and get the replacement capacitors. You can goover the voltage specification (not under), but keep the capacitancevalue matching. Replace one at a time. Go to www.badcaps.net foradvice, tutorials and training on doing this. *You really shouldreplace all the capacitors*, but the very large one next to the powerplug I did leave on the board because I couldn't find a match. To mydelight, the white screen of death went away and it was working as new!
Jan 15, 2009 | Westinghouse LCM-22w2 Television
Can't find correct setting for westinghouse lcm22w2 monitor
I don't know if this actually will fix your problem, but all LCM 22w2's are plagued with the 'white screen of death' and eventual power shutoff, including garbage characters and faulty menu, video output, etc. Here's how I fixed it.
http://www.ctcco.com for professional hosting solutions
Jan 07, 2009 | Westinghouse LCM-22w2 Television
Screen goes white
Dec 24, 2008 | Westinghouse LCM-22w2 Television
No image on my Westinghouse LCM-22w2 monitor
Your problem isn't precisely the same one I had, but I have the feeling you're not saying that this was a problem that gradually got worse over time and now it won't power up.
Nov 13, 2008 | Westinghouse LCM-22w2 Television
Monitor shuts off for a few seconds when i play games or watch videos.
I fixed it! It's the power supply board. The bad news is you need to solder.
Dec 16, 2007 | Westinghouse LCM-22w2 Television
Black screen
The Westinghouse LCM 22w2 has bad capacitors on the yellow power supply board. This is a common problem plaguing motherboards and LCD flatpanels that use capacitors from Taiwan. If you know how to solder, or know somebody that can, it's actually a pretty easy fix. Take out the yellow circuit board on the inside, write down the specifications for each of the capacitors (the cylindrical things) go to the electronics supply store and get the replacement capacitors. You can go over the voltage specification (not under), but keep the capacitance value matching. Replace one at a time. Go to www.badcaps.net for advice, tutorials and training on doing this. *You really should replace all the capacitors*, but the very large one next to the power plug I did leave on the board because I couldn't find a match. To my delight, the problem went away and it was working as new!
Aug 19, 2007 | Westinghouse LCM-22w2 Television
Westinghouse Electric LCM-22W2 Monitor Logo
150 people viewed this question
Top Westinghouse Electric Computers & Internet Experts
greg benton
vimal
vimal
Jerry Kramer
Jerry Kramer
Are you a Westinghouse Electric Computer and Internet Expert? Answer questions, earn points and help others
