Question about Toshiba Satellite A135-S4527 Notebook
Screen goes black , but when you close the lid and reopen it comes on just a bit then goes black , Is the screen bad ??
    Sergeant:
    Champion:
  • 387 Answers
It could be the switch that change to Standby mode when you close the lid <br /> I can fix this <br /> <a rel='nofollow' href="mailto:doron_c21@yahoo.com">doron_c21@yahoo.com</a><br />
Posted on Aug 26, 2010
Screen goes black after a couple hours
There are a couple of possible causes and solutions... Please give some more info.
Is the hibernation period long enough to allow the TC4200 to cool down or is it just long enough to close the lid and reopen it?
I believe I can give you a definitive answer with more info.
Jan 26, 2014 | Compaq tc4200 Tablet PC
While using the screen goes black but if you look hard you can see it is still on because I can see the brighter windows but just barely. I can close the lid and reopen and the screen is on but the...
It could be your LCD inverter is going bad. CLICK HERE to see. It is relatively easy to replace. Remove the LCD screen bezel screws and gently lift away close to the bottom. The inverter is on the bottom right under the LCD itself. Usually 2 screws to remove and unplug then replace. If it is not the inverter then it is your LCD backlight in which case you will need to replace the screen.
May 15, 2011 | Panasonic Toughbook CF-51 Notebook
There are multi colored vertical lines on LCD Screen going to a total black screen. Laptop connected is to an external monitor = normal display on the external monitor I removed and reinsert the video...
Unfortunately, you're not going to be able to get a new cable as Toshiba will not sell OEM replacement parts to anyone but an authorized repair center.
This may just as likely be a problem with the sockets/plugs as with the cable itself, as they are rather fragile. It may be worth spending a few bucks for a used cable just to see if it will solve your problem. Also be sure that the thin plastic shim found on the top of most of these cable ends is still there, as they can come off rather easily, and the lack of it will cause a poor connection.
Your other alternatives are (1) Toshiba repair center, or (2) using the external monitor.
Hope that's helpful.
Dec 31, 2010 | Computers & Internet
When I close the lid on my Toshiba X205S9800 laptop and reopen the lid, the screen is black. The computer is on and running as I left it, but there is no picture. I have had this problem for quite sometime...
when you close the lid your toshiba goes into hibernate mode. to disable this perform the following.
Note: you must have administrator priviledges to be able to perform this.
To make hibernation unavailable, follow these steps:
  1. Click Start, and then type cmd in the Start Search box.
  2. In the search results list, right-click Command Prompt, and then click Run as Administrator.
  3. When you are prompted by User Account Control, click Continue.
  4. At the command prompt, type powercfg.exe /hibernate off, and then press ENTER.
  5. Type exit and then press ENTER to close the Command Prompt window
Dec 06, 2010 | Toshiba Computers & Internet
My dell C610 Screen does not come back on when i reopen the lid. I turn the computer on use it then close the lid for about a min then reopen it and the screen just stays off but the computer itself is...
Known issue. The windows default settings for power saving mode tell the computer to switch it off (sleep) when the lid is closed. The sleep mode doesn't turn completely the computer, just the visualization devices (mainly screen, also some other components not required for the computer).
What I would advise you to do after restarting the computer (press on the power button for a very long time, until you cannot hear it working), is to change the power settings.
go to control panel, choose "power options", then see if you have "choose what closing the lid does". If it's not there (not all laptops show this option), choose "change when the computer sleeps", then change " put the computer to sleep" to "never".
That should do it. if you have any questions feel free to ask me.
Dec 07, 2009 | Dell Latitude C610 Notebook
My dell latitude d520 was working fine and now when I am on my screen starts running lines from left to right across the screen and then goes blank or black and sometimes comes back on and sometimes it...
if you tap the back of screen and it goes on and off chances are its loose ribbon cable ,
every time you open and close lid , it will tug on it a bit, if the light goes off then inverter problem
Mar 10, 2009 | Dell Latitude D520 Notebook
Black screen
It sounds like your “Suspend Switch” is acting up. The Inspiron 1501 uses a mechanical switch to detect if the lid of the system is open or closed. A camber is built into the hinge of the system that activates the suspend switch plunger as the LCD is lowered to the closed position. If the switch is broken or nonfunctional, then it can be replaced separately. It is located under the hinge cover next to the right hinge on the system.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Oct 28, 2008 | Dell InspironTM 1501 Notebook
Black screen
Yes, it could be stuck in hybernation
Or.. Check to See if the Lid Switch is Stuck Down... Some laptops have alittle Movable plastic pin that depresses when the lid is closed to turn the screen off... this can sometimes get stuck down to the board button.. causing the symptoms youre experiencing
Jun 04, 2008 | Toshiba Satellite A105 Notebook
Monitor/display doesn't come back on
Under the power saving options in the control panel you can have the laptop set up the way you want...under the advanced settings you can select when i close the lid "do nothing"
May 07, 2008 | Dell Inspiron B130 Notebook
Toshiba Satellite A135-S4527 Notebook Logo
263 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
