Question about Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore Quietguard 2
Hi I have a Kenmore Quietguard 2 and when I start it, it won't fill with water. I assume a pump is shot?
Thanks
  • cabojim May 29, 2008
    when dishwasher is started it will not fill with water
    Genius:
  • 1,073 Answers
Check the water inlet valve first
Posted on May 05, 2008
What can be wrong with my kenmore quietguard dishwasher if it does not fill with water
Most likely is is a stuck float or float switch. Next most likely possibility is a loose or broken wire going to the water fill valve. For some reason, mice seem to be attracted to this wire (usually 2 thin brown wires) - check for mouse droppings and look for chewed-through wires. Finally, if everything else seems okay, it is probably a bad water fill valve.
Sep 07, 2014 | Kenmore Dishwashers
Kenmore Elite 665.17053400. Powers up ok, fills up with water ok, but wash cycle won't start. I can hear the motor trying to turn but sounds like its seized up. If I cancel the wash, the machine drains...
This dishwasher has a very sophisticated wash system. In order to improve the wash efficiency it uses a chopper and a soil sensor. It is very likely the chopper assembly is clogged which is blocking the water from circulation and straining the wash motor.
See this diagram. Item 6 is the chopper. Worst case is the pump motor needs replacement. This is item 10.
Good luck
May 27, 2011 | Kenmore Dishwashers
Kenmore Quietguard 2 dishwasher not filling.
There is a solenoid that keeps the water in the washer. It is either faulty or there is something preventing it from closing completely. If there is no power applied to the washer, does it then hold water?
Apr 28, 2010 | Kenmore 24 in. 17002 Built-in Dishwasher
Not draining..agitator making a grinding type of
The bad news is with the combination of not draining and the grinding it is undoubtedly the drain pump. The good news is they are not difficult to replace. Let me know if you need any info on replacing it yourself and I'll try to give you the steps needed.
Hope this helped.
Sep 14, 2009 | Washing Machines
Kenmore quietguard standard wont start.
is there any function at all? if not, check thermal fuse located inside near control panel, check www.searspartsdirect.com and enter your model # to show how to take it apart. If it has functional display lights, replace main control board after ohm test on wash motor and fill valve.
Jun 25, 2009 | Dishwashers
I have a Kenmore Quietguard dishwasher, only a few years old, and it won't drain. I pulled it out and checked the drain hose, could not find a clog. I took the basket and sprayer out, couldn't find any...
I have a Kenmore Quietguard portable that won't stay connected to my kitchen sink faucet. Checked all I can and continues to spray the wall and me without staying attached securely to the faucet adapter. Help!! Any ideas?
Jun 17, 2009 | Kenmore 24 in. 15162 Built-in Dishwasher
Will not drain
There maybe something stuck in the pump or the pump is bad. I have also seen obstuctions in the drain hoses comming from the pump causing it not to drain properly.
May 12, 2009 | Dishwashers
Kenmore Ultrawash QuietGuard 3 Dishwasher not draining or rinsing
Hi Claire,
Are you using rinse aid?
that may help with the film.you may also have stuff down in the trap causing the water to drain slow.
Nov 05, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Kenmore 24 in. 15932 Built-in Dishwasher Logo
1,178 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
