Question about Craftsman 8.0 amp Reciprocating Saw
How can I remove the blade. There is an allen screw that I removed but the blade is still attached to something.
  • 43,501 Answers
Getting a broken blade our of the sawzall chuck can be difficult and require some ingenuity and patience...
Sometimes there be enough blade left so that you can grab it with a needle nose pliers... othertimes it is flush and that makes it more difficult... holding the chuck in the release position and rapping the saw against a table or with a hammer can jiggle the piece out....of course you have the chuck pointed down while you do that...
Also moving the piece around a bit with a stiff wire and also soaking the chuck and blade with WD-40 helps also....
Usually it will take a combination of these things and some persistance to get the job done...
heatman101
Posted on Aug 27, 2010
    New Friend:
What If blade is WIDE enough at fitting to be forced in...It is 'Universal Blade' That took some "UMPH" to get in/out when whole. Now that it is broken I see no way to get it released other than paying for maintenance, :( Can anyone help?
Posted on Nov 20, 2012
Bolt is put in wrong in Coleman furnace blower so we can't get motor out
If the improperly installed 'bolt' is in a location easily accessed, try clamping tighly a pair of vice grips on the head of the bolt to facilitate removal. I'm assuming 'put in wrong' probably means it is jammed in 'cross threaded' and you're unable to turn it correctly with a correct wrench.
If you're referring to the 5/16" square headed set screw that holds the blower wheel to the motor shaft, once the entire blower assembly is removed from the furnace cavity, access to the set screw is through the side of the blower wheel. If the wheel is attached with an allen screw instead of the 5/16" square head, access is either the same as for the other, or if you have the long
extended allens, look for a notch in the blade directly over the set screw location.
Feb 22, 2015 | Coleman Heating & Cooling
How do i remove the gas knobs on a bauknecht gas hob
If they dont pull off easily then they are attached with set screws on the outside of the knob. Rotate the knob an you should see a small hole with either a flat bladed screw or allen set screw type. Could be torx as well. Dont strip screw.
Jan 29, 2015 | Cooktops
How to remove blade wont budge with allen key
Hallo Ingrid
Pl send a picture Of allen bolt , if possible make a flate cut with hacksaw and open with screw driver.
Jayesh Desai
Jul 16, 2014 | Makita Jigsaw Blade
Remove blades
I am having new blades sent from tech support, they broke. Call them at 800 221 7977. If over 1 year sense you got them, say how many units you bought and they might give you for free. Worked for us. Hopes this helps.
Aug 06, 2012 | Minka Aire F602-BNCH Gyro? Fan
Makita 2012nb planer. The drive (top) sprocket keeps stripping out the flats on its arbor hole and the allen bolt loosens and backs out. Not sure which happens first. I've tried high strength loctite...
I think your screw is broken you should change the screw which attach the rollers and the blade. If you start a machine, screw turn out and let the roller stop rolling that means your screw and the ring are broken, you have to change them.
May 08, 2011 | Makita 2012NB Electric Planers
Do you have to pull the fan off to get the serpentine belt off a 1989 mercedes benz 260e
There are typically three allen screws that attach the fan blade to the clutch, 5mm if my memory serves me. Remove those.
Feb 16, 2011 | 1989 Mercedes-Benz 300-Class
Casablanca stealth fan light scrapes against blade surround
There are two probable causes. One, the light housing has been pushed/bent up into the rotating assembly, which is possible if the fan were ever removed from the ceiling and sat on the glass.
If it has never been removed however, the most likely cause is that the Allen Set screw on the flywheel has loosened allowing the flywheel to slip down the motor shaft. It's a purely mechanical problem and if memory serves, to get to the flywheel, you remove the light pan and it's right there. Find the set screw, loosen it enough so that the flywheel is easy to move up and down and raise it up a bit and then cinch it down tight. It's a fairly common problem and for the life of me I cannot understand why Casablanca would not use loctite on that set screw. I mean you pay $500+ for a fan, it should outlast you, right?
Jun 03, 2010 | Casablanca Fan 3245T Ceiling
HOW DO I REMOVE THE BLADES? I THINK SOMETHING IS
i do not think the blade's are removable.look underneath unit ,in the center there may be a hex/allen bolt that is use'd to unjam the blade's/disc. it also may be easie'r to remove unit to work on
Apr 22, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I need to replace the blades on a Sears Scroll saw. Model # 149236160
Your scroll saw should have come with Hex end tools to use when changing out the blade. You must release the tension on the blade (located on top of arm above blade). There is a small allen head screw which has to be loosened with an allen wrench to release the blade. There is also an allen head screw under the working surface which will have to be loosened to remove blade at the bottom. Replace blade at the bottom 1st, tighten up then go to the top, tighten it, then reset the tension and you're ready to saw again. Make sure to get a visual on the directions of the blade teeth before you remove it so you can replace the new one the same way. I hope this is helpful.
Sep 26, 2009 | Craftsman Saws
How to fit bosch PHO 15-82 planer blades
  1. Unplug from mains and turn planer upside down.
  2. Using Allen key (stored in heel of planer) slacken off the 2 sets of 3 screws that clamp the blade in place. One 360 degree turn should be enough
  3. Use piece of wood or flat screwdriver blade to slide old blade out the side of the blade track.
  4. Rake any dirt out of the blade track with screwdriver blade.
  5. Slide in new blades, check it is correctly centred and tighten screws. Take care not to over-tighten.
  6. Repeat with second blade.
  7. Carefully rotate blade carrier by hand checking that blades are parallel to the sole of the plane.
  8. If blades are out of true you will need to remove them again, take off the blade clamping plates and adjust the blade locating plate, which is held in place by 2 further Allen screws.
Pictures below from Bosch manual for further information
Sep 16, 2009 | Bosch Tools & Hardware - Others
Craftsman 8.0 amp Reciprocating Saw Logo
457 people viewed this question
Top Craftsman Saws Experts
Craig Butler
Craig Butler
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
