Question about Cub Cadet Garden
I need instructions for replacing the head gasket. Do you know where I can get those?
    Problem Solver:
  • 5 Answers
Should be able to buy at any auto parts store. small engine repair manual.
Posted on Aug 26, 2010
How do I check for a blown head gasket
Dwayne, the third link talks about the signs and test for leaking head gasket. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
blown head gasket on kohler command pro 25 horsepower
How to replace head gasket on Kohler command
Legacy Kohler engine leaky head gasket repair
May 01, 2016 | Kohler Command V-Twin Horizontal Engine...
Engine head gasket
I suggest you purchase a repair manual for your Benz, if available. It's a major task to remove the head(s) and replace the gasket. You'll need torque sequencing specs, probably new head bolts, etc. You should have the head checked at a machine shop for warping. I think it's beyond the scope of this web site to give very detailed and explicit instructions for such a major engine job. Good luck....
Apr 27, 2014 | 1980 Mercedes-Benz 280 SLC
Fix head gasket
For leaking head gasket it has to be replaced. For head gasket leaking and other troubleshooting, there are help links provided. Its suggested to click the link below and go through the troubleshooting procedure to confirm the issue :-----Leaking head gaskets? http://schematicsdiagram.blogspot.com/2011/12/leaking-head-gaskets.html
-----------Water in engine oil? http://schematicsdiagram.blogspot.com/2011/12/water-in-engine-oil.html
-----------How to replace head gasket on car?http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-head-gasket-on-1994.html-------------How to know what is faulty Cylinder head or Head gasket?http://schematicsdiagram.blogspot.com/2011/12/how-to-know-what-is-faulty-cylinder.html
-------------- Can I just replace Head Gasket on 1991 Buick Century?http://schematicsdiagram.blogspot.com/2011/12/can-i-just-replace-head-gasket-on-1991.html Location of Head Gasket ?
http://schematicsdiagram.blogspot.com/2011/12/location-of-head-gasket-on-1994-grand.html
HOW TO REPLACE A HEAD GASKET
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-head-gasket.html
How to replace Exhaust Manifold?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-exhaust-manifold-on.html
How to replace Intake Manifold?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-intake-manifold-on-acura.html
How to replace Cylinder Head ?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-cylinder-head-on-acura.html
Is it Easy to replace head gasket?
http://schematicsdiagram.blogspot.com/2011/12/is-it-easy-to-replace-head-gasket-on.html
Should I only replace head gaskets or complete head gasket assembly?http://schematicsdiagram.blogspot.com/2011/12/should-i-only-replace-head-gaskets-or.html
This will help. Thanks.
Feb 27, 2012 | Renault Cars & Trucks
Replaceing head gasket
For leaking head gasket it has to be replaced.For head gasket leaking and other troubleshooting,there are help links provided.Its suggested to click the link below and go through the troubleshooting procedure to confirm the issue :-----Leaking head gaskets? http://schematicsdiagram.blogspot.com/2011/12/leaking-head-gaskets.html
---------This will help.Thanks.
Jan 28, 2012 | 2002 Kia Sportage
Head gasket
Jan 27, 2012 | 1992 Plymouth Voyager
Where is the head gasket located at on a 1994 grand marquis
The head gasket (in your case gaskets) is located on the top of the engine block under the engine cylinder head which is under the Camshaft cover which is the very top of the engine. This car is a V8 engine so it has 2 heads and 2 head gaskets, one on each side of the engine. It is a very expensive job to replace head gaskets.
Mar 25, 2011 | Mercury Grand Marquis Cars & Trucks
White smoke coming out of tail pipe along with anti freeze
You likely have a blown head gasket. Check the plugs to see what cylinder is getting wet and replace the head gasket on that bank. Let me know if you need instructions or have more questions.
Nov 07, 2010 | 1989 Ford Thunderbird
Can i just replace the head gaskets or do i need to replace alll gaskets
when u replace the head gaskets u must also replace any parts gasket that u remove (valve covers, intake manifold etc.) to get the heads off, they sell what is called a "Valve Grind" gasket set that is what u need, it will have all the gaskets in it u need..
May 27, 2010 | 1991 Buick Century
How to replace the head gasket for a toyota truck 4x4
I assume you have never replaced a head gasket, if you have to ask? Or, do you just need help now you have it apart?
Feb 08, 2010 | 1998 Toyota Tacoma
Pontiac 3.1 with blowed head gasket
Are you sure it needs a head gasket? These are common for just having leaking intake gaskets and that is alot easier and cheaper to fix.
Mar 22, 2009 | 1998 Pontiac Grand Am
Garden Logo
233 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
roeb
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
