Question about Cell Phones
NEC PTC/207/04/023 - Cell Phones
What number will I use to reset the PTC unit in sharp copier mx2600n
I assume you have a C4-** code displayed.
The PTC unit is failing, if you turn the copier off & on then this will reset the machine. If the error is still there then the PTC will probably have failed & will need replacing.
Hope this helps.
Dave.
May 03, 2016 | Sharp Office Equipment & Supplies
Where is the fuse for the power windows on the 98?
Voyager, 98.
most cars this era have 2 fuse boxes. cab and engine bay
and circuit breakers for windows.
are all windows dead, the motors.>?
i look in alldata.com so can you.
and its PTC 8 and 9 in the JB1, junc.box1.
this fuse box JB has row of 10 PTC fuse in a line, dead center of box.
next you will ask what is PTC
answer ( high tech circuit breakers)
http://www.atcsemitec.co.uk/ptc_resettable_fuses.html
Jun 19, 2014 | Plymouth Voyager Cars & Trucks
Telxon PTC-710 just showing 66 on the screen
You have no arc chip below the os chip or the ptc is not seeing it.
Feb 08, 2014 | telxon Ptc 710 Portable Barcode Data...
My fidge is a kenmore medel 25357685790 my starter ptc looks to be burnt so i decided to replace it but it includes three pieces the capacitor, starter ptc and overload. the new parts only have a diffrent...
HI,
I use ERP 410 (relay capacitor and overload) Get it at your local Appliance Parts Store
Very easy to install
Leo Ponder
imufo2
Please vote for me if this helps.
Aug 02, 2011 | Refrigerators
Compressor is short,Model FF 350.This is 350 lt.double door frost free fridge.Compresser needs to be replaced,It is bought in April 2003
If you have had recent power failures, OFTEN the PTC motor starter for the compressor gets fried. The part can cost $50 or if you shop online as low as $2. What happens is if power briefly goes off and compressor has been running, the pressure is built up and when pwoer comes right back on, the PTC starter cannot start the compressor under pressure. Usually the compressor will get hot and just hum. The PTC unit is in a box that plugs on the side of the compressor. There is a capacitor that survives this and if you reuse that, you can get just the PTC part for less than $2.
The PTC is a little disk about the size of a quarter and fourr times as thick. It comes in a plastic box that the capacitor plugs onto and the whole thing then plugs onto the compressor.
Feb 11, 2011 | Air Tools & Compressors
HOW DO YOU REPLACE A START RELAY SWITCH ON A FRIGIDAIRE SIDE BY SIDE MODLE FRU26SA
Power off i.e unplugged
Open the back
Remove retaining clip on wiring side of compressor plastic cover.
NOTE wiring connections to terminals on the OLD relay. 1, 2 4 4 ect... make a simple wite color to terminal number sketch.
PULL off PTC relay WITH terminals by pulling HORIZONTALLY (Usually to the left / 9 O'clock position)
NOTE the thermal overload comes off WITH the PTC relay.
Remove wire from Thermal overload terminal and transfer the thermal overload to the new PTC relay.
Slide NEW PTC relay onto compressor terminals
Transfer remaining wires from OLD PTC to the correct terminal on the new PTC relay.
TEST compressor start before installing cover... PLUG in unit
After the test unplug the unit... reinstall the plastic cover and wire clip.
Reinstall back panel
Return unit to service.
Thanks for choosing FixYa
Kelly
NOTE the thermal overload will s akl
Sep 19, 2010 | Frigidaire Side by Side 26.0 Cubic Foot...
Haier aficionado model AES44BPG compressor wont stay on
I had the same problem. Mine turned out to be the PTC starter. Checked the compressor coil resistance and it ws fine. Replaced the PTC starter with Item #: 1268268 from Repairclinc.com and it started right up. The PTC starter was an exact replacement.
Hope this helps some else trying to solve this problem. To bad Haier doesn't offer this part!!
May 01, 2009 | Haier (B000194UBA) Compact Refrigerator
Fuses
Hi there!
Dead short in the power supply, possibly the rectifier or the PTC has failed. PTC located in the Primary supply at the point where the coil around the tube plugs into the Main board. Two terminals to be exact. Normally cream in colour if it is an original Philips PTC. If the rectifier is short you may expect to have more items blown. Good Luck, Regards, JUS004
Mar 22, 2008 | Philips 27PT5441 27" TV
PTC 96012 Replacement
Check this link: //http://www.fersay.com/view/catalogo/ls_catalogo.php?q=PTC+96012+&busquedaen=cod_etco&lang=es&busqueda=1
Jan 23, 2008 | Televison & Video
Cell Phones Logo
111 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
