Question about Canon PowerShot SD1000 Digital Camera
Memory card error. At first said card was locked but now just says error
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Aug 26, 2010
Nitrotrike
  • 589 Answers
SOURCE: memory card error displayed
There is a little slide switch on the side of the memory card. Good luck!
Posted on Jan 08, 2008
  • 11967 Answers
Did you format the card in the camera before trying to use it?
Posted on Sep 18, 2009
t00nz
  • 4738 Answers
SOURCE: how to clear memory card, error card lock on a
Remove the SD card from the camera. Slide the tiny switch on the side of the card to its other "unlocked" position. Reinsert the card in the camera. But if you've already tried this, see this link for additional things that you can try.
Posted on Oct 12, 2009
  • 20 Answers
SOURCE: 'memory card error - card locked!'
pull the card out
find the slide button on the side and slide it to the "unlock" position
put card back in
enjoi
Posted on Mar 04, 2010
t00nz
  • 4738 Answers
SOURCE: Memory Card Error Card locked. I get the same
If you've already tried the lock/unlock switch on the side of the card, then see this link for additional troubleshooting tips for this problem.
Posted on May 16, 2010
My sandisk memory stick pro duo has shown up file error in my pictures so when i go to transfer them on to my computer it can't get past the error how do i solve this?
Without knowing what the specific error is this is my best guess:
SOLUTION 1 - Unlock the memory card.
There is a Lock switch on the left side of the SD card. Make sure the Lock switch is slid up (unlock position). You will not be able to modify or delete the contents on the memory card if it is locked.
SOLUTION 2 - Toggle the lock switch.
If the lock switch is not on lock:
1. Slide the switch up and down. Repeat this 3 times.
2. Let it stay on the Lock position for 30 seconds.
3. Slide the switch up to unlock the card.
4. Try to transfer files into the device.
Jan 12, 2011 | SanDisk 2GB Memory Stick PRO Duo Memory...
Tip
Memory Card Locked / write protected error.
Hi due to so many questions asked about this here it is. How to deal with memory card locked/write protected error.
For non-SD cards: Format the card
The data on the memory card may be corrupted.
WARNING: Formatting will delete all the files in the device. Backup all your data before formatting.
Memory card write protected, memory card locked, memory card will not read, can't use memory card.
on Jan 10, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
My canon camera keeps displaying 'memory card' error and 'memory locked', what do I do?
check you sd card there is lock and unlock switch. unlock that button
Aug 08, 2010 | Canon Cameras
pull the card out
put card back in
enjoi
Mar 04, 2010 | Canon IXUS 80 IS Digital Camera
Display says memory card error card locked
Format memory card by using card reader, then try it.
Oct 22, 2009 | PNY 4GB Secure Digital High Capacity...
Memory card error
Sep 02, 2009 | Canon PowerShot A700 Digital Camera
Memory card is locked
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Feb 18, 2009 | Canon PowerShot A460 Digital Camera
Canon Camera - Memory Card error & Card locked error
Try reading the card independent of a camera i.e. on a computer or a photo kiosk to determine if the card is readable damaged
Jan 07, 2008 | Canon PowerShot A410 Digital Camera
Memory card error displayed
Nov 25, 2007 | Canon PowerShot A410 Digital Camera
"Memory card is locked"
This error message means that the memory card is write-protected. To take a picture, turn off the camera. Then insert a new card or change the storage location to internal memory
Aug 29, 2005 | Kodak EasyShare CX7530 Digital Camera
Canon PowerShot SD1000 Digital Camera Logo
26 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
