Question about Harley Davidson Harley-Davidson FLHR Road King
What should the front and rar air suspension pressure be on a 1996 road king
38 Pounds per Sq Inch
Posted on Jan 04, 2011
1999 flhr road king shock air pressure
Recommended Suspension Air Pressure: FLHX, FLTRX, FLHR/C
SHOCK LOAD TOTAL WEIGHT PRESSURE
LB. KGPSI kPa
Solo rider up to 150 up to 680 0
150-200 68-91 0-10 0-69
200-250 91-113 10-20 69-138
250-300 113-136 20-30 138-206
over 300over 136 30-50 206-345
Solo rider with capacity
luggage of 40 lbs (18 kg) up to 150 up to 68 10-20 69-138
150-200 68-91 20-30 138-206
200-250 91-113 30-40 206-276
250-300 113-136 40-50 276-345
over 300 over 136 50 345
Rider plus passenger ALL ALL 40-50 276-345
Maximum GVWR ALL ALL 50 345
If Tour-Pak is installed, add 5-10 psi (34-69 kPa) to shock pressure.
Do not exceed 50 psi (345 kPa) suspension pressure.
May 13, 2014 | Harley Davidson FLHR Road king Motorcycles
What is max air pressure for rear shocks on 2009 harley road king flhr?
LB. KGPSI kPa
Maximum GVWR ALL ALL 50 PSI 345 kPa
May 07, 2014 | 2008 Harley Davidson FLHX Street Glide
How much pis in front forks hd flhr road king
15 psi is the Factory recommended pressure.
Try it. If it feels too spongy pump it up to 18-20. If you need more give it a bit more but never go over 25 psi!
If it feels to harsh drop the pressure to about 10 psi.
Worth checking your fork oil too. You really need clean new oil every 10,000 kilometres (6,000 miles).
Feb 27, 2013 | 2000 Harley Davidson FLHR-FLHRI Road king
How do I adjust rear shocks on my 2000 Road King?
Hi Patti, Road Kings have air shocks at the rear. You will need a FL touring hand pump and adjust the air pressure accordingly to your weight/load.
Aug 31, 2010 | 2000 Harley Davidson FLHR-FLHRI Road king
What is the air pressure range for the front shocks on a 1997 Road King
Hi Stevedean887, for more information about your question please visit the websites below. Good luck and have nice day.
Controls and Indicators
Aug 21, 2010 | 2000 Harley Davidson FLHR-FLHRI Road king
Two valves for suspension one for rear won't take air lines look OK where to start looking also valve for front has oil in it help manual doesn't touch on air suspension much 2000 road king classic
Hi Rlloyd845, try pumping air into the rear suspension and spraying windex on all the connections to see where the leak is then repair as necessary by cutting off the very end of line to make for new seat. Good luck and have nice day.
Jun 20, 2010 | 2008 Harley Davidson FLHRC Road King...
Install rear shocks
With motorcycle raised so tire is just touching the supporting surface apply two or three drops of LOCTITE MEDIUM STRENGTH THREADLOCKER 243 (blue) to the threads of each mounting bolt then install the lower shock mounting bolt, lockwasher and flat
washer and tighten to 35-40 ft-lbs (47.5-54.2 Nm) and then install the upper shock mounting bolt, lockwasher and flat
washer and tighten to 35-40 ft-lbs (47.5-54.2 Nm). THEN insert the air tube into the air tube fitting until it bottoms, gently tug on the tube to verify that it is locked in place and then with a special no pressure loss pump available from H-D properly pressurize the rear air suspension system and check for leaks.
Apr 26, 2010 | 2008 Harley Davidson FLHR Road king
Front end wobble
First thing to do is check front and rear tyre pressures. Next check for un-even wear of front tyre. Then check steering head bearings for correct tightness. Also check for bent front brake disks as one side bent can cause this. Check for worn wheel bearings also. Check engine mount rubbers as these can cause floating on bends if worn of loose. Basically check all chassis related items fully.
Feb 25, 2009 | 2000 Harley Davidson FLHR-FLHRI Road king
21" front wheel for 2002 road king classic
Goes right in. Except be sure to check front fender light bolt. Had to cut many before.
Feb 10, 2009 | 2002 Harley Davidson FLHR - FLHRCI Road...
Shocks
The Road King shocks are air adjustable via an air valve located on the right side of the bike just above the rear tire. Your Harley Davidson owner's manual will tell you what the shocks should be pressurized to depending upon the load on your bike (for instance - if you'll be carrying a passenger - the pressure should be a bit higher than it would be if you were riding solo). Don't even attempt to read the pressure unless you have the specialized hand pump that is used to pressurize the shocks. You can purchase this from Harley Davidson or via a third party online. The valve is a typical bicycle / auto air valve - but ... DO NOT attempt to pressurize it with anything but the specialized hand pump. Using anything else will risk over pressurization of your shocks and that's not good. The shocks hold a very small volume of air at relatively low pressure levels - so the hand pump is a must have.
Nov 10, 2008 | 2008 Harley Davidson FLHR Road king
Harley Davidson Harley-Davidson FLHR Road King Logo
106 people viewed this question
Top Harley Davidson Toys Experts
Tre Elkins
ray gallant
John Cleary
Level 1 Expert
Are you a Harley Davidson Toy Expert? Answer questions, earn points and help others
