Question about GE Profile 23.1 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - High-Gloss White
Freezer works Refridge does not get cold like it should
  • GE Master
  • 43,501 Answers
<span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN">Hi,</span><br /> <span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN"><br />Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling<br /><br />Refrigerator not Cooling or Fridge not Cooling<br /><a rel='nofollow' href="http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not" target="_blank">http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not</a><br /><br />How to Defrost Refrigerator Defrost Timer Problem <br /><a rel='nofollow' href="http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer" target="_blank">http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer</a><br /><br /><br />Water Running in efrigerator from Freezer<br /><a rel='nofollow' href="http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from" target="_blank">http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from</a><br /><br />heatman101</span><br />
Posted on Aug 26, 2010
Hi, freezer working but refridge part is not staying cold
Most refrigerators take cold air from the freezer and move it with a fan and duct work to the fridge section. You could have a blockage in the duct, usually ice buildup, or your freezer fan has stopped working.
Jun 02, 2015 | Refrigerators
Kenmore Elite bottom freezer, model number 596.76522500, Serial Number 10310256GL. Water dispenser on the inside left of the refridge. Water dispenser is not working, items are frozen in refridge. Ice...
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
The cold control needs replacing. Thats the knob with the numbers that turn the Ref OFF and ON.
What I do is call my local Appliance Parts Store with my model no. They are extremely helpful .
Get freezer and ref thermometer. Ref is probably too cold.
Freezer should be 0 to 10 degrees. Ref 33 to 35
If you need more help, Go here:
http://www.applianceaid.com/procedures.html
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Sep 09, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
Refridge. light went out. Bulb is good. Indicator
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 25, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Upper freezer is working but the temperature in the fridge part is approx. 65 degrees -- not cold.
This is a malfunction of the control board. The control board is telling the refridge side that it is plenty cold - so it doesn't divert the cold air needed to keep the refridge side cool enough. Check to see the the coils in the freezer are frozen - if they are, unplug the unit and defrost with a hair dryer. Dry up the water and turn it back on - that should solve your problem.
Aug 22, 2009 | Refrigerators
Dometic 2852 freezer gets cold but refridge does not
If your freezer is getting down close to zero degrees (F) then I doubt that your refrigerant is low. The most common cause of the refrigerator section not getting cool (approximately 40 degrees (f)) is a fan that pulls the coils in the freezer into the refrigerator has failed. A very common failure of a cheep little fan motor. Normally that fan is behind a panel in the freezer section at the bottom. Determine where the cold air in the refrigerator section normally enters and the fan will be above there.
Aug 11, 2009 | Dometic RM2652 Refrigerator
Freezer is working fine but no cold air getting to the upper area
If freezer is cold then you are not getting air flow to the frig side. Check your air flow setting It is the one next to the thermostat. If in doubt ,just set both controls to the middle setting and check in an hour or so.
Jul 23, 2009 | KitchenAid Architect KBRA20ERSS Bottom...
Refridge is not cold freezer is fine
You have ice on the temp control door that has blocked air flow. You will need to pull off the back inside panel of the freezer and de-ice it or have a tech do it and test the defrost controller. That is most likely the reason for the freeze up in the first place. Hope this helps. Good luck.
Jul 07, 2009 | Refrigerators
Freezer section is working but refridge not very cold.
check the vent that lets air from the freezer goes to the refrigerator. A control knob operates the amount of opening through the vent with a flap. makes the flap is not stuck, and responds to the knob, this is all mechanically link.
Jun 30, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
My refridge and freezer would stop working
there is a saftey overload switch on the compressor when the compressor is over heating it cuts out. when the fridge is turned off it resets the switch. So now the compressor has burned out totally. you more and likely need a new compressor
Feb 03, 2009 | Frigidaire FRT21P5A Top Freezer...
GE Profile 23.1 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - High-Gloss White Logo
16 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
