Question about Whirlpool ET1FHMXLQ / ET1FHMXLT Top Freezer Refrigerator
Why does water build up in freezer and goes into refrigerator
  • Whirlpool Master
  • 43,501 Answers
<span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN" lang="EN">Hi,<br />Here is a tip that I wrote about how to fix your freezer so that the drain hole does not keep freezing up.<br /><br />Water Running in Refrigerator from Freezer<br /><a rel='nofollow' href="http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from" target="_blank">http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from</a><br /><br />heatman101 <br style="mso-special-character: line-break" clear="all" /></span><br />
Posted on Aug 26, 2010
Build up ice on evaporation,alarm goes on,please help
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 17, 2011 | Viking Professional Series VCBB36 Bottom...
There is an ice build-up underneath the humidity control drawers and the food in the drawers is freezing. It is a model RB 215 LABB. We have adjusted the temperatures of both the freezer and the fridge,...
The problem isn't the humidity control or temperature control. When the refrigerator automatically defrosts it goes through a cycle of heating and melting the ice build-up then drains this water to a tray at the bottom of the refrigerator (underneath). The drain tube that lets this water flow down to the bottom tray freezes so the ice begins to build inside the refrigerator section.
The solution to this is to defrost the tube so water can flow again. There are heating coils in the freezer section behind the plastic in the back that you must remove and defrost.
This is an inherent problem with a lot of refrigerator/freezers. You should probably have your refrigerator serviced and to check the heating capability of the coils to keep this tube from freezing. Otherwise put this on your monthly schedule of manually defrosting.
Sep 23, 2010 | Samsung RB2155 Bottom Freezer Refrigerator
Freezer I guess is defrosting but the drain freezes and water goes into the bottom of the freezer and builds up ice
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
heatman101
Aug 19, 2010 | Kenmore 65234 Bottom Freezer Refrigerator
Ice build up on bottom freezer
Ice build up on the freezer floor alone, with no ice on shelves or food above the floor, usually indicates a clogged defrost drain problem. when your unit goes into defrost, the melt water is intended to go down a drain tube from the freezer to a pan on the outside bottom of the unit, usually near the compressor. Sometimes these drains are clogged with food debris, other times some of the melt water does not completely drain, and freezes - this build up of ice can then clog the drain. You can unplug the fridge, with both doors open and a fan blowing for 24 hours to temporarily remove the ice and water, but it will return most likely, in which case you would need to have the drain cleared out and / or have a drain heater installed by a qualified refrigerator repair service.
Apr 07, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
There is water collecting on the top shelf of the refrigerator
This can be caused by high humidity present inside your frig because of a leaky door gasket, which is noticable with rips, tears, and or out of alignment. If the gasket is in good condition, the problem is above the refrigerator section, the freezer. Every 6 - 8 hours the frig goes into defrost. Whatever ice has build up melt from the defrost heaters and goes into a drain. Sometimes the drain is iced up or debre builds up and the only other place the water is gonna go is= tada! the refrigerator! So the way to fix this will be to open the freezer back panel and see whats going on..
Mar 21, 2010 | KitchenAid Refrigerators
Leaking water and ice build-up in freezer
There's a drain hole in the freezer side behind the bottom drawer in the back wall that must be clogh ; put hot water into it untill melted the ice and keep pouring water to clean the drain (don't worry , the water goes to an evaporative tray) .Keep the drain clean by putting every 3/4 months half a cup of clorox or bleach.
Sep 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
There is water building up in the bottom of the fridge ( under the crisper drawers). If I leave it there it will freeze. What is causing the water? The fridge is 18 years old.
drain hose is plugged... the freezer it need to drain water when if goes into defrost .the drain from the bottom freezer down to the bottom of the fridge... there is a pan under the fridge that holds the water until it evaporates
Sep 19, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
What causes ice build up on the bottom of a freezer?
your drain is probably plugged so when the fridge goes on defrost the water has nowhere to go.After the defrost cycle when the frige starts to freeze again the water freezes up causing ice build up
Dec 18, 2008 | Admiral 26 cu. ft. Side-By-Side...
Whirlpool ET1FHMXLQ / ET1FHMXLT Top Freezer Refrigerator Logo
20 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
