Question about Dometic Rooftop RV Air Conditioner
Fuses on AC unit keeps blowing need solution can't continue to b replacing fuses
  • 139 Answers
Are the fuses time delay if they are not then get them ..try cleaning the coil on the roof with a garden hose .if the coil is dirty the unit uses more amps to run causing fuses to blow /or you may need a new start capacitor for the compressor /fan its the round silver thing with wires connected to it .when you take it apart to clean ..good luck let me know../joe/
Posted on Aug 26, 2010
    President:
  • 3,074 Answers
There is a wire that has rubbed its coating off and is shorting out more then likely the wire is going to be close to the roof or another surface. Just a matter of locating the wire and taping it up. Hope this helps tim
Blower not working on the ac or heater
I would check the fuse box if you haven't already. Replace any blown fuses. See if that fixes it. If it continues to blow... or if there are no fuses blown, you may have a blower motor that needs replacing.
Here is a good video of how to replace. https://www.youtube.com/watch?v=LoX89ZvK03Q
Jul 11, 2014 | 2006 Dodge Caravan
Fuse keeps blowing, tech replaced a 'faulty' battery but it continued. Tech then fixed a 'short in th wiring and still the fuse keeps blowing. Not sure if this is a glitch or an actual problem with just my...
What fuse keeps blowing (drive or hyd HEAVY FUSES or light fuses probs for invertor controller LIGHT FUSES), low batteries or running on discharged batteries for a period of time can blow the fuses. Have the motors been tested? Is the drive an AC and hyd a DC?
Sep 20, 2013 | Crown Walkie Pallet Truck Electric 6000 lb
American Standard AC has started blowing fuses about 1x/2days - any ideas why & is it safe to just keep replacing the fuse?
Hello, the low voltage fuse will blow if the thermostat wires are shorting togethur or ground, or if the contactor coil on the outside unit is shorting to ground.
Jul 11, 2012 | American Standard Heating & Cooling
I have a whirlpool central air conditioning and the condenser stoped working. what could I expect it to be?
When you say the 'condenser' stopped running - I'm 'assuming' you are talking about the outside unit, and I'm also 'assuming' that when you say it stopped running you mean 'nothing' runs on the outside unit - fan motor OR compressor. The fan motor will drown out the compressor running noise which is a 'low rumbling' sound - often not heard by the layman because of the noise the fan motor puts out.
Assuming you are talking about the outside unit and 'nothing' is running either fan motor or compressor then you might be 'in luck.' Because the most likely reason for the outside unit to be totally off will be a 'blown fuse' or a 'tripped breaker.' The good news is that in 'hot weather,' especially the kind of hot weather that has been present this summer (especially in the south) - blowing a fuse or tripping a breaker is not necessarily an expensive repair.
Indeed, it's not uncommon for a AC unit to blow a fuse (or trip a breaker) on occasion, although it must be noted that doing so is also is sign on something seriously wrong with your AC, i.e. a fan motor breaking down electrically or even a Compressor, both being expensive items to replace.
But, as I said, it's not uncommon for a fuse to blow once in awhile.
I would check my fuses (and breaker) and see if this is what has happened.
If you have fuses (usually located outside close to the condenser) and have no way to check them (you check them with a ohm meter looking for continuity) - then just 'replace' them with new ones. Note: always put 'time delay/dual element' fuses back in - even if the ones that are in there now are 'one time' fuses. 'Time delay' fuses do just what they say they will do - (they hold for just a second or two during that initial start up (of the compressor) without blowing).
If a blown fuse/tripped breaker is your problem then "most" of the time the AC will run ok and you will not have any more problems.
However, if after replacing the fuses and turning the AC back on - the fuse(s) blows instantly, or a short period thereafter (say a few minutes or an hour) then you probably have a problem that is causing it - i.e. the fan motor or compressor is going bad.
Note: one thing that you can fix that might be causing the fuse to blow is a dirty condenser. So, check the condenser coil (think of it like a car's radiator). It 'must' be clean to run properly and when it gets 'really dirty and clogged with dirt it will cause high head pressure and can cause the unit to blow fuses and trip breakers.
Good Luck!
Aug 10, 2011 | Whirlpool Heating & Cooling
I have a Eaton-Cuttler-Hammer 60 Amp fusible Pullout Disconnect for my house AC unit. When the weather gets warm and the AC runs alot, one, or both, of the fuses blows. The plastic panal inside the metal...
Does not matter which way the fuses go....
The contacts are bad and will cause the fuses to blow sooner because they are heating up...
It will not cause a fire, but you should have the disconnect replaced or you will have continuous problems...
heatman101
Jul 10, 2011 | Heating & Cooling
The inside unit on my Bryant is working. The fan is on. However the outside unit is not running. I changed fuses and it worked for approxmately 20 minutes then stopped again. Any suggestions?
I would think that when you changed the fuses you 'cured' the problem - which was a blown fuse(s) - but now you have the same problem again - a bad fuse(s).
To test this - you could replace the fuses again - but first - I would make sure that the fuses you are using are 'time-delay' fuses. It should say on the fuse itself 'time-delay' or 'dual-delay' or something like that.
If you're using fuses that are not 'time-delay' your problem could be solved as easy as buying some 'time-delay' fuses.
However, -- fuses blowing -- are usually caused by electrical motors - i.e. compressor/fan motors - breaking down 'electrically' - and heating up and causing the amp draw to increase past the point of the fuses, i.e. a 40 amp fuse will blow when the AC starts to exceeds that rating.
One "longshot possibility" - is - if the condenser is 'really dirty' - it will cause the compressor to run hot and possibly cause the fuses to blow. I would make sure 'all power' including the inside thermostat is "off" - and then 'wash out' the condenser (the coil in the outside unit) real good with a water hose.
Of course another possibility is that you have a loose electrical connection(s) somewhere in the AC. If you're inclined to - you can again - make sure all power is off - and poke around in your AC looking for loose wire connections. Just be sure 'all power' is off before you do this.
If you are using 'time-delay' fuses and your condenser is 'clean' and you can't find any 'loose connections' - and you continue to have the same problem (blowing fuses) - I would suggest calling a Service Tech.
Note: never replace a fuse with a bigger fuse, i.e. if the fuses in your unit are 40 amp - 'do not' put in 50 amps.
It is possible that the fuse(s) you are using are not the 'right size' but that would have to be determined by a Service Tech and actually - is not a strong possibility, although certaintly possible.
hope this helps
Aug 14, 2010 | Bryant Heating & Cooling
Blown fuse
Continued replacement of fuses without fixing the reason for them blowing MAY be doing additional damage to components in the unit.
It needs to go to a repair shop. It is likely there is damage in the power supply section or that of the power amplifier section.
Feb 28, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
Ac fuse blowing, high suction pressure
Were the fuses blowing before you started charging the unit?
It sounds like you are overcharging it.
Apr 26, 2009 | Heating & Cooling
Problem with my Airtron Thermostat
Two things, first go up to the heater and check the fuse inside the heater, looks like a car fuse. If that is not popped, then go outside to your AC unit and pull out the emergency disconnect. Check those fuses with a multimeter. IF you do not get anything replace those fuses, It has nothing at all to do with your thermostat.
Feb 09, 2009 | Honeywell Programmable Thermostat Heater
Dometic Rooftop RV Air Conditioner Logo
176 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
