Question about Pride Jazzy Select 6 Indoor Power Wheelchair
When charging my jazzy, do I unplug any plugs that controls my jazzy, or leave all plugged in? the reaon ask, green light will not come on the charger, which is onboard charger, unless I unplug controller plug, is this the right way? J R
  • 692 Answers
No JJR all the plugs need to remain plugged in. On the Pride chairs the light on the charger will only come on green when the batteries are fully charged. When you unplug the controller the charger thinks the batteries are fully charged and the light comes on. Now the problem is the batteries. If they are old or you have a bad battery then the charger never senses a full charge so no green light. Hope this helps
Posted on Aug 28, 2010
When plugged into charger both lights show green but chair not fully charged
First measure the voltage of the batteries at the charging socket of the joystick.
Sep 28, 2014 | Pride Jazzy Select Elite
I am new at this i plug in c harger and only powre light comes on, is it charging or is the chatge light supposed to come on?and how long does it need to charge a jazzy select?
If your charger has a red and a green led on it when the green led lights the battery is charged. If you use it a lot during the day it may take 8 to 10 hrs or more to fully charge the batteries
Jan 11, 2014 | Pride Jazzy Select 6 Indoor Power...
The light is green on charger but the controls will not light up unless it is plugged in
When the charger light stays green when you plug it in it means the charger is not actually charging. Either the batteries are bad and will not take a charge anymore or the charger is not operating correctly. It sounds more like a battery issue. The battery voltage needs to be measured on each battery with a volt meter. If the voltage is less than 10 volts on either battery they both will need to be replaced.
Sep 26, 2013 | Electric Jazzy 1115 Power Wheelchair
My battery charger for my Jazzy 600 does not light up or get warm when I plug it in. The chair has not been used for months.
I tried to charge my jazzy. The charge light (red) remained on for several hours. Finally I moved the wire slightly the charge light turned green than faded to red. What is my problem? Your solution would be greatly appreciated.
Jun 04, 2012 | Pride Jazzy Select 6 Indoor Power...
Replaced batteries in Jazzy 600 but they will not charge up.
doug then you could have received a bad battery or you have a charger problem or a charger circuit problem. If the chair comes on then the wiring is ok. when you plug the charger in do you have a green light and a yellow light on the charger? (when fully charged the light goes from yellow to green indicating full charge) If when you plug the charger in and you have a red and green light then there is a problem with the charging citcuit. I would contact your provider where you got the chair to have them check it out for you Hope this helps
Feb 19, 2011 | Pride New Jazzy 600 Power Wheelchair by...
How do you charge the Jazzy 600 powerchair?
With the battery charger That was easy wasn't it? No, take the off board charger plug it into the charger port located under the front of the joystick and then plug it into the wall outlet and let er rip overnight The yellow light on the charger should turn green indicating a full charge disconnect from the wall and then unplug from the joystick and you should be all set Hope this helps
Feb 13, 2011 | Pride New Jazzy 600 Power Wheelchair by...
I have a 1992 jazzy 1113 ats wheelchair and i accidently locked it the other problem is that the only way i can get the controller on is to plug it into the onboard charger and then a green light and a red...
Aimeelynn I'm e-mailing you the unlock procedure for a VSI controller. If thats not what you have you can e-mail me back the type of controller you have. I will also try to answer the other questions you have
Nov 07, 2010 | Pride Jazzy 1113 ATS Indoor Power...
When turning power it makes a clicking sound but does not power up. battery charger has a red and green light on. When plugged in and turned on it flashes 8 times. I checked the power control connection,...
The chair will not move if the charger is plugged in. The flashes are normal with the charger plugged into the chair. The lights on the charger mean that the batteries have been fully charged. Red and yellow lights mean charging. After you unplug the charger from the chair (if off-baord charger, turn charger off or unplug from the wall) then unplug from joystick. after plug is removed from joystick press the on button and all the battery lights should be lit and when you move the joystick forward you will hear the electric bake release and the chair should move forward etc Hope this helps
Aug 10, 2010 | Pride Jazzy Select 6 Indoor Power...
How do you reset the dc charger on a jazzy 14xl the batteries have been replaced? thanks
Chargers generally do not need to be reset. But in some cases if you may want it to start a Bulk charge.
If the charger is plugged in to the mains and ON, Then switch OFF and leave unplugged for 2 - 5mins.
Meanwhile Switch Jazzy ON and try and put some load on the batteries by taking it for a short but power consuming trip usually by going up hill.
Then plug charger in and switch on and the charger should initiate a full charge sequence.
Aug 06, 2009 | Pride Jazzy 1103 Ultra Standard Power...
Pride Jazzy Select 6 Indoor Power Wheelchair Logo
277 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
