Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
I've got an oil leak coming from the from of the engine near the exhaust manifold but only when the engine is running
  • 15,935 Answers
Thanks for your question!
This indicates a blown piston ring, or scored block.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Aug 26, 2010
Testimonial: "not what i wanted to hear but it's right "
I have gas leaking from my exhaust manifold On my yamaha ttr 90
How is the bike running? If you have gas leaking from the exhaust manifold I would think you have other things going on for that gas not to be burned up in the cylinder.
Is the gas coming from another source? for instance if it is leaking onto the engine, is it running down and around the engine but you only see it coming off the exhaust manifold? Gas getting burned off the engine when it is running?
May 06, 2014 | Motorcycles
New radiator still losing antifreeze
You could have a leaking water pump or blown head gasket
Apr 20, 2014 | 2002 Dodge Caravan
Loss of engine power, loud whistling noise
Exhaust manifold leak? That's not common. You talking about the VVT near the manifold at the top of engine above the power steering pump? Yes indeed, AC Delco is the only one our engines love. 41-103. Obviously you have P0304, what other codes?
Mar 16, 2017 | 2002 Chevrolet TrailBlazer
What cause my 2000 lexus es 300 exhaust manifold to get hot
The exhaust manifold is going to get hot, this is where the engines exhaust flows through. these tempertures reach high temps,
If the manifold is glowing hot then theres a problem.
Sometimes people say the manifolds are getting to hot because they see them smoking. The reason on most of these cases is due to a leak, aleak from a bad gasket like a valve cover gasket. Engine oil leaks down on to the exhaust manifold causing smoke. make sure there are no leaks .
A few reasons that would cause exhaust manifold to heat up more than normal would be a engine thats running rich, this may be due to a leaking injector or a poor running engine. Another reason may be that you have a plugged cat. converter.
The Exhaust manifolds can reach about 600 degrees, the last thing is people hear the metal expand or contract and think there are getting to hot , this is normal.
Please let me know if there is something else i can help you with. thank you and have a good day.
Mar 18, 2012 | 1993 Lexus Ls 400
Exhaust makes a loud tick when first started
usually an exhaust leak, at exhaust manifold to head, broken stud maybe. Use a piece of hose to your ear and listen at manifold.
Dec 06, 2010 | 2002 Ford Mustang
My car was running great. i ran over something off road that made the exaust leak near the motor. i continued to drive it . then it began to run low in water and if i didnt keep a close eye on it, it would...
Exhaust and coolant problems are two separate things. It's possible the donut that connects your exhaust manifold to the pipe came loose or the exhaust manifold or pipe has a hole from rust. You obviously still have a coolant leak somewhere. Start the engine and look under the car to see if you can see coolant dripping. It's either coming from one of your hoses, thermostat, water pump or coolant lines that run from your radiator to your transmission (if you have an automatic). There's a good chances are if it's still leaking the new water pump may not have been installed correctly. Also check your oil to make sure it's not milky white. That means your oil is mixing with the coolant from a blown head gasket. That can happen if the engine overheats severely. Head gasket repair is very expensive.
Jul 12, 2009 | Geo Tracker Cars & Trucks
Smoke comes from around engine
Probably a vavle cover gasket leak, small but enought to produce oil, in or on the surface of the motor doesnt take much to a lil smoke from aa hot engine...it could be collectiing in the canals ontop of the motor where the vlave covers sit on the head? or a head gasket problem....inspect it well after you run the car for a lil while, b4 it starts to smoke
May 18, 2009 | 1986 Oldsmobile Cutlass Supreme
93 toyota carolla engine clanking
Hi metel,
open your bonnet, look under the main engine block (the side which is facing you)
see where the exhaust connects to the engine, in between the exhust pipe and the engine there is the
exhaust manifold.
This might of come loose.
Jul 07, 2008 | 1993 Toyota Corolla
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
102 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
