Question about Nikon N75 with 28-105 lens 35mm Film Camera
Cannot get Error to go away
I have changed the battery, tried to load new film, nothing will advance, nothing will take. I've followed trouble shooting in the manual, but nothing works....help, there's no camera repair shop in my town.
  • Anonymous Sep 12, 2008
    ditto ,,my problem to the tee even the small town
  • Anonymous Mar 31, 2014
    Cannot view pictures and cannot select any menu or shooting options. Camera comes on, pictures appear to be taking, but nothing else seems to work. Have taken out battery and reinserted, but nothing changes
    Problem Solver:
  • 18 Answers
If it's a D lens or similar, check that the lens is set to its minumum aperture (and locked) - ERR normally means that the lens is not at its minimum aperture.
If your lens is a G lens, then the camera is probably faulty.
Posted on Apr 13, 2009
Film-advance warning won't go away on a RB67 Pro SD 120 film back?
Mamiya RB67 Pro SD that is new to me. loaded the film correctly took the first shot. But, the film won't advance. What am I doing wrong?
Feb 18, 2012 | Mamiya RB67 Pro SD Medium Format Camera
I've got Nikon F65. I cannot load film. The motor which load up the film doesn't move at all. Please help!
I don't know this model but you can try this.Drop the film canister in and pull the film strip out and place on the film advance sprocket.Rotate the sprocket by hand/thumb until film is seated (1 turn). If the auto feed is working you will be OK. 2 other things ,1 of course load film in dark area, 2 check the batteries on the camera first, if they are week your film advance wont work ,Good Luck.
Jul 29, 2011 | Nikon Photography
I have an old Nikon FG 35mm Camera that I haven't used for a long time. It worked fine when I put it away, however now after loading new batteries and film, I can't ****/reopen the shutter, film doesn't...
Were the old batteries left in when you stored it? Alkaline cells can leak and cause corrosion, no matter what anyone says. A coating of metal salts on the battery contacts could be the problem. I hesitate to suggest that you may have put the cells in the wrong way up, or forgotten where the on/off switch is, but these will certainly stop the cameras working.
Nov 18, 2010 | Nikon F3 35mm Film Camera
I just bought new Lomo Fisheye2 camera. I read the instruction first before i will do anything to my camera. Once i read everything, i just follow the instruction step by step. Putting AA battery and...
If your film was TOTALLY blank then it's been bleached due to a processing error. By totally blank, I mean that there are no frame numbers or other film markings on your blank film. Otherwise, you simply have an unexposed film.
First, operate the camera with the camera back open, hold the camera up to a bright light and operate the camera as you look into the back of the lens. If you see a brief bit of light coming through as you operate the shutter then the shutter is admitting light into the camera and so you should have got some kind of an image unless you failed to correctly load the film (very common).
Unfortunately, there's no way to tell unless you try another roll of film. Once the film is loaded, turn the rewind crank gently to take up slack film and take a few pictures; each time you advance the film the rewind crank should turn a little. If it doesn't then the film has not been correctly loaded as the film leader has not engaged onto the take-up spool. If so, open the camera and re-engage the film. If it clearly has engaged, then the take-up spool is failing to rotate when the film is advanced: try taking a few shots and winding on the film with the back open. If the film is not advancing then you have a faulty Lomo. This is extremely common as it is a plastic toy camera with atrocious build quality and materials and is the FishEye is only designed for paltry ten rolls of film lifespan.
A final check for film which has not advanced through the camera is if the rewind is extremely short when the film has finished.
Aug 11, 2010 | Lomo Fisheye 35mm Film Camera
I have a 35mm nikon camera. I've changed the batteries but the film won't load. how can i load the film?
Here is what to look at: Custom Function number 8, "Auto film load when back is closed", default setting is 1 disabled on 0 it is enabled. If you have the manual for the F80 (same as N80) look on page 21 and page 72 and 73.If that is not the issue check the following: With the new batteries does the camera turn on, Can you focus, does the LCD light up? All that will let you know if you are getting power to the camera. If the answer is yes then the film should load so now check the inside of the camera back. Does it have the pressure are and roller next to the hinge. If that is missing then when you pull the film to the red dot, close the camera back there is nothing to put pressure on the film for it to load.
Aug 06, 2010 | Nikon F80 35mm Film Camera
Film is stuck in kodak advantix tried a new battery and nothing happens - camera doee nothing
APS cameras are very rarely seen these days because the film loading and advance mechanism was poorly designed and engineered from the start.
Your fault is very common and given that the camera will be irreparable anyway (no spares, plus the small problem that the camera was never designed to be repaired anyway) then you need to decide whether to just chuck it away or whether to break open the camera in total darkness and manually rewind the film back into the cassette for developing.
May 12, 2010 | Nikon N75 35mm SLR Camera
Can't get my camera to advance the film. I put new batteries in but still nothing Is there a particular type of battery I should be using for it??
Hi Susanabbott2, As long as you are using AAA batteries, unless you have the holder for AA batteries it should advance the film. Things to look at: With the batteries in camera turned on do you see the red display in the view finder, if not there is an electrical issue, if you do see it do the following. Open the camera back make sure the leader is pulled to the red marker on the lower right. On the camera back door is there the chrome springy thingy with the little roller? If not then as you close the camera back there is nothing to place tension on the film so that the sprockets can grab the film.
May 06, 2010 | Nikon N2000 35mm SLR Camera
Screen is black and film won't load
If it's a 35mm film camera and you see nothing through the viewfinder, then as long as the lens cap has been removed, your camera has a locked up mirror.
You don't give any clues which exact model you have, but if it's one of the later electronic autofocus models with automatic film advance then the additional detail that the film isn't loading confirms that your camera simply has no power. Replace the batteries and all should be well.
If your camera does not have automatic film advance then you still almost certainly have flat batteries and just need to learn how to correctly load and wind the film.
Feb 28, 2010 | Pentax Photography
Film won't adanvce
Needs new batteries, or the film isn't loaded properly. Check the battery area for rust too and clean the contacts gently with a pencil eraser.
Sep 12, 2007 | Minolta Maxxum HTsi Plus 35mm SLR Camera
Nikon N75 with 28-105 lens 35mm Film Camera Logo
101 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Nikon Photography Expert? Answer questions, earn points and help others
