Question about Dewalt 7.2-18.0 Volt One Hour Charger
Old batteries started not to hold a charge very long. I purchase 2 new batterys and still have the same problem. NOTE- i WAS USING MY TOOLS outside in 100 plus degree heat for weeks.
  • 90 Answers
Does the charger check out? use a volt ohm meter to check the chargers output. when you charge all four batteries us the meter to check the batteries charge. this should give you an idea where the problem is.
Posted on Sep 02, 2010
We have a pride jazzy 1143 select power chair. we have had problems with the batteries going bad. I purchased a new set of batteries last December. in June they would not hold a charge and I purchased a...
charger is no good or is not the correct charger for that chair suggestion have a dealer tech replace a original charger in chair,it should have a 3 yr warranty anyways
Oct 22, 2013 | Pride Jazzy 1103 Ultra Standard Power...
Acer aspire 6920 11.1 v battery work but 14.8 v wont charge why is this
Check model numbers, I had this problem with apple, to of the same laptops two differnt batteries
Apr 03, 2017 | Acer Aspire 6920 Notebook PC
3 month old new phone. samsung tocco lite. battery problem
1) faulty battery - you'd need to get a replacement from the manufacturer (should be free if still under warranty)
2) when you initially charged the battery after purchasing, if you used it at all before it was completely charged it won't hold a charge.
3) if you live or travel in mountain area, phones lose battery power quicker due to an increase in elevation and distance from nearest tower.
4) if phone has been exposed to moisture or direct sunlight for an extended amount of time, it can damage the phone's ability to hold a charge.
honestly, your best bet is to replace the battery & allow it to charge for 24 hours in "off mode". if the problem persists, then send it in to be repaired.
Mar 19, 2010 | Lands Phones
I have a Gateway MX6930. I purchased a new battery because the old one's life had shortened so much. The new one worked fine for a few days but now doesn't work at all. The battery charge light illuminates...
Yes you are right, a defective battery.
It's always recommended that you use manufacturers endorsed hardware because of this fact!!
Return the battery and get a new one. when you get the new battery don't charge it, just use it until its dead and then recharge it. It will then hold 100% charge.
Good luck
Jun 12, 2009 | Gateway 7330GZ Notebook
Will not hold charge
you need to change the battery...
May 14, 2009 | Samsung SCH-u340 Cellular Phone
Battery not running
Possible that whoever replaced your battery sent you the defective one back. Note the serial and model numbers on the battery, then request another one. When you receive the replacement, do a full recharge. Most new batteries come already half charged. Even in this state, take time to fully charge it (between 4 and 8 hours depending on the type and model). Then try running it on battery power. If the charge holds more than 2 hours on a new battery, youre good; less than an hour new, its defective. If after all of this still not resolved, request the company honor their warranty (usually a limited one year with purchase).
Mar 01, 2009 | Dell Inspiron Desktop with Intel Core 2...
New battery will not work vaio VGN-TX2HP
mAh denotes the amount of current the battery requires for its charging....
Thus.. the battery works out ur system but it will not charge.. ubetter replace ur new battery or get ur money back... the VAIO is not designed for so much adaptability....
Jan 18, 2009 | Computers & Internet
I purchased a Phillips CD445 cordless phone from Walmart in Brockville Ontario on April 4/2008. Niether set will hold a charge for no longer than 4 hours. I took the phones back to Walmart and they...
it is possible to send it a request(email or call )before u have to specify very clear about the problem otherwise try first to charge fully and discharge it 2/3 times (u also have the manufacturers/products guarantee on some parts outside the guarantee teh product is buyed)
Oct 22, 2008 | Lands Phones
Dvd battery
Hello sara_lou,
I have 2 suggestions for you:
1) Look into purchasing an external rechargeable battery pack for PDVD units (available at Best Buy). It is an external pack that will connect to the players AC port.
2) Prepare for surgery! You will need 6 rechargeable AA batteries, a soldering iron, super glue, and patience.
You'll need to open the battery case and look at the batteries within. Note the direction and polarity of all the batteries and how they are wired/soldered together. You will need to replace all these batteries with the new ones you have purchased. Wire together the new batteries in the exact same order and polarity as the old dead ones. Remove the old ones and replace with the new ones. Solder in where necessary and be sure not to bridge any contacts. Put the case back together with a little super glue on the seam. Replace into the PDVD player when the battery case is dry (or else you may permanently mount the battery case into the player) and set to recharge using the AC pack. if everythign was wired correctly, you should have a charged battery pack in about 1 hour (since most rechargeable batteries come with 3/4 charge in them).
While I don't recomend this second solution, it is plausable for the hobbiest electrician or DIY-er.
Best of luck to you!
Jul 20, 2008 | Insignia IS-PDVD10 Portable DVD Player
My makita 18v 2.0 battery won't keep a charge
How old is the battery?
They have a service life and require replacing after they no longer hold a charge. This could be 2 years or 8 years depending on how often it is used and how regularly it is charged etc.
If it is a new battery, then take it back as it could be defective.
Possibly could also be the charger but you could verify that by charging a different battery and seeing if it charges that second battery ok, or not.
Jul 04, 2008 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Dewalt 7.2-18.0 Volt One Hour Charger Logo
65 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
