Question about GE Monogram ZDI15C Automatic Icemaker
I hava a GE Monogram ZDI15CBBJ ice machine. It is pluged in but nothing happens, no lights or anything. Outlet is hot.
SOURCE: ge monogram zd115c automatic icemaker not making ice
Unfortunately, this has been a regular problem with mine for 6 years.  It started within the first week of installation.  I suggest calling GE and keeping track of when you called, who you spoke to, etc.  Every single part has been replaced at lest once and I am still without reliable ice.  I have been asking or a replacement since day one.  GE is not good on the customer service end of things.
Posted on Sep 15, 2008
aborcass
  • 2651 Answers
SOURCE: how to unlock control lock on ge monogram side by side
shoud be amatter of pressing abutton and holding in for 3-5 secs to unlock. look closely at the control panel it should indicate which button(s)
Posted on Jan 25, 2009
Sea Breeze
  • 4654 Answers
SOURCE: GE Monogram Ice Maker ZDI15 makes an ice sheet but does not drop or melt the sheet into cubes.
Below is a couple og links. One is for the user manual and the other is for parts should. Sounds to me the cutting grid is not getting hot and cutting the ice into cubes. PDF below, click link
http://imgs.ebuild.com/xCat/ebuildWebB/15?ObjectID=1105&Variant=Original
For parts or free answers go to this link and enter your model number into the search feature. Model ZD115C That will take you to a page with pictures and part numbers. The home page you may call or email for answeres. I did see a control board and for some reason the cutter is not heating this will cause the problem. Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Posted on Apr 27, 2009
SOURCE: GE Monogram Ice Maker makes ice, unit doesn't cool enough
This model Icemaker makes ice by flowing water across a freeze plate. It is located in the top of the unit behind the white cover directly below the ON/OFF/CLEAN switches. After freezing a sheet of ice it releases and slides to the cutting grid. It then drops into the ice bin and begins to melt and the whole process starts over again. The level of ice in the bin is controlled by the high level sensor on the right side of the ice bin. It is a whit tube with two wires coming out of the top. Without this sensor it can overrun the bin capacity. Bottom line this unit does not freeze ice, it only holds it like cooler does.
Posted on Jun 04, 2009
SOURCE: Ice build up bottom of freezer and water on floor GE Monogram
I had the same problem. The drain tube is located below the pan below the fins at the rear of your freezer. The drain tube has a trap (s-shaped curve) to prevent air flow out of the freezer. The problem is that water gets in this tube and freezes. I took the sheet metal cover off the back, got a turkey baster and flexible tube, and continuously flushed hot water (after the freezer had been turned off around an hour to thaw). Eventually the plug gave way.
Posted on Jul 16, 2009
Cutter grid is not getting hot
I need you to look around your ice maker for a package containing a wiring diagram. I have information related to the Whirlpool 15 inch and 18 inch ice makers but for some reason GE did not publish the repair manual for your model. I want you to check the voltage going into the WR62X10015 Transformer
You should be getting at least 120 volts ac. Then test the voltage coming out of the transformer. What is the voltage coming out of the
WR62X10015 Transformer? Check the control board area for a fuse that goes to the
Check for loose connections going to the grid or broken wires on the grid itself. WR29X10073 Cutting Grid Assembly
Here is a link to the GE Monogram Technical Data
The Whirlpool and the GE Monogram Ice Machines are basically the same thing other than part numbers so I am linking to the Click Here=> Whirlpool 15 inch and 18 inch Ice Machine Service Manual I will be here to answer your questions so please let me know should you have questions, More information can be found
HERE Thanks Sea Breeze
Apr 07, 2013 | GE Monogram ZDI15C Automatic Icemaker
Ge monogram zdic150 ice maker cutting grid does not get hot enough to make cubes
If the cutting grid is only getting warm this would indicate a loose wire, a dirty grid or a defective grid transformer. As much as these grids cost it would pay to search for the problem that is causing this. The transformer is near the control board=> WR62X10015 Transformer
Other source for a transformer=> WR62X10015 Transformer If you would like my help repairing the Ice Machine please let me know, Thanks Sea Breeze
Mar 08, 2013 | GE Monogram ZDI15C Automatic Icemaker
GE Monogram bottom freezer leaking water from left side onto the freezer floor and onto hardwood floor of the kitchen . Already tried totally defrosting freezer and that did not solve problem. Help!!
ck the drain in the back of freezer . it may be pluged and when it goes into defrost cycle you get about a cup of water on the floor . if there ice on bottom of freezer then the drain is iced over . some models require a drain heater to prevent this . mm hope this helps ..
Oct 14, 2010 | GE Monogram ZICS360NR Bottom Freezer...
GE ice maker is getting hot
You need to remove the ice maker the function that heats the lower element should last only a few seconds so I believe the ice maker will need to be rebuilt or replaced. Sea Breeze
Jul 24, 2009 | GE Monogram ZDI15C Automatic Icemaker
My ice maker is not despensing ice, but water works. It is a GE Monogram refridg. Water works, but when you change to ice, nothing happens. when it was acting up, all it would do is dispense crushed ice,...
Could you look on the bottom frame of your GE Monogram around the door frame and behind the fresh food section door seal for the model number? The problem most likely is in that control panel that you use to switch from crushed to cubes. Let me know, Sea Breeze
Jul 22, 2009 | Refrigerators
Ge Monogram built in side by side. Water and Ice
You can do it yourself if you feel comfortable, Here is a service manual for you that should help out. 31 9091 GE Monogram Side By Side Refrigerator pdf
Jun 10, 2017 | GE Profile PSW26P Stainless Steel Side by...
Ge monogram refrigerator is shooting water/ice out.
The same thing has happened to us with the ice. We just unplugged the ice maker for a few seconds then plugged back in. that seemed to work. hasnt happened in a while.
Nov 27, 2008 | GE Monogram ZISS420NRSS 42" Built-In...
GE Monogram (freestanding) Ice Maker
ice maker first should supply water to ice tray. then the freezer will do it's freezing then heater and ejector will finnish the job.sounds may be that of the ejector trying to dump the ice.the heater may not be heating. you ould put a knife undre the tray and feel the blade if it's hot or not. please do not put your hands under tray while in operation.
Aug 13, 2008 | GE Monogram ZISS480DRSS Stainless Steel
GE Monogram ZDI15C Automatic Icemaker Logo
90 people viewed this question
Top GE Kitchen Appliances - Others Experts
John Tripp
John Tripp
Sal DeAngelo
christian nielsen
Are you a GE Kitchen Appliances - Other Expert? Answer questions, earn points and help others
