Question about Kenmore 75503 Stainless Steel Dual Fuel (Electric and Gas) Kitchen Range
My dual oven Kenmore elite range has a door problem. The door is so heavy that the hinges are bending outward and is getting worse. I called when this first started happening and was told to stop stepping on the door??? I have never stepped on the door and I believe the metal is too thin to hold the door adequately. Any thoughts on this or same problems.
  • 15,935 Answers
It is very thin - however slamming it down has the same effect.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2010
I continue to get code F11 on my Kenmore Elite Gas Range Oven and therefore, I am unable to unlock / open my oven door. I have pressed and held down the STOP button as well as the oven light button.
Your model number should be much longer than 790 30 Open drawers and doors to look for the whole model number around the frame.
With the whole model number you can get more information at Sears Parts Direct. There are parts diagrams and user manuals and you can order parts.
http://www.searspartsdirect.com/
This site gives instructions for repairing F11 and recommends checking the temperature probe and tells how to do it.
How to fix Frigidaire oven error code F10 F11 F30 F31 etc AskGene com
Sep 10, 2014 | Kenmore ELITE 790 30 FREESTANDING DUAL...
Whirlpool oven door
Hi ShellBrokeIt,
Pivot the hinges outward, and GRop the door by both edges,  Feed the slots of the door onto the hinges and slide it on, Close the door and your done.
Oct 16, 2007 | Whirlpool GR478LXP Electric Kitchen Range
My viking oven door has literally fallen off the left hand side hinge - is this a diy FIX?
The door slides onto the two hinges and is held in place with two gravity operated latches. I'm not sure of the condition of your range but it sounds like the door was forced or lifted rapidly allowing the one side to release. The only solution I know of is to remove the other side and reinstall. The hinges have multiple locking positions so the next time you are cleaning your oven, open the door about 8 inches, find the small latches in the door hinge groove, and hold them upwards as you lift the door towards yourself.
The hinges should remain slightly opened. For installation, lower the door onto the hinge posts and pull it outwards slightly.
Oct 27, 2010 | Viking VDSC365-6B Dual Fuel (Electric and...
Hook up oven door on maytag gas range
You likely need to lock the hinge in open position to do it. Either there is a small lever on the hinge itself you need to flip when the hinge is in the open position or there is a hole in the hinge, where you need to insert a steel pin (you can use screws, but they bend somewhat ;)) to hold the hinge open
Mar 04, 2010 | Maytag MGR5875QDS Stainless Steel Dual...
Bosch HDS7282U oven door won't close properly.
I am a old bosch repairman and i know for a fact that the door can be fixed. tighten the hinges with 3-4 washer on both hinges. nyc can fix this problem . if your door is really bad then both hinges has to be changed. but sometimes the old hinges willdo the same after awhile.
Dec 20, 2009 | Bosch Evolution Pro-Style 700 HDS7282U...
Range door will not seal properly.
Place a hammer handle between the door and the frame at the hinges..
Push on the door, carefully.
This usually works to re-seat the door hinges.
Mar 08, 2009 | Kenmore Kitchen Ranges
Ovendoor not closing for tight seal...
You should feel the door pull closed when you as you lift it and get near the closed position.
There is some spring linkage associated with the hinge pins at the bottom sides of the oven.
I cannot find the oven you indicated, but I did find exploded views and parts list of the topic post oven on the SearsPartsDirect website.
Jan 28, 2009 | Kenmore 99123 Electric Kitchen Range
Kenmore oven model# 790.79383401 door not closing
Do the hinges come out with the door or does the door slip off the hinges? If the hinges are on the door then there is no adjustment if not there should be an adjustment but you may have to pull the range out to properly adjust if it is a built in range. Also check the door lock.
Jan 15, 2008 | Ovens
RE: f5 fault code; kdrp407hss
Solution!!! The hinges that Kitchen Aid uses are the problem. If the door is opened quickly & bottoms out, the steel in the hinge bends a little. So when you go to close the door it won't close all the way.... which causes problems with the latch , latch switch, oven cleaning, etc.
After taking apart the door several times I realized the hinge can be "fixed" without even removing the door. Follow the directions in the user manual for door removal... after inserting the little metal hinge stops (a drill bit or nail will work) Close the oven door till the stops won't allow it to close any further.....then gently but firmly, push forward. This will bend the hinge back to original shape. Remove the pins...Voila!!!
I wish kitchenaid used hardened steel or a thicker hinge....then this wouldn't happen.
Nov 11, 2007 | KitchenAid KDRP407HSS Dual Fuel (Electric...
Kenmore 75503 Stainless Steel Dual Fuel (Electric and Gas) Kitchen Range Logo
74 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
