Question about Estate ETW4400VQ Top Load Washer
All cycles work good, except the spin cycle. the motor makes a whurring sound, but the drum will not turn.
    Problem Solver:
  • 7 Answers
There are 2 possible problems. First one is the timer may be bad. The second one is there is a belt that makes the drum turn. This is not an easy replacement for a beginner. You may need to call in a repairman.
Posted on Aug 26, 2010
How to fix the spin cycle on my Whirlpool washer?
Usually Debra you have to replace the motor when this happens motor is weak and heating up cutting out to soon ..Hope this helps
Mar 02, 2015 | Whirlpool WFC7500VW Washer
Frigidaire front loading washing machine will not do final spin
If you cannot manually turn the tub when it is off, and not in use, then the motor and transmission is possibly seized. If you can turn it with no issue or noise, then the control is not communicating correctly to the unit.
Dec 28, 2012 | Frigidaire Washing Machines
It starts but then seems to just make a whurring noise and nothing else happens no rotars going round or anything? At first it seemed like it got stuck after the cycle but I have pressed re-set and now it...
The reason for the whurring sound is that the water pump is trying to empty the drum first before letting in the new water cycle, I would check your outlet water pipe for any obstruction first by blowing down the pipe to check to see if there's a blockage, with the machine off of course this is of course only a suggestion but I hope it helps eric
Nov 15, 2017 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
I have a maytag over capacity plus heavy duty 2 speed 10 cycle washer it fills with water fine you hear the motor kick in to girate but doesent spin or you put it on spin cycle it sounds like it is...
The motor is working, but the mechanism not engaged by the helix so the shaft can not move therefore no agitation or spinning. Motor is designed to turn 2 directions: clockwise and counterclockwise for agitation and spinning. Therefore there are 2 mechanisms to assist these tasks. The drain is control by a separate pump and it is still good also.
The tube has to be out to replace the helix for agitation and a part to engage with the spinning rotation to release the brake so the spinning function can work. These parts are cheap, but the the labor is not. Hope this can help
Jan 09, 2010 | Washing Machines
Doesn't spin freely, works for about half a cycle and stops spinning. won't turn back on or spin good until it cools for a few hours. then you might get another half cycle or so out of it.
open the dryer door and maunually spin the drum around. if it spins relatively easily, then it sounds like the drive motor is going bad. the windings open up and it stops. sounds like you need a new motor. it may be cheaper in the long run to get a new dryer
Oct 20, 2009 | Whirlpool Dryers
Washer won't spin
Check the washer motor. Make sure that the motor is getting correct voltage and is working and spinning when you turn it on. It sounds like the motor is bad. You can remove the back cover to get to the motor to check it out
Feb 13, 2009 | GE Spacemaker Washer and Dryer Electric...
WMA54 Hotpoint Aquarius drum does not turn during wash or spin
Start checking the lid switch, if this is stuck the machine wont start.
If the drum does not move at all, the motor, the motor control unit, the motor coupler, the control board may be faulty.
For more details you need to observe if machine is draining and pumping water inside during cycle, see: It doesn't spin
Jan 06, 2009 | Hotpoint WMA54 Front Load Washer
Won't spin or agitate
Sounds like a burning out motor to me...
Jul 26, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Everything is working except the spin cycle
Sounds like the spin coil/brake solenoid is burnt out or broken. This is a coil situated on the motor plate under the machine with a lever attatched to it. When the machine goes into spin cycle, this solenoid pulls the brake away from the outer drum to allow the drum and agitator to spin together. The shaft that goes into this coil should move in and out freely. If tight, replace spin coil/brake solenoid.
Oct 31, 2007 | GE WSKS2060WWH Top Load Washer
Spin cycle trouble
possibly a segment has raised on the motor armature or a faulty motor brush. pop off the belt and put it into a spin cycle to see if you still hear the noise- if so the fault is with the motor as the drum will be still. any scraping sounds in the drum may be a lost bra wire.
Jun 03, 2007 | Asko W640
Estate ETW4400VQ Top Load Washer Logo
Top Estate Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
