Question about Kenmore Elite Oasis 6808 Electric Dryer
Push power button on power turns on then press start and everything turns off
  • Kenmore Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair ? The dryer will not start
heatman101
Posted on Aug 29, 2010
I have 98 GMC suburban installed push button start keyless system it won't start????
You did something wrong on the installation, as to what that is I have no idea. Recheck all connections and the install instructions.
Jul 06, 2017 | GMC Cars & Trucks
Turnitoff
Generally you will turn the key counterclockwise to the lock position. This will shut off the vehicle. If you have a push button start try pushing the start button.
If you are referring to a dome light try pressing up un it or look for an on off switch. Radios can generally be turned off by Turing the volume knob counterclockwise, pushing the power button, or pressing a power button.
Hope that helps.
Nov 16, 2014 | Cars & Trucks
Start problem?
Let me briefly explain what happens when you turn n the key. All power is off in the off position with the possible exception of the brake light. When you turn on the key, you supply power from the battery to the electrical system. Typically, all systems are powered through a connection on the start solenoid. When key is on and the solenoid is in the off (or rest) position - all electrical works. When you energize the start solenoid, you need all the power you can get to run the starter - everything electrical turns off. After the start, you release the start button, everything electrical comes back on (solenoid returns to the rest position).
In your case, you say everything goes dead when you press the start button - this is as it should be - however, the mechanics of this system should deliver power to the starter - which evidently it is not. (A solenoid is nothing more than a electric powered heavy duty switch) It is possible your solenoid is worn out. There is heavy sparking/burning of the contacts every time you press the button. First thing to do is check voltage on the start side of the solenoid when you press the button. Voltage should be the same as on the hot side with the key on. Other possibilities - the wire from the solenoid is loose, damaged or disconnected, check both ends for tightness and cleanliness. There is that possibility there is a problem with your starter. Removal is not for the faint of heart though it is possible. There is also that possibility your engine is locked up and your starter can not turn it over because of that. If this is the case and you have a amp meter - you will see heavy draw on the starter wire. If you have a volt/ohm meter, you can so all the prelim checking.
I hope this helps you with your trouble. Good luck and thanks for using FixYa.com
Jul 29, 2013 | 1995 Suzuki VS 1400 Intruder
We pulled our stacked washer out from the wall to service the cold water hose filter on the back of the unit. when we pushed it back into it's location the washer won't start, won't fill...
I know you don't want to hear this, but either you did something to the hose filter or you didn't get it plugged back in correctly.
If you banged the water inlet valve in moving it back, it might be damaged.
Suggest you unplug everything and start over.
Sep 04, 2011 | Frigidaire FEX831F Top Load Stacked Washer...
The Zenith Digital TV Converter DTT900 needs reprogramming
1) While pressing & holding down the TV POWER button, press CHANNEL UP or CHANNEL DOWN repeatedly until your TV is turned on or off. 2) Release the TV POWER button when your TV is turned on or off. *Each press of the channel button sends a manufacturer code (1-45) to your TV, one after the other. Note: You may have to do this every time you change or remove the battery, as the remote will reset itself to the default code.
Nov 25, 2009 | Televison & Video
I had a wireless mouse attached to my laptop. I
Did the lovely doggy pull the pc off the table or anything???? Try This:
Press power button
keep pressing F8 until list is displayed
Select safe mode and uninstsll drivers for wireless stuff
While at it you can clean down your system
Press start press run enter %temp% and press return and delete everything
Again press start and run and type prefetch press return and delete all
Then press stsrt all programs accessories and system tools and select defrag (this can take a few hours to do)
It will be like a new machine provided it starts in safe mode
Hope this helps....Please let me no...
Nov 17, 2009 | Acer Aspire 3003LCi Notebook
Canon pixma IP2000 not starting
dear,
uninstall the software of your printer and reinstall it...hope it may work.
thanks.
Jun 16, 2009 | Canon PIXMA iP2000 InkJet Printer
Laptop (sony) will not turn on when button is pressed.
Just remove the battery from laptop and again fix it carefully.
Mar 12, 2009 | Sony Computers & Internet
Sony vaio will not turn on
sounds like the battery
see if you can have somebody that out like radio shack or best buy
Feb 07, 2009 | Sony Computers & Internet
Kenmore Elite Oasis 6808 Electric Dryer Logo
57 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
