I have a heat pump with the unit under the house. We have noticed our power bill has increased. After crawling under the house I notice the drip pan is full and not draining through the pipe. So I unclogged it and it drained fine, but my next issue is, why would the return duct have about 3 gallons of water sitting inside the pipe making it sag. So what can I and need to do to fix this. I have been covering the ducts to cover the leak that I found but this water in the pipe has me baffled. Please help. I'm a member on here for cars but this is scary
    President:
  • 1,515 Answers
Hi, this sounds as though you just have a backed up condensation line that you opened up the drain, and you say it drained fine. As far as the return air duct having water in it, it is connected to the return side of the evaporator coil and it just over flowed into the flex duct causing it to sag. I would take a small sharp knife or a 16 penny nail and just drain the water off. If you have a panel on this unit where the return duct attaches, try and remove it to see how or if the coil has dirt built up on it and check the pan and try and clean it out. I have seen this problem quite often, its not serious but will cause problems if the pan continues to plug off the condensate line and backing up into the duct.With the duct sagging, it will cause the system to work harder to pull air through the home back to the filter and through the evaporator coil to start its journey over again. This is why you have noticed the increase in your bill. This pan needs to be cleaned up so the condensation will continue to drain through its line and not back up into the return. This will solve your problem my friend. Nothing to be worried about, just drain off this water and flush out the pan and you will be fine. Keep me posted on this. I would like to know if you were able to excess the condensate pan OK. Keep me posted.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Posted on Aug 26, 2010
Testimonial: "Thanks for the info. Will keep you posted."
  • 1 more comment
  • Robert Horton
    Robert Horton Aug 26, 2010
    PS, make sure the air -handler has not dropped down some what in the rear where the return duct attaches, as this may be why its over flowing into the duct. I am sure its just a dirty condensate pan as I have had to clean many that have over flowed into the return duct above and below.
    Best to you.
    Shastalaker7
  • Chris Busby
    Chris Busby Aug 26, 2010
    The unit is under the home, and from what I see the unit sits fine. The pan was evenly full and was only draining what could get through the cracks. This is what I went to fix was the duct work and the return. These were never sealed off and losing air like crazy. I have no idea who did the work but it was sloppy. But anyways, I have one other question, after all this drains will I quit getting condensate on the windows, because I was thinking that the cool water inside this pipe was being transferred into a moisture causing the windows to condensate were we have vents. The system looks great other than I mentioned, it's about 3 years old. Do you have an idea of what it would cost to put in new duct work for 1800 sqft. Thanks for all your help.
  • Robert Horton
    Robert Horton Aug 27, 2010
    Hi, thank you for the awesome rating's!! Yes, with the pan full and the relative humidity will cause moisture/condensation to form on the windows inside. As long as the line is open and draining, this should clear up. I can give you the price and tell you about what we get out ducts for at cost and most all contractors will double that to the owner. The return and supply air ducts come in 25' sections at around $76 our cost for a 18" section of duct, so double this for the amount you would need. I would replace only the return and supply unless you are having other leaks in the smaller ducts. The best thing for you to do is find a contractor in your area that will send out at no charge to give a look at your conditions, space to work under the home and so on, and they will work up a bid for you. Yes, this return should be replaced. If you don't feel a lot of cool air under the home, you may get away with just replacing 1- 25' section on your home. It would be hard for me to give you an estimate without first taking a look at the system, but I just did a home that was 3,000s.q' just the return and supply which the total cost to the customer was $400. So check around and find someone that will come for free to give you a bid as we are out there. I wish you the best of luck,
    Shastalaker7
Water dripping from freezer
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor.
However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick.
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also.
Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer.
May 07, 2014 | Samsung RF4287HARS Stainless Steel French...
Where can I find a drip pan to put under my AC unit?
Did you look at the homedpo thay shod have one
Aug 14, 2012 | Heating & Cooling
My ac unit is now after 3 weeks of use dripping water inwards(even with a 1/4" slope of the unit to the outside) is my drip pan overflowing?
Yes, your drip pan is overflowing, because the drain hole near the back of the unit is clogged. There are 2 ways to address this problem.
1. Look out side the house, under the unit and search carefully for the drain hole or drain tube. If it's a hole, clear it using something like a pipe leaner. It it's a tube, use 2 pipe cleaners twisted horizontally together and carefully run it up into the tubing in a push/pull motion. This will help dislodge any clogs.
2. If you're feeling really lucky, turn the unit OFF and unplug it. Straighten out a wire coat hanger leaving a little hook on one end. Remove the front cover of the AC unit and slide the coat hanger under all the mechanical parts into the drip pan. Sweep it around carefully in the drip pan. all the way to the back of the unit. Be careful not to get the little hooked end caught on anything, by keeping it flat against the drip pan. Doing this, may dislodge any clogs.
And finally, if you're in a high humidity area, increasing the tilt to 1/2" may help improve the drainage.
Hope this helps you unclog the problem.
Jul 20, 2011 | Heating & Cooling
We have a one year old home and started to notice
do you have floor or ceiling vents, and does your house have concrete flooring or do you have a crawl space under depending on the answer because if you have a unit that is all outside then the duct may not be sealed
Jan 08, 2010 | Ruud UBHC Air Conditioner
PUMP WILL NOT STOP WHEN YOU PUT POWER ON . PUMP STARTS AS SOON AS YOU PUT THE POWER ON TO PICK A WASH PROGRAM EVEN BEFORE THE DOOR HAS BEEN CLOSED.
I have seen this on my unit. There was water in the drip pan under the dishwasher. Water in the drip pan comes from a leak. In my case, the water valve was getting so old that it was letting too much water into the unit when it was trying to fill. This cause the filling station to over flow into the drip pan.
A quick fix - I removed the water from the drip pan under the unit and I was able to turn down on the supply valve in the basement to limit how much water could come in. This allowed the unit to run without overflowing. I will replace the water valve soon.
Other possibilities, the float device used to detect too much water in the drip pan or too much water in the unit is stuck in the too full position. Or the pump out pump is stuck and not moving water.
Dec 17, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Excessive water dripping from Central A/C drian line
sounds like the overflow drain is picking up the water that means the main drain is clogged.you need to find the main drain pipe if lookin at the air handler in attic there should be 2 drains from unit one higher than other follow it and blow out drain they put the other overflow drain out the eve so if it stars leaking someone notices it and it doesnt damage cieling but it sound like it needs imediate attention befor it does go to the overflow pan and damage your cieling. i hope this helps and good luck
Sep 29, 2009 | Amana PTC153B35AJ Air Conditioner
Dripping water from pan or coils
If the a-coil is on the suction side of the blower, the drain line needs to be trapped. take enough hose to make a circle below the drain fitting and then into the drain. The blower causes a suction up the drain line if it is not trapped and will not let the water go out the hose.
Aug 03, 2009 | Coleman Heating & Cooling
2006 Chrysler T&C transmission leak
a bolt most likely vibrated loose and is letting transmission fluid leak out. try finding it and tighten it back up. or your dipstick housing is loose and the pressure is allowing fluid to leak out.
Jun 02, 2009 | 2006 Chrysler Town & Country
Heat pump cutting off and knocks out power to house.
Wow!.
Wires buzz where, What are the hooked into? On he heat pump? At the breaker Box?
I would have electric company check incoming pole lines & transformer. Was there a bad electrical storm in your area?
You may also have a bad Main breaker box, Is it out in the weather? Terminals may be corroded.
Pulling power from other breakers means you have a dead line or low voltage/amps on that line, Or a dead short That much power you should see welding & melting of wires.
Good Luck! Be very Careful. MSG me back let me know if i can help more.
Mar 11, 2009 | Goodman CLQ36AR49 Air Conditioner
Heating & Cooling Logo
80 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
