Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Washer will not empty water...must rest for 30 - 40 minutes then will empty and maybe fill up but has to rest again before emptying.
    Problem Solver:
  • 7 Answers
Chances are the pump is over heating and probably need to be replaced.
Posted on Aug 25, 2010
Servis easi logic 1000 is filling up then half emptying then turning off
Have you just moved the washer to it's present spot? if so maybe the drain hose is to low and the water is siphoning out. Something may also be wrong with the pressure switch.
Dec 29, 2014 | Washing Machines
Samsung Front Load washer stops in the rinse-spin cycle.
Many washer have two pumps in them. One circulates the water, the other is the drain pump. You may be hearing the circulating pump.
Sep 15, 2014 | Samsung WF328AAW Front Load Washer
Error code
H20 indicates incoming water supply problem.
Check that the water is fully turned on.
Check the inlet hose/s for kinks or restriction.
Make sure there is a good pressure of water to washer.
Please rate my solution.
Thankyou..
Jan 31, 2010 | Hotpoint Ultima WF860 Front Load Washer
Maytag Neptun will not agitate or spin
Change your timer. or timer sensor. behind your knobs
Feb 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
Ashing machine not emptying
check the drain pipe is not blocked, to empty the machine manualy get a bowl on the floor and lower the drain pipe into it and fill to stop water flow lift pipe up in air and lower to start draining again when empty if pipe not blocked i would suggest a new pump located under the drum and easy to fit
Feb 05, 2009 | Hotpoint WMA46 Front Load Washer
Wash times are outragious
Sounds like water pressure is very low, maybe due to clogged filter at the inlet. This would also account for containers not emptying. Need water flow to do this.
Jun 15, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Descaling
Remove the filter holder (portafilter).
The manual says to unscrew the nozzle from the filter holder coupling and wash with hot water.
Mix a liquid decalcifier with water in tank at a 1:1 ratio. DO NOT USE VINEGAR! It says to fill the water reservoir.
Run the cleaniing solution through the machine - pressing the coffee button, 1 cup at a time. During each interval let the decalcifier act for 10 or 15 minutes by turning off the machine by the main switch.
Carefully wash the tank and fill with fresh water and empty 2/3 of this by pressing the coffee button.
Now let the machine warm up and empty the rest of the reservoir by rotating the hot water/steam knob.
Screw the nozzle in the filter holder coupling again.
Jan 06, 2008 | Saeco Magic De Luxe Espresso Machine
The Washing Machine fills and then empties with not running a wash cycle
possible a pressure stat fault. some pressure stats have a too high water detector which turns on pump
Mar 27, 2007 | Zanussi F1245W Front Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
21 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
