Question about HP OfficeJet K80 All-In-One InkJet Printer
Transparent printer tape
Where would I find this transparent tape in the printer so I can clean it? Also how can I get to it to clean it?
Thanks,
Chuck I have the same problem as the other comments. My printer keeps indicating align cartridges which I have done numerous times. How do I clean or replace the transparent tape problem. Since the other messages I read are from February and it's now May I have a bad feeling about getting this fixed timely. Please prove me wrong.
  • HP Master
  • 19,396 Answers
I do not know if you are referring to transparent tape to be removed before replacing cartridge. If it is this there must be a strip of cellotape to be removed on the cartridges bottom, where the ink comes from.
If it is not this , please give more details on the problem, as we cannot see your other posts, about chuck and transparent tape.
Generally, if you keep getting a cartridge alignment or cartridge replacement warning it may be a problem with the cartridges. Each HP cartridge has a chip , if the cartridge is faulty or refilled you can get the message. Did you try any other cartridge set?
Posted on May 15, 2008
    Guru:
  • 1,894 Answers
After installing new cartridges did u do a hard reset?
    President:
  • 2,712 Answers
It should be on the carriage. You may have to remove the top and side covers to gain better access. The inks are water soluble, so just take a damp cloth and wipe along the carriage.
Hope that helps.
Posted on May 05, 2008
  • Swilin Sampson
    Swilin Sampson May 05, 2008
    Some times you can get alignment problems if you have used refilled cartridges. This is a dirty trick by some companies to ensure that you buy only genuine inks from them..
    If you are using refilled cartridges, try using original inks and see if this solves the problem
How to replace or install waste toner tank ?
Dear
The waste toner box may be taken for cleaning by pulling it from the left side of the toner carts. its a transparent box extract all waste toner (carefully do it as its very fine powder) try to make it transparent its wall. Fit it to the position where it was pulled.
Hope this may solve waste toner error massage.
Thanks.
Oct 28, 2014 | Samsung CLX-3185FW Wireless Multifunction...
Tip
Easy way to pull out a transparent tape
keep the transparent tape in the refridgerator for few minutes.and you would find that it was never that easy to pull out the tape....just try it out.
on Mar 07, 2010 | Office Equipment & Supplies
I have Samsung CLX 3175 laser printer. Am getting invalid toner message although parts are genuine
Well, eventually I worked it out: The "contacts" are four square fields to the left on on the backside of the cartridge. And it works instantly. (I read somewhere that it needs to be fully transparent tape. The 'blurry' tape leads electricity and doesn't work.)
Mar 13, 2012 | Samsung CLX-3175FW Multifunction Laser...
The transparent film was out of the location when I were change the ink. How do I put it back into the right location?
Hi! here is ... 1. Open your printer i.e. left and right spock. 2. Put your transparent belt between the Cartridge & back board. 3. Each corner there is a small rubble pin. 4. Put your transparent belt any one of the pin. 5. Now put the another one. 6. Remember that let them straight... thanks
Sep 05, 2011 | Canon PIXMA MP160 All-In-One InkJet...
It is coming up with error code6000
firstly dismantle the printer so you can clean the timing disk wich is located inside printer on leftsideway, also clean the plastic transparent tape wich is vissible when you open the ink cover.
Aug 30, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
My ps 1100 label maker prints only on black side of tape
This depends on the TAPE CARTRIDGE you have in your label printer. Apparenlty, you have a TRANSPARENT TAPE on it, and the printer prints in BLACK only.
Just replace the tape cartridge
Apr 01, 2010 | Brother P-Touch (PT1100SBVP) Label...
TRANSPARENT LABELS
yes you can do clear labels but they need a backing thats not clear so the printer can calibrate.
Jul 09, 2009 | Zebra 2746e Thermal Printer
Carriage jam
hii,
try to clean film stripe between the carriage(transparent plastic)
Nov 07, 2008 | HP PSC 1610 All-In-One InkJet Printer
Hope that helps.
May 01, 2008 | HP OfficeJet K80 All-In-One InkJet Printer
HP OfficeJet K80 All-In-One InkJet Printer Logo
48 people viewed this question
Seeker5211
Seeker5211
