Question about Frigidaire (FEB30S7D) Oven
Fault code f95, what is it? - Frigidaire (FEB30S7D) Oven
    Problem Solver:
  • 7 Answers
This is the explanation that Frigidaire gives. Press stop key. Turn off power for 30 seconds then turn power on. If the door lock motor never stops rotating, or if the F95 error comes back again, verify wiring of the motor. if wiring is good, replace the EOC. If the problem persists, replace the motor latch assembly.
Posted on Aug 26, 2010
Kenmore wall oven fault code f61 what does it mean when it says this fault code
Find the model number. See which oem manufacturer built it using the information at
Sears Kenmore Fault Codes AppliancePartsPros com
and then look up the code under that manufacturer.
Feb 17, 2017 | Kenmore Ovens
F09 fault on my oven,what is the problem and how can I fix it?
to some extent they are specific to a make, other are generic.
All the makes and codes are listed in the link. On a GE, it is the lock switch.
F9 Lock switch Check wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch.
Read more: http://www.appliancepartspros.com/repair-help/ge-fault-codes.html#GE Range / Stove / Oven Fault Codes#ixzz3ylwEPD9R
Appliance Fault Codes AppliancePartsPros com
Jan 30, 2016 | Ovens
What is F95 error code
Follow this link which explains how to fix the issue on your oven.
https://answers.yahoo.com/question/index?qid=20110813145633AASuRbi
Jan 02, 2016 | Ovens
Why won't it heat up? And what does error code 311 mean
rcr311w codes Washing Machines Questions & Answers ...
www.fixya.com > Forum > Tags > rcr311w codes
Zita http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3308-bosch-wae-range-washing-machine-fault-codes.html here is one link to error .
Sep 12, 2015 | Bosch HBL5450UC Electric Single Oven
Have a kenmore stove, and a code of F93 is coming up. What is the solution?
F90
F91
F92
F93
F94
F95
If lock motor runs:
1. Test continuity of wiring between EOC and lock switch on lock motor assy. Repair if needed.
2. Advance motor until cam depresses the plunger on lock motor switch. Test continuity of switch contacts. If
switch is open replace lock motor assy.
3. If motor runs and switch contacts and wiring harness test good, replace the EOC.
If lock motor does not run:
1. Test continuity of lock motor windings. Replace lock motor assembly if windings are open.
2. Test lock motor operation by using a test cord to apply voltage. If motor does not operate replace lock motor
assy.
3. If motor runs with test cord check continuity of wire harness to lock motor terminals. If harness is good replace
the EOC.
Door lock motor or latch
circuit failure
AS YOU SEE THE F93 CODE REFERES TO THE DOOR LATCH MOTOR
Jul 19, 2011 | Kenmore Ovens
While baking we are getting error F 95 on our kenmore elite wall oven
Sorry to read about your problem, I hope this helps you out.
your f95 means your Door motor mechanism has a failure. The motor does not stop rotating.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Dec 30, 2010 | Ovens
My ST 92 Salva Oven displays fault code AL 3 what does it mean
my salva st-92 oven is displaying AL9 fault code
May 05, 2010 | Ovens
What are Fault Codes F2 and F5 on a GE built in electric oven model JTP45WDW2WW? Is there a site where the fault codes can be accessed?
Both codes most likely relate to a failed circuit in the lock mechanism and or a failed circuit in the temperature sensor circuit.
Sep 17, 2009 | GE Profile JTP56 Electric Double Oven
Jenn-Air Wall Oven Model #WW30430P F5 Fault Code
I have the exact same problem with an F5 fault code. I also have a new clock assembly. RepairClinic.com said "Jenn Air fault code F5 = Hardware and watchdog circuits disagree / Replace clock assembly (also called the ERC)
Jenn Air Fault code for newer models F5 = Power to element relays disabled in cook mode
1. Intermittent oven temperature sensor or wire harness or,
2. Intermittent contact on power relay board"
This doesn't help since it is too technical. What should I do next?
Oct 19, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
Frigidaire (FEB30S7D) Oven Logo
753 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
