Question about Fuji Finepix Z20fd Digital Camera
My camara wont take pictures,when open or turn on it says protected card,and i went in to menu but dont see whats wrong!
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Aug 26, 2010
There is no sd card inn my camara but it reads write protect and cant take any pictures
As long as you don't put in any memory card, where the camera can put its pictures, it will say write protected.
If you did put in a memory card the wrong way around you also can have damaged the little switch in the memory card holder, so it always thinks the switch is engaged. Please put in a correct card, with the lock switch up. Not pointing to the lock position and check if that will work.
Oct 12, 2014 | Olympus SP800UZ Digital Camera
How to unlock a photo in camara
The protect function allows a user to protect a picture from accidental deletion. To unprotect a picture on your camera, scroll to the protected picture that you want to delete, then press the Menu button (the button to the right of the Play button.) Scroll down the menu and you should come to an option that allows you to Protect/Unprotect the picture. Since your picture is currently protected, deselect that option. You should then be able to delete the picture normally.
Alternatively, you could also format the memory card, however this deletes ALL photos and data you have on the memory card. If you are trying to completely clear the memory, this is the best way. After turning on your camera, simply press the Menu button, scroll to Setup, then scroll down to Format. Select Format, it will ask you if you want to format the memory card, or the camera's built-in memory. Format whichever one you want to clear, if you are using a memory card then your pictures are stored on the memory card. It will take a few seconds to format.
Hope this helps.
Dec 05, 2012 | Kodak EasyShare M1033 Digital Camera
Every time i turn on my camara it says protected card but its not the memory card its not locked! so whats wrong with my camara??
The message which you are getting because you memory stick is write protected.There is a small thing which make a card write protected.
As I dont know which card you are using so here I am giving an simple example with images.
Just click HERE and first read the instruction.It is from SANDISK as it is the most trusted memory stick brand so i am giving its resemblance.
Follow the same steps and make you card working.
If you still persists or you have any more query then get back to me here.
All The Best.
With Regards:-
Subhankar Ghosh
Dec 12, 2010 | Fuji FinePix Z10fd Digital Camera
Cant take pictures with memory card in
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Mar 19, 2010 | Fuji FinePix S700 Digital Camera
I need to restart my camara.
I just got a fuji digital camera. I was taking pictures and it said memory full and then the lcd screen went dark gray with a green dot in the middle. I then opened the memory card and installed it. I can still take pictures and see thru the focus lens but not the lcd screen.????? pls. help
Dec 15, 2009 | Canon Cameras
My digital camara will not save pictures. Messages appear.
If you are using SD memory card, it can be locked. Take out your memory card, on the left side there's a switch. Turn switch up and try again. Hope this will work.
Aug 09, 2009 | Cameras
Fujifilem Z20fd I cant turn the card protection off which appears
Is your flash working? Do you have the flash turned on?
Jul 11, 2009 | Fuji Finepix Z20fd Digital Camera
My Coolplix L18 wont let me do nothing
Hi
Take the memory card out of the camera.
You will see a small switch on the card (it is the lock switch)
Slide it to the opposite side and there you go!
It's easy to accidentally lock your card without even knowing it.
lol my mom just had this exact same problem and it was driving her crazy (she too didn't realize the card had a physical lock switch)
Have funn,
Bye
Jul 02, 2009 | Cameras
Write protect card
thos pictures are lost... u ken fix the problem by format...menu- setup- format...they are problems with the pictures because the camera was shaken allot...dont worry this will do it... or u ken get a card reader to get thos photos back, but the format is required
Sep 22, 2006 | Olympus Stylus 700 / 700 Digital Camera
Fuji Finepix Z20fd Digital Camera Logo
27 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
