Question about Sony Cybershot DSCW80 7.2MP Digital Camera with 3x Optical Zoom and Super Steady Shot
Lens won't go back inside of camera...keeps telling me to turn off and turn back on. I was able to see pictures housed in camera, but cannot take picture
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 26, 2010
My Sony cybershot dsc-w55 won't take pictures! I
Your lens is stuck due to either being banged or bumped or there is dirt/grit inside the lens gears. The lens needs to be replaced, but buying a brand new lens is out of the question. Sony will charge $125 just for the lens assembly, it's crazy.
A refurb lens can be installed for about $75 including return shipping. You should check the replacement cost of a used camera and see which is cheaper in the long run.
Hope this helps!
Thomas Drayton
Owner, Darntoothysam.com Digital Camera Repair
Jul 25, 2011 | Sony Cameras
I have the same problem this guy had: I have a Sony Cybershot 8.1 megapixels. Every once in a while the screen will turn black when I turn the camera on. The display will come up (shaky hand, flash, etc.)...
The camera either has a stuck aperture inside the lens or a bad CCD sensor.
The aperture is the opening that allows light to enter the lens. If it's stuck closed no light goes in, so no display on the LCD and solid black pictures. The way to fix it is to replace the lens. You can try tapping or banging the camera on it's side on your hand or even gently on a table. This might unstick the aperture for a short time, but it will just stick again later.
If the CCD is bad the sensor won't show anything other than solid black, or sometimes purple/pink smeared lines. Again the solution is to replace the lens assembly, or look for a used CCD online and just switch that out instead.
Hope this helps!
Thomas Drayton
Jul 12, 2011 | Sony Cyber-shot DSC-W100 Digital Camera
I have the same problem. After I take a picture, it comes up "System Error 2". If I turn the camera off and back on again, I can take another picture. I have tried a new memory card and the...
Hello dear sir bkapper, surely there was a flaw in the mechanism of image stabilization (VR).
The best solution , bring the camera to Nikon service.
Regards.
Mar 09, 2011 | Nikon Coolpix 8800 Digital Camera
Our camera has a black spot on the screen and shows up on the pictures as well is there a way we can fix it?
Turn the camera on and extend the lens, wipe the front lens with the proper cleaning materials "lens paper and camera lens fluid" try the camera again to see if it worked, if no improvement! there maybe deb-ri inside the lens housing or camera body. At this point it will need a qualified camera technician to see if it can be repaired.
Jan 10, 2011 | Canon PowerShot SD940 IS / IXUS 120 IS...
DSC-W150 SteadyShot says turn power on & off & lens pops in/out
I had the same problem with my Sony DSC-W150 camera. It turned out to have an easy fix. At the same time, press the power button and depress the shutter button halfway (the one you snap to take pics) as if you were trying to engage the autofocus without pressing the button down entirely. The lens will attempt to autofucus, which in my case was enough extra power to dislodge whatever debris/sand had clogged the lens. Hope this works for you!
Jun 04, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
Stops taking pictures
I have the similar problem, I turn on the camera and after the lens comes out , red light blink all this time, and suddenly it powers down without retracting the lens back in.
The battery are fully charged AA 2400mah / 2650mah Duracell at 4.0 ma with load test. I was wondering if there is any circuitry problem.? Any experts in digital camera electronics please respond? Trick: To bring back the lens back in for safekeeping i trik this, i turn it on while it is reading the memory etc and after a sec or two i turn the knob to off, this way lens goes back inside.
I have read other brands also have their cameras lens sticking out and never going back inside.
Feb 19, 2010 | Kodak EasyShare DX4530 Digital Camera
I dropped my camera while it was on and the lens was extended. And I dropped it right on the lens. And now when I turn the camra off, the lens does not go back inside the camera. Everything else is fine,...
if the cams making grinding or crunching noise the lens housing gears are broke. repair usually not very economical. about 80% the cost of cam when you bought it.
Jun 04, 2009 | Casio Exilim EX-Z57 Digital Camera
Can't take picture
Needs to go back to Panasonic- an inherent fault.
Aug 16, 2007 | Panasonic Lumix DMC-LZ7 Digital Camera
Sony Cybershot DSCW80 7.2MP Digital Camera with 3x Optical Zoom and Super Steady Shot  Logo
20 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
