Question about Dell All-in-One 968+ Wireless Network Card Bundle InkJet Printer
Telus was in today and replace the modem and router in my house now my wireless printer 968W does not work. The window says Communication not available.
  • Jean Mevel Aug 26, 2010
    Had a chat with an expert and fixed my problem.
  • 724 Answers
Set the printer network menu to a have a matching DHCP or a static address
Posted on Aug 25, 2010
In my lap with windows 8 version netconnection i s not available,but with same wifi modem..NETGEAR N150 WIRELESS D S L Modem Router mobile is net.connected.
Netgear are products that are last to just about 90 days. I am a computer tech and do a lot of house and business calls to TS networks. Most problems come from Netgear, once they switch to another brand, the problem disappear. Even I had a wireless Netgear router, and had to return it because the life span was about 4 month and the complimentary support is only 90 days.
Just by rebooting the modem (turning it off and on) usually fix it for about 8 hours, then the cycle start again. After rebooting the modem/router, delete your saved network from Windows 8 and start fresh. That should work.
Mar 21, 2015 | NetGear N150 Wireless-N ADSL2 Modem Router...
I can't get my wireless printer to work since I bought a new modem
That's strange as the wireless printer communicates with the router, not the modem. Did you change routers, or bypass the router when you hooked up the new modem?
Usually, you use the panel on the printer, Settings, tochange the wifi device to use, and enter a password when prompted. With newer routers and printers, there's a WPS button that allows the new device to be added without needing to know a password.
Just a few ideas you might try to get it working again..
Oct 30, 2013 | Microsoft Windows Vista Home Premium with...
Dell 968w wireless printer
Go inside printer menu and assign it a static IP address, address that is not in use by any of your other devices. use 255.255.255.0 for subnet and your router ip as gateway
Jul 26, 2010 | Dell 968w Printer
D-Link DI-524 wireless router stopped working
You could spend $40 to have a qualified technician try to trouble-shoot, or you could spend $40 to buy a brand-new wireless-G replacement router. Your money; your choice.
Apr 16, 2010 | Office Equipment & Supplies
How do you hook up a dlink router to a telus modem, the WLAN connection won't work.
Newer telus modems tend to be wireless.
If your telus modem is wireless, then you want to forget the DIR-625 all together and simply connect your computers to the telus modem.
If you have a standard telus modem, you will want to connect a LAN cable from the modem to the WAN port on the router and then connect your devices to the router.
Please come back and vote or leave some feedback, it will let me know whether it helped so I can improve and it will encourage me to keep on helping.
Thanks,
Pat
Mar 31, 2010 | D-Link DIR-625 (790069292637) Wireless...
We had to replace our modem & our wireless router isn't working
You have got a new modem. You will need to change the settings of the router according to the new modem.
First make sure that your computer is able to go online when connected directly to the modem. If that works then connect the computer to the router and the modem to the router.
open the set up page of the router and set up the router.
Click here for more info
Nov 28, 2009 | Dynex Wireless-G Broadband Router
Can I setup a cable modem with a router
You can if the router is wireless and you have a wireless card in your computers. If not, then you will have to upgrade the router to a wireless and get wireless cards in the computers or run a cable to the 2nd floor
Oct 26, 2009 | Arris SURFboard SBG900 (49402201900) Modem
My 968w printer will not print wireless. i have worked with att support and they are telling me the wireless pack is bad, but not sure of it. how can I tell if the wireless pack is not working properly or...
Did you try it with another computer? well if you can see the wirless printer in your computer and you cannot print, this is software isusse or configuration. but if there is no connection at all, could be corrupted wireless card.
Oct 04, 2009 | Dell 968w Printer
Access point router and wireless router communication
You said that the router connected to the modem is acting like an access point. that means the DHCP server on that router must be disabled. The second router is connected to the first with the ethernet port. What you can do, you can enable the DHCP server on the first router and make the second router work as an access point.
so that both the computers will be in the same IP address range.
If they are already in the same IP address range then you can try to ping the second computer's IP address form the first computer.
Click here for more info.
Sep 18, 2009 | Belkin (F5D8231-4) Wireless Router...
Can not connect to my wireless network
Do you have a wireless card in the system?
If it is a laptop, you first need to connect to the router wired. Create a name and encryption, then disconnect and let windows search for the connection.
Don't use WEP, encryption is too weak and be hacked into within 10 minutes. Use WPA-SK AES or higher.
To find out the router address, go to the command line and type tracert www.telus.net or anything else. The first address returned is the router address.
Aug 20, 2009 | Computers & Internet
Dell All-in-One 968+ Wireless Network Card Bundle InkJet Printer Logo
164 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
