Question about Refrigerators
My samsung fridge freezer da99-00494v has started to get very noisy while running
  • 4 more comments
  • drewpee40 May 29, 2008
    Fridge fan started making a noise while running, water dispenser stopped working and now fridge temp display is flashing
  • Anonymous Jun 07, 2008
    Water dispenser has stopped working and fridge is noisy when running. inside temp is also not as cold.
  • sierrafox Jun 13, 2008
    I am having the same probelm - the fridge temp is now falshing and temperature going up in fridge - the fan made big noises - freezer side not effected
  • janchamberla Mar 11, 2009
    Making increasingly load wherring noise whilst running then just as it becomes unbearable it stops and there is the beautiful sound of silence, then just as you think its fixed itself it starts up again. No problem with the temp so far!!!
  • Anonymous Apr 01, 2009
    fridge can be silent for a while but then it makes rattling noises that stop when I open the fridge. The noises return when the door is closed.
  • sherbertson May 11, 2010
    We have just followed these tips and ours is working fine now. It is a bit of a struggle to get the back off though - some of the screws are well-hidden. Be aware that the back panel might be frozen on so you need a bit of faith to pull it off, do this carefully so that you don't pull the wires out. Ours was completely covered in dense ice so took some blasting with a hair dryer. It's a pain-staking task but worth it and saves on calling someone out. Hopefully it will be a good while before we need to do it again.
I had the same problem - the fan was making a racket like it was catching on something, it got worse and worse and then suddenly stopped. After a few days it became noticable that the temperature was dropping until the fridge was basically just a cool cupboard!! So, I emptied the enite fridge, took out all the shelves and took off both back compartments - the lower section contains the fan, but the top has to be removed to access the fan section. Basically it had got iced up and frozen solid and with the use of a hairdryer all was fixed and back to a silent running, working fridge - quite labour intensive but straight forward and fairly obvious.
Posted on May 17, 2009
Just had same problem
you can
1. turn off and defrost
2. remove all panel of fridge ( inside) fan has got bloked with ice and cannot cool fridge.
Posted on Jun 15, 2008
You will find that the fan is iced up it is fairly simple to correct switch off from mains take out all the trays and disconnect the cool box remove the back panel be careful because you can damage the wireing if you are to brutal you will then see all the workings use a hairdrier to free up fan clean down and replace all parts i have done this with great success tony
Posted on Nov 15, 2009
My samsung refrigeretor do not go on! Just the is on when the dor is open. then fan don't go on!
Posted on Sep 01, 2009
    Producer:
    Uploaded 30 video answers.
  • 117 Answers
Some good help with samsung diy here -
samsung fridge freezer diy help
hope this sheds some light
Posted on Oct 18, 2010
Samsung DA99-01537A ??????? ??? ???? ????? ??????? ????? ?????? ??????? ?? ????? ??? ?? ???????? ???? ???? ???? ??? ?????? ????? ??????? ?? ????? ?????? ?? ??? ??????? ?????? ??? ???? ??????? ????? ???? ?? ???? ???? ??????? ???????? ???? ???? ?? ???? ??? ???? ?????? ??????? ???? ???? ????? khalidagoriel@yahoo.com
Posted on Oct 23, 2010
3 Suggested Answers
  • 10 Answers
SOURCE: my frost free fridge freezer
I would start with a 24 hour full defrost,
if the problem reoccures then it is more likely thermister fault
Posted on Mar 19, 2008
  • 117 Answers
SOURCE: motor noisy, stops when open refrigerator door
you may want to check out
this is a common fault on some samsung models , defrosting it doesnt usually solve the underlying fault , normaly fault will re-occur ...
check these videos out
Noisy Fridge
sounds like the recirculating fan inside the unit is about to seize. Find it and lubricate it.
Apr 23, 2017 | Samsung RS2630SH Side by Side Refrigerator
Srs618dp model samsung noisy and lose temperature
I have a Samsung srs618dp side by side fridge. I have just turned it on after 5 months and it seems to be working however every 30 seconds it keeps beeping, very annoying. There is no ice build up.
Apr 06, 2013 | Samsung RS2630SH Side by Side Refrigerator
Fridge/freezer Samsung3116NW very noisy from left fridge wall Ithink
if the left side of your fridge is the freezer compartment , chances are you have a bad circulation fan . I would suggest replacing the fan motor assembly . The circulation fan is located at the rear of the freezer mounted to the evaporator cover .
Feb 19, 2011 | Samsung Refrigerators
Sde by side refrigerator. fridge icing up and fan very noisy
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 16, 2011 | Samsung RS2630SH Side by Side Refrigerator
Motor noisy, stops when open refrigerator door
i had this problem then turned off fridge freezer for 24hrs and it was gone it was more or less needing defrosted
Apr 29, 2010 | Samsung Refrigerators
Samsung RS21DCNS Fridge not getting cold
0845 726 7864 samsung know of this problem and are doing free fixes to all of them just phone the number it doesnt matter about the warranty as they have extended them all free to 5 yrs.
There are numerous problems including noisy fan that stops when doors open to no water and all are free to fix.
Hope this helps.
Sep 01, 2009 | Samsung RS2556 Side by Side Refrigerator
Maytag msd2456dew not cooling / not freezing after noisy fan
my Matytag msd2456dew fridge fan is running, no ice bulid up on coils in freezer section, but no cold air to freeze anything in freezer section or cold air in fridge section. what can be the problem?
Sham
Feb 15, 2009 | Maytag Refrigerators
Samsung RS21DGRS side by side fridge freezer. Fridge not working became noisey then stopped working. It is 2 years old and two week out of warranty.
common issue on these uk Samsung fridge freezers , symptoms
fridge noisy stops when door opened
water doesn't work
colder at the bottom of the fridge
ice build up around the left vent on the lower fridge panel
check out the you tube video and the Chanel the video belongs to - very helpful stuff regarding uk Samsung fridge freezer problems
this videos show how to dismantle Samsung rs21
May 29, 2008 | Samsung Office Equipment & Supplies
Refrigerators Logo
4,916 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
