My sundowner airconditioner switches suddenly of and I can't switch it on
  • bertgyzen Aug 26, 2010
    Many thanks for your reply. I think that our problem is a result of the drip pan, as we had over the last few weeks several times that the unit was defrosting. I am not able to get to the drip pan as this is most likely in the ceiling, but i Will work on it. Best regards Bert Gyzen
  • 2,272 Answers
OK.keep updated with the results.A drip pan is installed under the condenser unit to catch excessive drips or leaks. If you find water in the drip pan, clean or replace the condensation line. Thanks for the update.
Posted on Aug 26, 2010
  • 857 Answers
Air Conditioner Won't Start may be due to : -
1.electrical problems
Please follow these:
it may sound silly, but is the air conditioner turned on?
Has the cooling thermostat been set to "cool" and the temperature set below ambient room temperature?
Do both the outdoor compressor/condenser unit and the indoor blower fan/evaporator coil unit have electrical power?
Are the power switches on at these units, are the fuses good, are the circuit breakers in the "on" position, and is the thermostat set correctly? See A/C - HEAT PUMP CONTROLS & SWITCHES and THERMOSTATS for some diagnostic tips.
2. Air Conditioner Won't Start or Stays Off Due to Condensate Pan Switch.
Condensate pan switch lockout: an attic or other air conditioner air handler condensate drip tray or drip pan located under an air handler is installed to catch air handler condensate leaks if the normal condensate drain system fails. Some condensate pans have their own separate overflow drain (a proper installation) or share their drain with the normal condensate drain (an improper installation).
But on some air conditioning air handlers the installer may provide a condensate overflow pan switch rather than a separate pan drain line. In this installation the switch is designed to turn off the air conditioning system if it finds condensate water in the overflow pan. The idea is to shut down the air conditioner before there is a more costly leak into the building insulation or ceiling.
So if your air conditioning system seems to be normal in all other respects but it simply won't turn on, check for a flooded condensate pan or a defective condensate switch. See DRIP TRAY DEFECTS and also Use of float switches on air conditioning condensate overflow pans.
2013 Sundowner Santa Fe Manual
Not sure what the Santa Fe "Sundowner" is... but as far as I know there is only one manual for all models. Hyundai 2013 Santa Fe Owners Manual can take a few minutes to download as file is quite large... be patient.
Download it here:
http://www.missdraper.org/2013Santa_FeDMA/2013SANTA_FE_(DMA)_FINAL.pdf
PS... If by "Santa Fe Sundowner" you mean the horse trailer by the same name, I can't help you!
Aug 24, 2014 | 2013 Hyundai Santa Fe
To repair hole in airconditioner pipe. the switch broke off
Have an a/c specialist make a new line as repairing the line will be next to impossible and will damage the compressor and tx valve.
Mar 16, 2013 | Cars & Trucks
Fan for heater/air conditioner quit working suddenly
its the blower motor resistor that is faulty or the blower motor resistor wire connector that has a bad connection.Wiggle the wire connector going to the resistor with the ignition switch and the fan switch in the on position and if the fan comes on then the connection is bad but, if it does'nt come on then the resistor is faulty.
Aug 17, 2012 | 1992 Dodge Dakota
My GE wall Airconditioner is not cooling brings out warm air?
mcdevito75, here, wall A/C do they also give out Heat, if so, refer to the owners manual for instructions on how to use the cooling. Set switch to low cool and the switch with the blue scale about 1/2 way thru the blue scale shown on the switch (Knob) Both your A/C units may be set on heat, double check position on switches, (Knobs)
Jun 24, 2010 | GE AJCQ08ACB Air Conditioner
I have an electrolux split system airconditioner model no.EJE24HRA it has not been used for months but the display panel is suddenly flashing Auto and if I do turn it on it suddenly switches itself off...
there is a auto switch button inside the indoor unit just above or on the side of digital display but you must open front panel to get access to it when you do, press that button which says auto once to cancell it from coming on than set your mode on the remote to heating then press start or on button on remote. be sure to set temp to atleast 30 degree before starting it
Sep 27, 2009 | Electrolux E23CS75SS Air Conditioner
The air from the airconditioner and heater only will blow out the
Sounds like a vacuum leak. Check the vac supply on the intake manifold. Passenger side front of intake.
Jun 24, 2009 | 1997 GMC Safari
Fan speed trouble on cool setting
1.check selector switch of airconditioner.
2.capacitor of blower fan motor.
3 wiring of airconditioner.
4.replace selector switch.
Feb 25, 2008 | Comfort-Aire EKTC12-150J Air Conditioner
Heating & Cooling Logo
93 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
