Question about AOC Computers & Internet
My aoc 716vmy monitor have blurred or doubled view. how can i fix it?
    Sergeant:
  • 223 Answers
A couple things to check. speakers close the monitor. (caused by magnets) run a degauss from the monitor menu, also check the monitor connections back of monitor and back of computer for "tight" fit
That covers external issues. In the computer, in windows XP its typically right click on the desktop , go to properties. adjust your Screen resolution to fit the monitor, see if different resolutions have the same double effect. also go into advanced look for "Monitor Refresh Rate", try increasing the "Refresh rate" from say 60Hz to 75 Hz. this is very common cause of poor screen quality. Hope that helps. Cheers
Posted on Aug 25, 2010
My AOC 2250 monitor has double image or shadowing. Can I fix this somehow?
Replace the cable from the computer to the monitor with a known good one.
It may have been damaged.
Any Geeky computer nerd friend will have a spare one, don't just run out and buy one.
Feb 26, 2015 | AOC Computers & Internet
How do I perform hard reset for AOC monitor. Menu reset doesn't fix problem.
There are only two types of resets. Factory reset, and Hard reset. To make a hard reset, you have to unplug the TV from AC mains wall socket, and re-plug it back after 20 minutes or so. Within this time it might have been resetted. To do a Factory reset, you have to enter its service mode option. Electro help . Try this link to know more. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy.
Jan 07, 2014 | AOC L24H898 24 in. LCD TV
AOC monitor black screen how do I fix it?
I have a couple AOC i2353ph monitors. One day, one of them booted up with a single vertical white line moving slowly back and forth across the screen that kind of looked like a scan or radar. Once I reset the monitor from the OSD it went way. Use "Extra > Reset" from the monitor menu.
Oct 22, 2013 | AOC 917Sw 19" LCD Monitor
We have purchased two e950Sw LED 18.5 monitors to replace the crt monitors on two of our computers. Old monitors worked fine. Both of these monitors when hooked up get the "No signal" message....
Your old monitors might have had a higher screen resolution or and incomparable resolution for your new monitors.
Probably the easiest way to get them to work is to plug the old monitors in then go to your control panel / display and set the resolution to 1366 x 768 as this is the native resolution of the e950Sw LED.
Chris
Jul 08, 2011 | Computers & Internet
AOC 917sw 19 inch monitor resolution issue (same as above)
Have you try the following resolution values:
1280 x 768
Usually its the standard for widescreen view
Please don't forget to rate if answer is useful
Jun 18, 2009 | AOC 917Sw 19" LCD Monitor
AOC 26" LCD 619Fh Problem
Go to "Picture Boost" option in the "OSD window". Then turn on the "Bright Frame" option and after that make the "Frame Size" to 100. That's it now you can get a perfect sharp image...it worked for me.
Mar 07, 2009 | AOC LM729 17" LCD Monitor
Monitor problem
Hi..there,
Oh...That's bad news! Your panel it's damaged. Don't bother to replaced the panel, cuz it will cost you double the price. Get a new one for Xmas ... You'll saved even more $$$... Happy Holidays!
Dec 18, 2008 | AOC Monitor
Excel text is blurred not totally black
if it gives problem only on excel i mean that the properties of excel has disturbed. the computer is not faulty any more. you can restore default from the excel properties.
Nov 28, 2008 | AOC LM729 17" LCD Monitor
AOC 53N PROBLEM
DO YOU KNOW HOW TO SOLDER. IF SO, TRY TO OPEN THE MONITR AND LOCATE THE VERTICAL SECTION AND YOU WILL FIND LOOSE SOLDERS. A SINGLE HORIZONTAL LINE MEANS THAT THERE IS A PROBLEM WITH THE VERTICAL LINEARITY OF YOUR MONITOR. FIND SOMEONE WHO KNOWS HOW TO FIX COLD SOLDERS
Aug 06, 2008 | AOC 5 En 15" CRT Monitor
AOC 17" Flat Monitor (silver)
Hello all.I had 2 AOC monitors with this kind of problem also and figured out the problem with this kind of monitor. All you have to do is to unscrew the monitor and get the control control switch buttons on its circuit board. There are four switch button that control the monitor with four pins each that attaches to the circuit board of AOC, another option is to replace the switch button with a brand new  control switch button which can be bought to your local electronic shop. Now i had no problem with my AOC monitor because i literally removed those switch control buttons from its circuit board.
Mar 03, 2008 | AOC CT720G 17" CRT Monitor
Computers & Internet Logo
142 people viewed this question
Top AOC Computers & Internet Experts
Raj Patel
Mohammed Ebrahim M
Mohammed Ebrahim M
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
