Question about Garden
Had to replace the handle on my 10 inch compound miter saw, I need the wiring diagram for the handle!
  • caroljax2 Aug 25, 2010
    It is not a chain saw it is a Craftsman 10 inch compound miter saw Model 315.285450 thank you.
  • 905 Answers
Would you have the manufacturer / model # of your miter saw?
Posted on Aug 26, 2010
Can't lock miter angle with slide handle
There is a plate under the turntable which needs to be replaced, remove centre bolt locknuts and washer (44,45 and 46) from the underside of the base and lift the turntable off taking care to not loose the detent spring (36) and steel ball (37), turn it upside down and remove the spacer plate (31) and replace it, use a small amount of grease on the spring and steel ball during assembly to keep them in place
Jun 24, 2015 | Hitachi C10FSB 10" Sliding Dual Compound...
The only way to turn the saw off is to unplug it. Ryobi 10 inch sliding compound miter saw model TSS100L
You may be able to take the handle apart and, using compressed air, blow any sawdust out of the handle and switch but most likely you'll have to replace the switch.
Feb 14, 2014 | Makita 10" Miter Saw LS1030N
How do I replace the spring in the lock off lever?
This is page 28 of the manualhttp://www.manualslib.com/manual/490926/Craftsman-113-235110.html?page=28#manual.
Nov 27, 2013 | Craftsman 10" Inch Miter Saw Sears Model...
Skil 3316 Compound Mitre Saw 10"
I suspect that the brushes have fallen out between the end bearing and the armature bars.. Try removing the brushes and see what happens.
May 18, 2013 | Skil 10-in 15-Amp Compound Miter Saw...
How do u unlock a 10'' benchtop compound miter saw
slightly push down on the handle, then look directly over the top at where swivel spring is either on the left or right side , there is going to be a pull pin, it will only pull out far enough for the handle to go up and down, its not suppose to come all the way out
Jan 12, 2011 | Makita 10" Compound Miter Saw LS1040
How do i replace the light on my makita ls1013fl, specifically the wiring
The light should have its own harness that plugs into a connector. I have the breakdown with the breakdown and wiring diagram if you want a copy just email me at phoenix.repair@hotmail.com or go to phoenixrepair.org. Hope this helps you.
Rob
Oct 14, 2010 | Makita LS1013FL 15 Amp 10 Inch Dual Bevel...
Changing the blade
there is a nut holding the blade in the center , it is left handle thread , there should be a locking mechanism to hold the blade while you unscrew the nut
Oct 31, 2009 | Makita 10" Compound Miter Saw LS1040
Need wiring diagram for the box on the outside of the motor.
white from cord to B. grey from stator to A. blue from brush holder and red from switch to C!
Mar 25, 2009 | Hitachi C10FSB 10" Sliding Dual Compound...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
