Hi, My Hotpoint Ultima WT761G will not switch on. No power at all. Have checked plug socket & fuse and even replaced fuse. Also there is water in the drum that will not drain away. When machine is plugged in, the door locks however no led lights or display. When unplugged door unlocks after time delay...! Any ideas whats wrong? Thanks.
  • bradboy Jun 01, 2008
    No power to washing machine and no led lights on,door does not open as well, but havent tried when power off. There is 240v inside of washing machine.
5 Suggested Answers
dazmaraz
  • 66 Answers
SOURCE: hotpoint wf220 washing machine
most computer machines will do what your explaining , after the lights have flashed try selecting a prog, and press the start button
Posted on Aug 31, 2007
SOURCE: Hotpoint wf860 - H2O Error Code - Machine is asking for water but draining it straight out
Check that your outlet pipe rises above the stated height on the back of the machine (about 3/4 of the way up). If it is too low, it will siphon the water out of the drum. If you're not sure what height it should be at, raise the top of the pipe (ie where it bends back into the outflow pipe) above the top of the machine (if you have room) or as high as you can. It must be above the height of the drum.
Good Luck
Posted on Jan 23, 2008
SOURCE: hotpoint ultima wf640
read your washer instruction manual and check all connections also h2o stands for the chemical sign for water
Posted on Apr 03, 2008
  • 3 Answers
SOURCE: drum wont move
Its fixed! The starter capacitor was blown.
Posted on Feb 27, 2009
  • 130 Answers
SOURCE: Help with correcting fault code f-5
F-05 error means:-- Water Temperature Sensor Error
If during the water heating step in wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the "F/05" error code will be displayed.
TO RESOLVE THE PROBLEM:--
Check the Water Temperature Sensor, Heating Element and Element Relay globul1a.gif Check connections to the Sensor, Heating Element and Relay
Posted on May 07, 2009
Hotpoint ultima wmd960 no power going to it at all checked fuse that's ok.
(this is pre-typed to cover a number of power faults!)
Check that the washer supply is OK using another item - a kettle for instance. If it's not check your breakers/fuses. Reset/replace if necessary and if the same thing happens, or if there was nothing wrong with the breakers/fuses in the first place, sorry but with such a fault it is impossible for anybody on this forum to remotely guess what could be wrong with your washer. It could be internal wiring/plugs sockets, control panel switches, control PCB.
I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Oct 23, 2011 | Hotpoint Washing Machines
I have my hotpoint ultima 7 kgs wt960p is not coming on i've check the electric outlet and the fuse and both working but still not coming on normally the blue lights on it was nothing coming on at all...
So sorry but with such a fault it is extremely difficult for anybody on this forum to remotely guess what is wrong with your washer.
John C
Jul 07, 2011 | Hotpoint Ultima WF860 Front Load Washer
My hotpoint ultima dryer has no power to it changed fuse checked plug socket emptied water tank cleaned both filters
power comes in at mains lead goes to the choke /filter from here onto the door interlock switch then onto timer ......hope this helps
Feb 26, 2011 | Hotpoint Ultima WF860 Front Load Washer
My Hotpoint ultima WT721 1200 spin keeps tripping out all plug sockets. Have changed fuse but still does it. What could it please?
hello, bad earth check all the wired connection to the washer if these are ok then check your socket wires make sure wires are tight if these ok then there may be fault inside the washer power supply hope it helps
regards
shaun
Jan 15, 2011 | Hotpoint Washing Machines
Hotpoint ultima error code f5
Fault code f05 is a drainage problem or pressure switch stuck on full.
If your machine is full of water, unplug it from the wall socket. Drag the machine out and lower the drain hose into a wash basin. Raise the hose to stop the flow of water. Repeat the draining process until you get no more water coming out.
Now take the rear panel off, check the pump hasn't burned out, use a multimeter to test if it's open circuit and check the wires to it aren't broken.
If all ok there, take the hose off the bottom of the tub and clear out any debris in there.
If this doesn't work, repeat draining it and this time take the pump out and make sure there's nothing there stopping the pump running.
If there is no water in the machine, take the lid off, locate the pressure switch and take the small bore tube off it, blow down the tube to ensure there is no blockage. Give the pressure switch a tap and try again.
Read more: http://www.justanswer.com/questions/1omeg-hi-i-have-a-hotpoint-ultima-wt721-washing-machine-with-fault#ixzz0o57elJQI
May 16, 2010 | Hotpoint Ultima WF860 Front Load Washer
My Hotpoint Ultima keeps displaying an F10 fault and doesnt spin correctly. However, if I then switch it to a rinse and spin cycle it seems to spin OK.
F10 meanswater level pressure switch not sensing correctly, there could be a blockage in the switch hose or chamber, or the switch could be faulty.
Jan 17, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WD64 No power - help please !
hi from n/west uk from the symptoms you describe ? that you have no lights on machine? this is most definately total power loss to machine so if you are certain? the fuse is ok? next is has the wire/lead from plug chaffed or damaged breaking the supply? this next possibility may sound odd but the socket you plug machine into ? may be faulty ie the damp location at rear of machine could have caused deteriation of socket terminals or wires even the wire may have broken/come loose? have had this happen in homes and caused by wires not secured properly and eventually arcing/ resulting in power fail at socket ? may i suggest try another elec appliance ie lamp/hoover/ iron? to check if socket is operating just to eliminate? also if the socket is a fused type? make sure this fuse is ok too? finally have you checked consumer unit for possible seperately fused/trip out for the machine use socket ? hope this helps find fault best wishes
Oct 26, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Ultima
If your washer doesn't seem to work at all, check these:
No power
Lid switch
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse. You can also visit this website for more troubleshooting details:
http://www.repairclinic.com/0088_11_1.asp#Level1_1
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem. (Positive Rating)
  • "Helpful" - The solution provides useful leads that helps solve the problem. (Positive Rating)
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated. (Negative Rating)
  • "Inappropriate" - The solution has absolutely nothing to do with the problem. (Negative Rating)
Thank you for using FIXYA!
IrishDruid
Sep 28, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
Hotpoint ultima WT9 60
the internal circuit board has come loose, switch off power take the top off and tighten the connections on the plugs inside
Feb 01, 2008 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
78 people viewed this question
Top Washing Machines Experts
Richard Roth
Richard Roth
