Question about Cameras
Camera is a JVC GR-DF470 Video Camera. Problem is UNIT IN SAFEGUARD MODE EJECT AND REINSERT TAPE ERROR 03. I have done this and problem still remains.
Same problem, same camera. Interestingly, it happened after two years and coincidentally when I changed to a different brand of tape (TDK) after using Sony and JVC tapes.
Solution (as suggested on some other web site) is to eject and then manually wind the tape a couple of turns. This can be done by sticking one flat blade screwdriver in the tape locking tab (bottom middle of case) and using another to manually wind the tape reel. Re-insert the tape and there should be no error code and all should work fine.
Hope this helps.
Posted on Aug 31, 2008
I have the same model of camera and the same problem has occurred after two years of use. I am not sure why it happens but checking on other web sites, it may have to do with tape tension and the brand of tape. Up to now, I was using Sony and JVC tapes which worked fine but a recent purchase of TDK tapes seems to have caused this problem.
My fix was to take the tape out and then manually wind the tape a couple of turns by inserting one flat blade screwdriver in the tape lock tab (bottom middle of tape case) and using another to wind the tape. This appeared to fix the tape tension and after loading it back in, the tape and the camera worked fine.
Hope this helps.
MY CAMERA SHOW E03 ;unit in safeguard mode ;EJECT AND REINSERT TAPE WHT SHOULD I DO............
JVCGR-D270.Digital Camcorder. When we put the tape in the cam it chews the tape whiles loading and says that it's in 03 safe guard mode. Please help.
Jan 24, 2011 | JVC GR-D73AG Mini DV Digital Camcorder
Gr-dvl-520u trying to record or playback tape it goes into safeguard mode within 5 seconds. alternatly pressing play and still every 3 seconds advanced the playback without it going into safeguard mod
According to http://www.techlore.com/article/10974/JVC-Camcorder-Stuck-in-Safe-Mode/,
"JVC notes that you are also given a malfunction code when the unit is placed into safeguard. If it displays code 01, 02, or 06 you should remove
the battery and powersupply and wait for a while. Code 03 and 04 indicate that you should eject and reinsert the tape.
If neither of these solutions work, your only alternative is to bring it to a shop or send it to JVC for diagnosis or repair. Unfortunately, there is no other way to clear the condition."
If you are getting E03 or E04 errors on every tape you try, it sounds like a servicing is required.
Apr 17, 2009 | JVC Cybercam GR-DV500US Mini DV Digital...
Unit stuck in safeguard mode
I can't find e setup for sony
camcorder
Dec 30, 2008 | JVC GR-D270 Mini DV Digital Camcorder
Unit in safeguard mode
You mix te info with Write protected tapes.
Safe guard mode is caused by the motor that takes the tape out of it's case, through the mechanics and past the video head.
If for some reason the electronics detect that it's been done by too much force, the safe guard issue promts.
Mar 29, 2007 | JVC GR-D290 Mini DV Digital Camcorder
Cameras Logo
250 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
