Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
My house was pre wired for garage door opener Just bought a chamberlain opener wanted to know how to wire it.there are about 7 little wires coming from out of wall
    President:
  • 3,197 Answers
You have 7 wires coming out of the wall but you don't say where they go. Only someone with the knowledge and equipment could trace these wires. If it were me I would use the wires that came with the new opener and follow the directions exactly.
Posted on Aug 26, 2010
Just bought this house and don't know the code for the garage door
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to the keypad and key in any 4 digit code you like and press enter.
Sep 27, 2011 | Sears Craftsman LiftMaster Chamberlain...
We bought a house that has a chamberlain garage door opener on the side of the garage. The owners before us did not know the code or could not get it to work. Is there a way to set a new could if we do not...
hi trace. yes. these keypads take a 4 digit code. To insert your own code get a step ladder and a helper. while one of you climbs the ladder to push the code set button on the back side of the motor, where the wires connect, the other will input 4 numbers of your choice followed by the enter button. thats it. joe
Jun 19, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have pre wiring in my garage for the opener which has white,red,blue,green wires. The opener came with red,white for the control and black white for the sensors. How do I connect four wires from prewirng...
The opener actually needs 6 wires. They gave you 4. It depends on where the wires end as to what you can do. A good imagination will help. I personally would install it with the wires furnished with the opener.
Oct 21, 2010 | Sears Craftsman LiftMaster Chamberlain...
We bought this house years ago, didn't get the old garage door keypad code, and need to know how to re-program it.
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to the keypad and key in any 4 digit code you like and press enter..
Aug 29, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door opens whenever it wants to
In most cases, when a garage door opens or closes by itself, or when you find your door open, up returning home, the problem is due to a short somewhere. This short is most likely to be in one of two places: either in one of your transmitters or in the wall button or its wiring.
When there is a short in your garage door transmitter, you will often find the garage door is up upon returning home, even though you know you closed the door when you left the house. A short in your transmitter causes ta continuous signal to be sent. As you are pulling out of the driveway the garage door closes fully and appears to stop, but as the carriage and arm run past the down limit and hits the header bracket it reverses and the door begins to open, just as you start driving off down the road. You come home to find the garage door is up, as if someone else had opened your door. The best thing to do to troubleshoot the garage door problem is remove the batteries from your transmitters and try operating the door from the wall button. If the problem is intermittent, you may want to do this for a day or two to eliminate the transmitters as the culprit.
If the problem persists, try removing the wall button wire at the motor head to ensure it is not a short in the wire to the button, then try operating the garage door with the transmitters only. If it stops the problem, replace the wires and test the wall button which can also go bad. It is a process of elimination.
Oct 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Bought a new house that had a craftsman opener model 139.53990 made in '03 set aside in the garage. Tried hooking it up, bought a universal remote and got it programmed. I push the button the lights...
There are no fuses in the opener. Pull the logic board (the end where all the white wires go) and check for burnt or missing traces on the printed circuit board. This is not uncommon where there are electrical storms.
Sep 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
My unfinished house did not come with the wall opener/closer button attached. The wire is there. I got a switch but the wall has four wires (red, black, white , and another. The new mount only calls for...
Look at the rear of your opener and see what color wires are connected to terminals 1 and 2. These will be the two wires you should connect to the wall button.
Jun 30, 2009 | Sears Craftsman LiftMaster Chamberlain...
Wiring diagram for garage door opener
Can you hook up sensors to an older craftsman garage door that never had them?
Jun 21, 2008 | Sears Craftsman LiftMaster Chamberlain...
We are trying to install a garage door opener and our home is pre-wired with cat5e cable and not sure what colors to hook up
I like to use the blue wire and the blue/white wire for one side - blue/white connected to wire with black trace>
Do the same with red and red/white on the other side.
Use green for the wall control.
Hope this helps
May 03, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
54 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
