Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Code LD comes on so it will not continue working. This happens when it has 8 or 9 minutes left in the cycle, it happens more times than not. I have pressed cancel and started the process over and it just does it again. I have turned it off and unplugged it for 10-15 minutes started the cycle again and it does it again. What is causing the problem. I have checked the size of load and the weight distribution and no problems there. Thanks for any help you can give.
  • Whirlpool Master
  • 3,361 Answers
This is a long drain error.
You have to enter the machine and clear any debris out of the drain pump.
Posted on Aug 25, 2010
Gets to 8 minutes but wont go into spin cycle code ld comes up
  1. ld means long drain. If it takes too long to drain it won't go into spin or other cycles. It's possible that you have a blockage in your drain hose or pump, or your pump has gone out. Remove pump and check for any blockages. Replace your Drain pump if it is found to be bad.
  2. Also, some washing machines have a pressure sensor that can fail causing the ld code to come up.
  3. Last but not least, if the drain pump was replaced, and hoses were unclogged, and you still have the same problem, your control board may have failed.
Feb 25, 2011 | Whirlpool Washing Machines
Cycle gets to 8 minutes but wont go in spin cycle code comes up ld
The switch in the lid is out of position or gone bad.
Feb 25, 2011 | Washing Machines
LG dishwasher LD-2120WHU I get the
This happens to my LG dishwasher every 6 months or so. It also makes a groaning sound as if the system is starved for water. The resolve the problem by removing the dishwasher and laying it over on it's right side. I then remove the two plastic assemblies that are on the left side and I remove them from the dishwasher (you will need a vice grips to remove the hose clamps from behind them, you will also need to remove the round circular water intake plastic disk that is on the inside of your dishwasher on the left hand side right in the middle of the left wall) and clean them. Once the water can run freely through these plastic parts you will get a good water flow and you should be fine. Until you have time to do this I recommend putting a few quarts of hot water into your dishwasher once you start to hear the groaning problem. This solution should be very easy for anyone who is comfortable doing their own oil change. Oh, and turn off the power supply first.
May 26, 2010 | Dishwashers
My washer stops at the spin cycle. The LD code
“F21” (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Jul 16, 2009 | Kenmore Oasis HE 27082 Top Load Washer
LD code problem
Jun 06, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Ld code on any cycle
Feb 21, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Oasis HE 27082 Displays "LD" error falsely
remove the harness and replace it is what this will lead to,just watch and you'll see
Apr 27, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Ld error code on kenmore oasis
ld stands for long drain. If you can remove the bottom panel you will see the pump in the middle front which has a clean out you can unscrew. There is usually obstructions in the clean out such as a sock causing the long drain. When u remove the clean out cover alot of water will come out so a wet vac comes in handy.
Apr 15, 2008 | Kenmore Oasis 27042 Top Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
