Question about Hunter Ceiling Fan Light Switch Control
Is ze-268sg ceiling fan switch compatible with ljy-280 switch. if so, what are the wiring/color set up. I used the ljy-280, and now the fan won't tun-off. i used; L blk, 1 grey, 2 brwn, 3 grn pattern. It feels like lo, hi, hi, hi and cycle repeats.... plz help OBI-WAN
5 Suggested Answers
  • 14 Answers
SOURCE: where does while lead from ceiling connect? capacitor has five leads, 2 gry, 1rd, 1 grn 1br, (grn gry br to switch) switch has black lead to ceiling lead.
White is the common, or neutral. There should be a white wire to connect it to.
Posted on May 24, 2009
bob898018
  • 3 Answers
SOURCE: 3-speed fan switch broke on
My Hunter fan uses a Zing-Ear ZE-268S6 switch. This is NOT a standard switch! It connects L to 2 AND 3 for medium speed. It is best to order the exact switch if possible. Hunter wants to sell you the entire bottom assembly (probably expensive). I found the exact switch online at:
http://www.kenselectronics.com/lists/switches.htm#Pull%20chain
for $6.80 plus $4.95 shipping. I bought an extra which didn't increase the shipping - worked great. Hunter ZE-268S6 ceiling fan connection colors: L=black; 3=green; 1=grey; 2=brown. If you need a different switch on their page, just click the Edit menu, then Find, type your part number in the box, and click Next.
Posted on Jul 07, 2012
SOURCE: Hunter fan switch doesn't work
I had this same problem. Home Depot and Hunter did not help me. I called Ken's Electronics in Kalamazoo Michigan Phone (269) 345-4609
website http://www.kenselectronics.com/index.html. He was excellent and very knowledgeable. Got repair part for about $7.00 and received it within two days. Great. I was so frustrated because it looks like I was going to have to purchase and install a whole new fan. Started to wonder if Home Depot and Hunter did this on purpose. Call Ken and he can help with questions and installation too.
Posted on Oct 18, 2012
SOURCE: Fan with remote won't work with wall switch. I
I just recently purchased a hunter ceiling fan w/light and remote. Had it installed and wall switch would not work, only remote. I contacted Hunter company directly about this problem and I was told that they redesigned their fans with remotes so that only the remote works for turning off power to fan. The person who made that made that BRILLIANT change should be fired. So to those of you who own a newer hunter an product with a remote ne your wall switch will not work tat s te reason why.
Posted on Jan 04, 2013
Where can I purchase a Jin you e70469 ceiling fan switch.
ebay 14 bucks
Jin You E70469 Pull Chain Switch for 3 Speed Ceiling Fan 4 Wire 1 2 ...
https://www.ebay.com > ... > Lighting Parts & Accessories
item 2 ze-208s ceiling fan pull chain speed control switch for zing ear 3 speed 4 wire -ze-208s ceiling fan pull chain speed control switch for zing ear 3 speed 4 wire. ... item 3 OEM ZING EAR ZE-208S 3 SPEED CEILING FAN PULL CHAIN CONTROL SWITCH E-89885 DR73 -OEM ZING EAR ZE-208S 3 ...
Exhaust Ceiling Fan Switch 2 Speed Pull Chain Blower Jin You ...
https://www.ebay.com/itm/...Ceiling-Fan-Switch...Jin-You-E70469...-/132376583704 Replaces Jin You E70469, Santa, Gardner Bender GSW-33. The control module provides two speed setting for your fan. 2 Speed Pull Chain Switch. 3" (7mm) Brass Chain. Spark Electric Components LLC. Width 11/16" (18mm). ' eBay!
Jin you e70469 ceiling fan switch Google Search
Dec 12, 2017 | Dryers
I need a zing ear part ZE-301D+ZE-109M for a HUNTER CEILING FAN WITH LIGHT #28698
Fixya does not sell replacement zing ears. Check with a local appliance parts supplier.
Jul 05, 2016 | Hunter Dryers
What current Zinger switch would be used to replace a Zinger ZE 208S?
How many wires on the capacitor & which color wire goes into which slot of the pull chain switch?
Aug 12, 2014 | Hunter Dryers
Hunter cieling fan replacement zing ear switch ze-268s5
I never could find the 5 wire 4 speed replacement. I did however find a solution.
4-speed (five-wire) pull-chain ceiling fan speed switch--Use 3-speed ZE-208S6-A09.
How to use the 3-speed ZE-208S-A09 to replace a 4-speed switch:
old ZE-208S5-1T or ZE-268S5: . . . . . for ZE-208S6-A09 use:
L=Black . . . . . . . . . . . . . . . . . . . . . . . . L=Black
1=Gray . . . . . . . . . . . . . . . . . . . . . . . . 1=Gray
2=Brown . . . . . . . . . . . . . . . . . . . . . . . . (Don't use Brown)
3=Purple . . . . . . . . . . . . . . . . . . . . . . . 2=Purple
4=Green . . . . . . . . . . . . . . . . . . . . . . . . 3=Green
old ZE-208S5-1T or ZE-268S5: . . . . . For ZE-208S6-A09 use:
2=Green . . . . . . . . . . . . . . . . . . . . . . . . (don't use Green)
3=Brown . . . . . . . . . . . . . . . . . . . . . . . . 2=Brown
4=Purple . . . . . . . . . . . . . . . . . . . . . . . 3=Purple
Feb 18, 2013 | Hampton Bay 24750 Huntington III Ceiling...
5 wire, 4 speed Ceiling Fan Switch - Hunter
You should be able to assuming you have the correct switch. Don't use the 4 slot in switch.
Dec 29, 2012 | Dryers
Fan switch are LJY-280A and E198635
I have a Hampton Bay indoor/outdoor ceiling fan with 3 speed fan switch WU Pin LJY280A, E198635. It is a L-3-1-2 (ccw) switch with purple, grey, black and brown wires. The wiring is different than most on web. The L is not black, 2 is black. My wiring for the switch is L-Purple, 3-Grey, 1-Brown, 2-Black.
Found schematic on web that I think is correct:
Off-none,
Hi-L,1 4uF,
Med.-L,2,3 10uF & 4uF,
Low-L,3 5uF & 4uF.
I hope this helps someone.
Feb 21, 2012 | Hampton Bay Dryers
Where can I find a replacement switch. Zing Ear ZE-268S6. Thank you.
Hi Eric...
Click here Amazon com zing ear switch and chose the best one for you. Anyway contact the seller before buying, to see if fits on your model. I hope this helped.
enjoy
Jun 27, 2011 | Hunter Ceiling Fan Light Switch Control
3-speed fan switch broke on Hunter model 28072, cat. 300 fan. Found replacement switch at Lowes, but wiring colors are completely different from manual. What color wires go into L, 1, 2, 3 positions...
Nov 30, 2010 | Hunter Ceiling Fan Control Switch
Zing ear switch from a hampton bay ceiling
Did you try Home Depot, Lowes, or any lighting supply store. It's a pretty common item, so they should all stock it
Dec 12, 2009 | Hampton Bay 52 In.Carriage House II in...
Dryers Logo
401 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
