Question about Kodak EasyShare C913 Digital Camera
If I push the zoom button the camera shuts off
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 26, 2010
Tip
My friends's camera have a zoom problem. I've read the article, my...
If you are havingproblems with your Digital Camera and the lens not working properlythen here are some things that you can try that may help you get itworking again. These problems can include: The camera not startingup, the zoom function not working properly, The focus function notworking properly, and the lens not retracting when the camera is shutoff.
Keep in mind asyou try these things that realistically you have about a 50-50 chanceof fixing many of these problems, and the further down the list yougo the more chance there is that the fix may break your camera, buthey, it isn't working now, so what do you have to loose? Justremember that IF your camera is still covered under a warranty, itwill be better for you to return it and get a new one then to try andfix it yourself.
The first thing tomake sure of is that you have fresh, working batteries in yourcamera. If your batteries are over a year old they are not puttingout full power anymore and you may just need to replace them with newones. I have seen some batteries die in months. Some will fail veryquickly, so never assume that a battery is good. Try a new one! Alsotry holding the function or OK button while you start up the camera.This will keep some of the other functions from working and give youmore power on the start-up.
Next, remove thememory card and try to start the camera without the memory cardinstalled. This will cause some cameras to reset. Then turn thecamera off and insert the memory card. Again restart the camera andsee if it works.
If your digitalcamera has an AV cable, inset that and try to start it up. This alsowill shut down some of the other functions and give it more power forthe start-up. It also may be a good idea to keep it plugged in if youneed to try some of the later fixes.
Now try to lay thecamera flat on it's back. Push the shutter button in as you turn thecamera on. The camera will then try to auto focus as it is startingup. The combination of the focus and the start-up may free the lens.
Now comes theparts that can be a bit more risky.
Using compressedair, like the cans that you blow your keyboard out with or a regularair compressor and nozzle, blow air around the rings of the lens.This may dislodge the dirt that is hindering the lens from moving.Another way also is to use a shop vac. Hold the nozzle over the lenswith it sucking air over the lens as you start the camera up. Becareful that the air does not pull too hard on the lens and causemore damage. In some cases though, the gentle pulling will help toextend the lens.
If that does nothelp, using a thin piece of paper, you can slide it into the gaparound the lens barrel, or use a needle to dislodge dirt if you cansee it. Just be careful not to slide anything in too deep and ruinthe dust gasket around the lens. Also be careful not to scratch thelens.
Now we will startto get desperate. Take the camera and tap it gently on a table top orother hard surface. The cover for the USB cable is a good place totap on. This is often rubber and will cushion the blow a bit.Slapping the camera on your hand or the inside of your thigh may alsowork. Oh, and make sure to unhook that AV cable when doing this. Alsobe aware that this may cause the internal components such as theribbon cables or wiring to come unhooked and cause other problems.Very hard banging, can also cause the LCD screen to crack.
Now, if you havedropped your camera with the lens extended, and the lens is obviouslycrooked, then you will need to tap it straight. To do this usesomething softer, but with a bit of weight. A pencil or a hair brushmay work well. Tap the lens in such a way as to knock it straight. Inother words the opposite way that it is pointing crooked. Do thiswhile trying to turn it on and off. Tapping it on a table top mayalso work.
Now the reallydesperate fix. If everything else has not worked, then you are leftwith no options. Forcing the lens is now your only choice.
Gently as possibletake the lens and with a pulling, twisting, rotating motion, pull andturn the lens at the same time. Also attempt to straighten the lenswhile doing this. You can then push it back gently and try a fewtimes, but do not push the lens all the way back in or you will notbe able to grab it anymore. If you are doing this and you feel aclick, then stop and try the camera, as the guide pins may haveclicked back in place and you are good. It is also possible that theclick is the guide pins breaking, which of course is bad news.
If you aresuccessful in getting the lens to go in and out freely again, you maythen have to turn the digital camera on and off a few times, push theshutter button part way in to activate the auto focus, a few times,to get the camera to recalibrate the auto focus again. Doing thisshould help to get it to work again. Resting the camera may also helpto get it to focus properly again.
This should giveyou many things to try so that your digital camera will work for youagain. But remember that as often as not these may not work and youstill will not have a properly functioning digital camera.
Lens Error fix for Digital Camera
How to easily download Pictures from Digital Camera
How to Unlock SD Card
Digital Camera Manuals, Drivers, Downloads, and Support
on May 03, 2011 | Cameras
My camera worked fine for 3 years, when suddenly .... when i'm zooming fast (zoom button pushed down) camera switches of. If i'm zooming slowly everything is ok. Some master said that zoom lens motor...
I would say to check the batteries and their connecting surfaces plus the contacts in the battery compartment. With bad connections on the batteries, when the camera zooms slowly it does not use much power. When zooming fast it uses more power (current) and if the batteries are making a poor contact the camera will shut down due to low volts. Check that first before spending big money. If you are using Duracell batteries, they have a short + pip end which some devices will not work with them due to poor conection. Compair a duracell battery with another brand. see the difference on the + end.
Aug 04, 2010 | Canon PowerShot S3 IS Digital Camera
How do I activate digital zoom on my canon S3IS
I believe there is a ring around the button the shutter button (the button you press to take the photos. Your sort of push it left or right (near or far). The digital zoom should activate after it goes past its optical zoom range. Push it only slightly to slow down the zoom process.
Aug 12, 2009 | Canon PowerShot S3 IS Digital Camera
Zoom button is pushed in the camera
The rubber spring for the power button inside the cam has been pushed hard. You need to re-align it.
Aug 22, 2008 | Aiptek IS-DV2 Camcorder
Camedia C-5050 zoom won't take pics
Is your memory full? Does the camera attampt to focus when you push the button down 1/2 way? If not the mode dial may be faulty (you are not in picture taking mode) or the shutter button may be faulty (no focus attempt) Try to use the timer button to get the shutter to trip.
Jul 10, 2008 | Olympus Camedia C-5050 Zoom Digital Camera
Zoom malfunction
I had exactly the same problem. You just need to smash once with your hand on the bottom of your camera (it looks that this works for all canon cameras).
Jan 08, 2008 | Video Cameras
Zoom error message
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Aug 07, 2007 | Olympus SP-350 Digital Camera
How does zoom work
well, this is pretty simple - find the "zoom" button push it & look thru camera at same time. As for finding the details about your camera, simply visit the manufactures website or just google the brand & you'll find info & instructions that way.
Jun 23, 2007 | Vivitar ViviCam 5100 Digital Camera
Zoom malfunction
the zoom control button is malfunctioning. try to clean the contact. check the resistant of the variable carbon. if it is not open, try to adjust the contact point away from the damaged area.
Oct 18, 2006 | JVC Handycam GR-DX77 Mini DV Digital...
Kodak EasyShare C913 Digital Camera Logo
19 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
