Whirlpool Duet washer had an F2 problem: Plugged water pump. I have emptied the water pump. Now the washer will not come on.
    Genius:
  • 1,073 Answers
Check that the frount bottom interlock switch is in place and closing correctly it will be on the frame of the frount where the frount panel attaches
i would check this first
Posted on May 05, 2008
Why does my whilpool duet washer flash F2: Its holding water and beeping.
First please verify this is a f2 and not a fo2 error
they mean almost the same thing i have it listed below
F/02 Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump
Nov 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Why is the washer not completing a cycle. says f2 or suds will not completly spin water out of washer
* Check the drain hose and make sure it is not plugged or kinked.
* Check the electrical connections at the pump and make sure the pump is running.
* Check the drain pump filter for foreign objects.
* If the above does not correct the problem, replace the pump.
Thank you !!
Jul 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet washer is saying f2 what does this mean
Hi
Thanks for using FixYa. F/02 error means Long Drain. If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed. Press PAUSE/CANCEL twice to clear the display.
  • If the above does not correct the problem, replace the pump.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have the front loading duet washer. The code F
F2 indicates a long drain usually caused by blockage in the filter, remove and clean out filter.
Also Check the drain hose and make sure it is not plugged or kinked.
www.appliancehelponline.com
Apr 09, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
The washer is giving a code of "F2" & not draining properly.. any idea?
This code indicates a pump issue. First, remove and clean the filter. Then you need to check out the pump.
Whirlpool F2 = Long Drain error code.
If the drain time exceeds 8 minutes, the water valves are turned off and “F/02” is flashed.
Press, PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the "F2 error code" will be displayed.
Potential Causes:
(1) Check the drain hose and make sure it is not plugged or kinked.
(2) Check the electrical connections at the pump and make sure the pump is running.
(3) Check the drain pump filter for foreign objects.
Mar 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool duet washer will not spin all of the water out after the spin sycle. There is a flashing F2 on the screen.
F/02 = Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed. Most likely cause is item 1.
  1. Check Screen Filter Assembly for foreign material lint, socks, coins, nails ect. To access the filter remove the lower front panel. The filter (white is located before the pump. Place a pan under the filter and remove it and clean then reassemble.
  2. Check the drain hose and make sure it is not plugged or kinked.
  3. Check the electrical connections at the pump and make sure the pump is running.
  4. If the above does not correct the problem, replace the pump.
Oct 31, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
My whirlpool duet washer will rotate to balance
To solve this:
thanks.
Aug 31, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whrilpool duet front loader washer flashes f2
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• If the above does not correct the problem replace the pump..
Aug 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer will not spin. pump drains well. low humming noise.
"low humming noise??" soundslike the pump trying to pump, did you try removing the lower acess panel and physically cleanout the drain pump filter?? sondsas if its still trying to empty water
Mar 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Front Loader
F2=Long Drain If the drain time exceeds 8 mins the water valves are turned off and F02 is displayed
Check drain hose
check pump filter for foreign objects
check pump motor for proper operation
Jul 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
37 people viewed this question
Top Washing Machines Experts
