Question about Singer 7436 - INGENUITY
The top stitch and the bottom stitch do not connect properly. The top stitch is lose and will pull out. I have tried adjusting the tension to each level. No success.
    Genius:
  • 1,788 Answers
Try a new needle and make sure that the flat side faces to the rear of the machine, Also, check your manual, if you don't have it go to singerco,com and download one for free,
Posted on Aug 27, 2010
I have a brother PR1000 and on the test stitch there is too much bobbin thread showing underneath. do I adjust the tension in the top thread or the bobbin tension?
Yes Adjust to more tight see what it'll do.
Bottom bobby is too tight or upper thread control is too lose.
Good luck
Mai
Jul 12, 2017 | Brother Sewing Machines
Why is the bottom stitch straight
Thread tension is a BALANCE between the top tension and the bottom tension. It appears that your bobbin tension is sightly tighter, causing the top thread to be pulled down. Run a zigzag stitch. If your top looks fine, but your bottom looks something like chicken footprint tracks, see if you can adjust your top tension a little tighter to compensate. If, in doing that the stitches are balanced but just too tight, you will need to adjust your bobbin tension SLIGHTLY looser. You will need a tiny screwdriver to do this. Take the case out and locate two screws on the side. Once is a Phillips--leave it alone. The other next to it is usually on the left of the Phillips, and, is a straight-blade screw. Lefty-loosey, righty-tighty. In your case, you want to adjust it a LITTLE looser to match the top tension--no more than 1/4 turn. Put it back and test it again; you should see some improvement. If it still needs a little adjusting, reinsert and repeat, but ONLY 1/4 turn at a time.
DON'T fool with it at all if you can compensate by tightening your top tension, and before you do anything, clean and oil your bobbin area with ONE drop and ONE only of sewing machine oil.ONLY. You might find that just cleaning and oiling will solve your problem right there.
Jul 06, 2014 | Singer 6038 Mechanical Sewing Machine
The bottom stitching looks like a line and not stitches the top stitching is fine
try adjusting the top thread tension and see if that helps
also try changing the thread.
also change the needle--make sure it's the right needle for the fabric
being sewed.
Dec 13, 2012 | Juki DDL8300N Sewing Machine
I have a singer 7258 that I can not get the tension to loosen up on. The top stitch is straight across and adjusting dial doesn't help.
Hello
Adjust the tension
Load your sewing machine with one color on top, threaded through the needle. Load the second color thread into the bobbin and thread.
Fold the scrap fabric in half, and sew a straight stitch at least 2 inches long. Look closely at the seam. If you see loops of the bottom color thread on top of the fabric, proceed to Step 3. If you see loops of the top color thread on the bottom of the fabric, proceed to step 4.
Loosen the top tension. Since the top tension is so tight, it is pulling the bottom thread up through the fabric. Loosen the top tension by turning the numbered knob on the front of the sewing machine counterclockwise by one number.
Tighten the top tension. Since the top tension is too loose, the bottom thread is pulling the top thread down through the fabric. Tighten the top tension by turning the numbered knob on the front of the sewing machine clockwise by one number.
Sew a straight stitch 3 inches in length. Check the stitching. It is perfect if the threads meet in the middle, and you can only see the top thread on top and the bottom thread on bottom. If it still needs adjusting, go back to step 2 to repeat the needed steps.
Using two different colored threads makes it easier for you to see which thread is being pulled.
Always use proper precautions when working with electrical machines.
Aug 01, 2011 | Singer Sewing Machines
The bottom stitch is very loose. I've tried tightening and loosening the screw and the problem remains...HELP!
The bottom stitch is affected by the TOP thread tension :) First go back and make sure your bobbin tension is correct since you adjusted it. It should drop slightly when held suspended by danging it by the thread. If it reels out to the floor it is too loose. If it doesn't drop at all it is too tight.
Now that you have that adjusted look at your top tension. If it is loopy on the bottom side of the stitch the TOP tension is too loose. Increase the top tension.
Now take some scrap material and set machine to a wide zig zag, medium length stitch and sew a bit. Compare the top and the bottom sides of the stitch. They should look identical. Remember the TOP side effects the bottom and the BOTTOM tension effects the top side. Adjust accordingly until they look identical with no loose threads or loops and no puckering (puckering means it's too tight).
May 03, 2011 | Brother LX3125 Sewing Machine
Stitches are not connecting top to bottom
Try re threading the machine with the presser foot up.
When you thread with the presser foot down, the thread/string cannot properly enter the tension control.
No control = looping stitching that pulls out.
If you do not have a manual, you may be able to download a free one at Brother's website.
Feb 22, 2010 | Brother Sewing Machines
How to adjust tension on bottom stitch?
There are tow places where the thread tension is adjusted.
One is bobbin. This is not routinely adjusted. Just once and it is good for long time. This is done by turning the only screw on bobbin by about 1/4 turn or so at a time. Try several settings until you find he best.
the other place is the conventionally on body of the machine.
Tension of bottom stitch or top stitch are very confusing words. meaning difft things to difft pple.
All i can say is this. If u see bottom stitch run straight through loops of top thread. then either top tension is too loose or bottom too tight. and vise versa.
With top tension set to middle position adjust the bobbin to get correct stitch. Then later on all u need is to adjust only the top setting according to stitch and cloth
Oct 16, 2009 | Brother LS-2125 Mechanical Sewing Machine
Underneath stitch bad
Sometimes even though the tension is at recommeded placement, you may find with various fabrics or threads, you have to adjust it. I would try to raise the tension just a bit. Try it a little at a time until you achieve a stitch you are happy with. If adjusting the tension does not correct the problem, double check your threading. If sure it is threaded properly, especially going through the tension assembly...check your thread. I have found that the thread you use can and often does create tension problems. Try changing the thread and see if the stitch quality improves.
Mar 21, 2009 | Bernina Virtuosa 150
Singer 221-1 stitching is good on bottom but not on top
pucker is caused by too loose or, to tight adjustment of: the thread tensioners both the bobbin tensioner and, the needle tensioner need to be adjusted: to adjust the needle tensioner turn the side knob clockwise is tighter counterclockwise loosens; the bobbin tensioner is a tiny screw on the bobbin holder adjust both tensioners until your stich loops' both top and, bottom are tight but, the machine does not break the thread
Feb 16, 2009 | Singer Featherweight II 117
Thread tension problem when sewing on heavy fabrics
Sometimes when I need to use heavy thread for top stitching to reinforce a seam that has come undone, I will use the heavy thread on the top and regular thread on the bottom. I haven't tried it the other way around for hemming but I would think it would work. I do not currently have a Bernina.
Jan 15, 2008 | Bernina Artista 180
Singer 7436 - INGENUITY Logo
37 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
