Question about Kenmore 65924 Electric Dryer
The dryer heats, but it takes a long time to dry towels. I have completely cleaned the vent system all the way to the roof, replaced the heating element, thermastat and hi-temp cut out. I used a ohm meter on the heat selection switch to check various positionns. Hi output is suspect the wiring diagram states that to max temp a minimum of 10K ohms is required. There are two external resistors wired in series on the connector to the switch which have a value of 5.1K and 910 Ohm. I was wondering if the selector switch is supposed to have a internal 5K resistance in the max heat position.
  • Kenmore Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Posted on Sep 12, 2010
Dryer not heating enought
The first thing you need to do is make sure your dryer vent hose is clean. An easy test (if you have a really long dryer vent run) is to unhook your dryer vent hose from the back of the dryer and just dry a load of towels like you normally would. If your towels are nice and dry when the cycle is complete, then you know your dryer hose vent is clogged somewhere down the line.
Oct 13, 2014 | Maytag Dryers
My dryer is taking way to much time to dry a basic load
The problem is either a blocked lint filter or a restricted vent system if the dryer heats up normally or a faulty cycling thermostat if the dryer heats up erratically. Check and make sure the lint filter is clear. You may need to have a contractor have the vent system checked and cleaned as it is necessary to clean them at least once year or every six months if 4 to 5 loads are done everyday. Restricted vent system impedes the airflow and therefore the disposing of the steam it carries. This consequently results in the longer drying time.
Replace the cycling thermostat if the dryer is heating up erratically or does not heat up sufficiently.
Aug 21, 2011 | Kenmore Dryers
Whirlpool gas dryer heats but wont dry the clothes
If your
Dryer Maintenance
heatman101
Dec 14, 2010 | Whirlpool LGB6300 Gas Dryer
Takes three cycles to dry towels; i checked the venting but it goes up to roof so how do know if its blocked further up? My house is 5yrs old
usually long dry times is a restricted vent.. most vent are a straight shot out the back with longer vents excess buildup is common... unplug the vent in the back to the dryer and run a load if it heats quicker then u know ur venting is clogged up... hope this helps
Jan 29, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer is taking too long to dry clothes, even on AccuDry setting for Jeans/towels - it still is heating, just not heating enought to dry clothes, I have been doing two cycles at least for a very small...
Your house vent is restricted causing the long time to dry complaint.
Please clean the entire vent to the outside.
Also make sure the vent behind the dryer does not get smashed when the dryer is pushed back to the wall.
Jan 19, 2010 | Whirlpool GEQ9800P Electric Dryer
Whirlpool dryer....heats
You could have heating element going bad, or a plugged dryer vent. Start with dryer vent, make sure all lint is out of it, all the way through it, even if it goes to the roof, or out the wall. Also vacuum out back of dryer and inside vent tube. This should help with problem. If not then replace heating element its getting weak.
Jul 19, 2009 | Whirlpool LER4634J Electric Dryer
LGE59777S Not drying
There is a little sensor that tells the dryer when to heat and when not to heat. that sensor is bad. If you take the back of the dryer off you will see it. It is about the size of a half dollar and has 2 wires that plug into it. While you have it apart make sure that the dryer vent on the back of the dryer is not plugged with lint. Major cause for fires in dryers.
Jan 04, 2009 | LG DLE5977 Electric Dryer
Kenmore elite smartheat quitpak electric dyer
try drying load with vent tube disconnected may get warm and dusty but if works ok recheck vent completely also be sure vent is not being flattened when dryer is pushed back to wall also remove lower panel(clips along top edge each corner about 3-4 inches in)remove blower housing 2-3 screws and clean housing
Dec 12, 2008 | Dryers
NOT GETTING HOT ENOUGH TO DRY TOWELS IN AN HOUR
It takes the dryer forever to dry a load of clothing, no matter how many pieces or thickness. Yes, I have already checked the vents out of the dryer, there not clogged. Any other suggestions?
Jul 09, 2008 | Whirlpool GEW9200L Electric Dryer
Clothes don't dry fully on automatic cycle with "normal" selected.
there may be a fault on the low heat setting, check the element works on both settings, otherwise nothing to suggest, apart from are you overloading it with too many items?
Oct 13, 2007 | Whirlpool GEW9250 Electric Dryer
Kenmore 65924 Electric Dryer Logo
73 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
