Question about Xerox WorkCentre XD125F All-In-One Laser Printer
FIND THE METER - Xerox WorkCentre XD125F All-In-One Laser Printer
  • 1,110 Answers
Hold down the C key for a few seconds. You will get sets of numbers flashing. Put them together for the meter. So an 09 followed by an 60 then a 70 would be a meter reading of 96, 070 copies.
Posted on Aug 26, 2010
How do you calculate 1 cubic metre of soil?
a cubic measurement is achieved by multiplying the length X the width X the depth
for example--1 meter X 1 Meter X 1 meter = 1 cubic meter
example 5 meter X 2 meter X 1/2 meter= 5 cubic meters
example 5 meters X 2 meters X 10 cms = 10 square meters X 1/10 meter = point 1 cubic meters
I am sure that you can get it with a calculator
Oct 28, 2017 | Office Equipment & Supplies
Hi how to convert to kilowatt hour using this meter? Do we really need to multiply by 20
Yes, you do have do multiply, but not the number on the dial itself. This is a commercial or heavy residential use meter. They are geared so that each kilowatt hour measured by the dial is actually 20 kilowatt hours. This is done since some users use so much power that the meter could actually roll over during a normal billing cycle using a regular meter. So, if you are reading this meter to determine how many kilowatt hours you have used since the last reading, you simply read the meter as you would any normal meter to get the number displayed. Your photo reads 13525. That is your current meter value. If you last bill stated the meter value was 13501, that would indicate that you used 24 (13525-13501) times 20 or 480 kilowatt hours since the last bill.
Hope this helps!
Aug 15, 2016 | Office Equipment & Supplies
How do you reset to factory settings
you will need a service manual , a voM meter,a modulation meter,a SWR meter an Oscilloscope,a sinad meter,a rf meter,an AF meter a signal generator. Now that you have these pick up the book and start reading.
Feb 12, 2016 | Uniden Radio Communications
How much is one cubic meter
One meter by one meter by one meter, or two meters by one meter by half a meter, or three meters by one meter by one-third meter, or...
Apr 22, 2014 | Office Equipment & Supplies
I need an instruction manual for a astaic PDC2 meter
contact Astatic at this address:
Technical Support
800-542-6263
techsupport@roadprobrands.com
8am-4:30pm EST, Monday-Friday
Aug 27, 2013 | Astatic PDC2 SWR/ RF Field Strength Meter
Realistic STA-2270 Stereo Receiver
The pivot that balances the fm signal meter has jammed, it would have to be taken apart, the outer lens removed to attempt a repair, this is a very tricky operation, if you hit the receiver on the side nearest to the meter, the needle should move back and forth freely,"indicating the meter is good" but if it fails to move the mechanical part of the meter is faulty.
Apr 14, 2012 | Marantz 2270 Am/fm Stereo Receiver
With my rf gain all the way up i dont get needle movement and when i transmit the needle only move to about 2. not sure what is wrong
It could be a bad meter in the radio. there is know way to know without hooking the radio to a watt meter to see what it's really doing.
If its just the meter, its not a real problem. Some time dirt gets into the workings of the meter, and especially if it is a metallic debris, it will gum it up because there are magnets in the meter, and metallic debris sticks to it locking it up. Some times lightly taping the radio above the meter while modulating will loosen it up, but that would be a temp fix. The meter would have to be replaced. Careful when taping the radio, you don't want to cause more damage.
If the meter is just gummed up, the meter is not integral, and if it doesn't mater to you if the meter works right as long as the radio works, then you can leave it.
Aug 13, 2011 | Connex 3300 240-Channels Base CB Radio
How do i install a master air flow sensor and where is it located and how long does it take and cost for the part?
It depends on which engine you have, but can be done in about 30 minutes in each case. I have pasted the procedure from autozone.com below. The cost is $200.
REMOVAL & INSTALLATION
2RZ-FE and 3RZ-FE Engines
See Figure 2
  1. Disconnect the MAF harness and the IAT harness along with the wire clamps.
  2. Loosen the are cleaner hose clamp.
  3. On the 3RZ-FE, disconnect the air hose from the air cleaner cap.
  4. Loosen the four clips, then the air cleaner cap with the meter attached.
  5. Remove the four nuts, MAF meter and gasket from the cap.
Fig. Fig. 2: Exploded view of the MAF meter on the 2RZ-FE and 3RZ-FE engines
  1. Discard the gasket.
To install:
  1. Place a new gasket on the air cleaner cap.
  2. Install the MAF meter and tighten the nuts to 74 inch lbs. (8 Nm).
  3. Install the meter and cap assembly on the air cleaner housing.
5VZ-FE Engine
See Figure 3
  1. Disconnect the air cleaner cap from the MAF meter.
  2. Detach the harness from the meter.
  3. Remove the mounting bolts for the meter. Lift off the meter and discard the gasket.
Fig. Fig. 3: Remove the bolts securing the meter
To install:
  1. Place a new gasket in position, then tighten the meter to the cap assembly, 61 inch lbs. (7 Nm).
  2. Attach the meter and cap assembly to the air cleaner housing.
1FZ-FE Engine
  1. Disconnect the MAF meter harness and wire clamps.
  2. Separate the cruise control actuator cable from the unit.
  3. Loosen the air cleaner hose.
  4. Disconnect the 3 clips, then remove the wing nut, air cleaner cap and meter assembly.
  5. Unbolt the meter from the cap. Discard the gasket.
To install:
  1. Secure the MAF meter to the cap with a new gasket.
  2. Install the cap/meter assembly to the air cleaner housing.
  3. Attach the air cleaner hose to the unit.
  4. Attach the cruise control actuator cable.
  5. Connect the MAF meter harness and wire clamps.
Oct 28, 2010 | 1994 Toyota Pickup
How do you replace the meter light in a cobra 25?
You need to open the unit up ( remove the case/cover). Then remove the 4 screws holding the face plate on. Remove all the knobs ( they slip off) . remove any screws holding the meter on ( there may be none depending on which model you have ) . slide the meter out of the face plate and replace the meter with a new meter. Note: The meter light needs to be reistalled in the new meter. It simply slides out the side of the old meter and slide back in the new meter. Replace all the screws, and the jobs completed.
Good Luck and a good weekend to you.
Ed
NC Electronic
Mills, Wyoming
Jan 05, 2008 | Cobra 29 LTD CB Radio
Xerox WorkCentre XD125F All-In-One Laser Printer Logo
75 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
