Question about Vacuums
I want to install a new hose on a Sears vacuum Mod #116.23812300. How do I remove the Hose Connection Cover(#4370325)? It appears to be a flexible plastic part, however, it will not move from it's position on the old hose.
  • Hert May 07, 2008
    The question pertains to a Sears vacuum cleaner. Reply is of no value. Thanx anyway.
  • Hert May 07, 2008
    I did find a way to solve the problem. You're right, a photo would have helped in stating the problem. Your reply did not address the fact that this particular hose is wrapped with electric wires, which complicates the situation. Your solution may work with a hose without electrical wiring. Thanx for your respose.
    Genius:
  • 3,422 Answers
Please CLICK HERE
This guide will explain you how to replace the hose.
Goodluck..
Posted on May 05, 2008
  • Priya darshan May 05, 2008
    Please don't forget to rate or accept the solution
  • Priya darshan May 08, 2008
    I am really sorry for the wrong link i posted.
    Since your problem is solved then please don't forget to rate the other expert.He deserves it.
    Thank you for using fixya.
  • 3,037 Answers
You are trying to remove the flexible hose part from the end correct? If you post a picture of the item that would be very helpful since the numbers you posted really didn't help much.
Usually you can just take a flat headed screwdriver and pry out the old hose from the side of the connection piece. Let me know if I am not understanding correctly and I would be glad to help you.
thanks
  • Benjamin Patri
    Benjamin Patri May 07, 2008
    Please don't forget to let me know your thoughts about my solution.
    If your problem is fixed, please rate this solution as that is one of the biggest
    aspects of how this website works and in order to receive any credit in
    helping you, I need to be rated.
    Otherwise, let me know if you have further questions and I would be glad to help.
    Thank you
  • Benjamin Patri
    alright, so you did solve the problem? if so, I'm glad you did, have a good day
The hose is sucking up but the base plate doesnt?
If you have taken the bottom end of the machine apart, you might not have reassembled it correctly so that the path to the floor (base) plate is obstructed when the vacuum cleaner body is laid back, otherwise:
You have either a blockage in the section of the cleaner in the vicinity of the short flexible hose and the floor (base) plate or the the short flexible hose has become detached at one or both ends.
1. Stand the machine upright with the beater bar in the "off " position. Machine switched off but plugged into the mains outlet.
2. Lay machine on its left hand side. You will see the short flexible hose uppermost. Check that it is attached at both tends and has not split or cracked. Check for obvious visible obstruction inside.
3. Remove the floor (base) plate by releasing the three plastic clips with a quarter turn anti-clockwise. Lift floor plate forwards and check no obstruction. Replace floor plate. Stand machine upright on floor.
4. Press two plastic clips to release the inspection cover, on bottom right hand side of machine (when standing behind it). Look into the hole: you will now be looking down into the U-bend that leads to the hose. Switch on the machine: full suction should be at the hole on the side of the machine (otherwise the hose would not have worked). Switch off.
5. Lean the handle and machine body backwards, as though you were going to use the machine on the floor. The hole to the hose now becomes covered and you will be able to see into the short flexible hose that leads to the floor plate. Check for obstruction. Replace inspection cover.
If there's no obstruction and the flexible hose is sound and attached securely then the machine will work - there's nothing else to check.
Jul 10, 2014 | Dyson DC14 Bagless Upright Cyclonic Vacuum
The hose is sucking up but the bottom doesnt...
Why have you posted this question twice on the same day?
Spot bot is blowing not sucking
This problem may be the same as I am having. The SpotBot recirculates the vacuum air back into the brush area when it is using the circular brushes. There is a short flexible hose deep inside the unit that connects from the clear plastic nozzles in the round brush unit to the end of the clear vacuum hose outside. Mine had a large tear in that flexible hose. This causes air to enter the hose and reduces the vacuum action, like cutting a hole in the side of your regular vacuum hose. The bad part is that I have not been able to find a replacement hose. It also takes a bit of repair experience to even get inside to where this hose is. Given the number of references to this type of issue, it appears that Bissell has a design flaw that causes the hose to break prematurely. Any response Bissell?
Jul 06, 2014 | Bissell SpotBot Robotic Wet/Dry Vacuum
Only suction from hose
What again for the third time? Already answered this but if it helps:
Jul 05, 2014 | Dyson Vacuums
I just changed my bag and now it is squealing and the red bar is in window?
It would seem that your vacuum is clogged, hence the change bag indicator. Pull the hose out and and remove at the swivel connection at the base of the hose.You can use a small flashlight to check the hose, lay the hose on the floor with the light at one end and look for light at the other end. I know the grip end is curved but you should be able to see some light. Check the rear port by removing the cover located near the base, on the rear side, close to the hose swivel. Unscrew the 2 plastic screws and lift out the cover; check for a clog here. Next lay the vacuum flat on it's front and shine the light behind the brush roll and up the short black internal hose. Facing the metal sole plate, the hose should be near the right corner. Good luck.
Jun 03, 2012 | Miele S7210 Bagged Upright Vacuum
How to replace the flexible hose between the upright and floor modules?
Turn the vacuum on it's side. Pull the power nozzle end out. Unscrew, in a clockwise direction, the hose from the body/tank.
Reverse to install new hose. Screw the hose into the tank, turning counter-clockwise. Place other end into power nozzle. Ensure it's set properly.
Dec 31, 2010 | Electrolux Epic 3500 Vacuum
Have a Sears shop vac, mod 113.172. The motor doesn't take in
If the motor turns, you should have suction. Put the hose on the exhaust side of the motor if there is a connection, and try to blow it out. If you can't, try using a garden hose or toilet snake to clear the hose. IF the hose is clear, and the problem continues, check the float in the cage below the motor. It should be down at the bottom of the cage. Also, if you haven't been using a bag or foam cover for the cage, it is possible for leaves to clog the motor.
Mar 15, 2009 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Hoover Upright SteamVac Deluxe with stair and upholstery cleaner
Don't listen to Solution #1, it is simply NOT correct. This is the correct answer:
As you stated, you already know where the water hose connection is. It is under the easily visible port cover on the top of the base.
What is NOT easily visible is the connection for the vacuum hose. That's because the machine needs to be "reconfigured" before the hose can be attached. To "reconfigure" the machine:
1) Remove the cover off the waste water tank and notice how things appear--it will soon be important.
2) Find and remove the "panel" on the front of the waste water tank by sliding it straight up and out.
3) Replace the panel with the connector by sliding it straight down. When finished the top should look something like it did in step 1). This assures that the dirty water will be vacuumed into the waste water tank.
Done!
Oct 23, 2007 | Hoover F7220900 SteamVac V2 Upright Vacuum
Replace Kenmore Vacuum Hose
check out this solution http://www.howtomendit.com/answers.php?id=25754
Jun 07, 2007 | Kenmore 23313 Whispertone Bagged Canister...
Vacuums Logo
52 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
