Question about Maytag Atlantis MAV6000 Top Load Washer
My washing machine started making a very loud noise in the wash cycle this morning. The spin cycle still seems to be working properly. It is a Maytag Atlantis heavy duty model top loader.
  • denali4 Aug 26, 2010
    Hi my maytag atlantic top loader started making a really loud noise in the wash cycle this morning. I tried the spin cycle and it works fine. Just not the wash cycle. Where should i start? I have taken the top of the machine off.
    Thanks for your response. I have taken off the top and front and also turned it over and checked the drive belt. I have now filled it to the smallest amount so i can run it.
    1.I really do think it is a bearing.
    2. Which direction do i try to turn the spindle in the tub to check if it is hanging up?
    3. Also how do i go about replacing the bearing
    4. How do i remove the spindle and remove the tub to clean it all out?
    Thanks again for your assistance.
  • 11,896 Answers
Is the machine making a grinding noise? If that is the case, you could have bearings that are dry. Check the seal behind the tub to make sure it is not ripped and losing it's grease.
If the seal is ripped and there is no grease, the bearings will eventually seize up.
If the seal is good and you can spin the tub by hand fairly easily without the tub flopping all over, then check the "dogs" that balance the tub, they may be rubbing. If they look ok, then check the motor and/or tranny
Posted on Aug 26, 2010
  • Maytag Master
  • 17,130 Answers
What ever be the reason it is important to take a look into the noise source to confirmt he fault. It can come from the motor when in load conditionas in the wash where there is a heavy loadd with the water inside.
Nextt the spindle drive assmebly, the bearings can be bad, the beltt can be slapping.
Also if the suspension is having an issue then the main tub may be hitting the sides with the wash cycle in motion, check if there was over load speccially if there were blankets inthe wash, if the fault is repeating then check with a good lighting to see the action of the drive BUT TAKE PRECAUTION AND CARE.
Dirt accumulation of the tub spindle can also make it drvie hard with friction, so check after the clothes are removed for the movement of the spindle.
Hope the advice helps.
  • Donald DCruz
    Donald DCruz Aug 26, 2010
    The assembly can be acccessed from the rear, place your washerr after drainign , side wise and remove the bottom pulley assmebly to see the fault in the spinle, if there is no water leak, then try to use some good cleaner like WD40 / or light oil to spray into from the botttom pulley end.
    Hope this helps.
    Thanks again. I will try this tomorrow. and get back to you.
  • 10,319 Answers
The drum has coiled springs to secure the drum in place while it spins. You will need to remove the top and the front panel to see if they are securely attached
Posted on Aug 25, 2010
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Washing machine makes loud knocking noise
drain or drain pipes blocked
bearings gone
Aug 18, 2014 | Washing Machines
I have a Whirlpool Ultimate Care II washing machine, model number: LSQ9110PW3 that stopped working properly two days ago. At first it seemed to not be able to go into the spin cycle. However, I just...
You have one of the best washers ever made... It is called a "Direct Drive" by us technicians. You probably need this part, but NEVER get rid of this machine as NOTHING out there is this good- not for anyprice. https://www.repairclinic.com/PartDetail/Whirlpool-Washing-Machine-Motor-Coupling/285753A/1195967?modelNumber=LSQ9110PW3&ss=a11b5d654521&mr=1
Apr 07, 2017 | Whirlpool Washing Machines
Have a proforma toploader and is making a grinding noise in both wash and spin cycle. it is still draining and doing everything just making the noise.
We have a proforma toploader washing machine and when using the machine in makes a very loud grinding noise during the spin and wash cycle. On occassion it also does not spin the clothing out properly, however the machine is still usable.
Dec 29, 2010 | Maytag Performa PAV3200
Loud screeching noise when spin cycle is on
Good morning! Possibly the noise was due to improper placement of load into the spinner which should be within its capacity load. best regards.
May 02, 2009 | Washing Machines
Tub makes loud thumping noise when spinning
Good morning! It's common to hear a loud thumping noise during spinning because the load (clothes) are not properly place in the tub. Please try to put the load in order & compress it down. best regards.
Washer won't agitate or spin out.
Well it is ethier Belt, Cluch ,motor ,Or transmission. But it does sound like your transmission . The loud clunk is the brake in the gear case ( Trans.). It might have broken off.
Apr 05, 2009 | GE WJSR2070B Top Load Washer
Washing machine making whining noise during spin only
Yes, bearing, most definitely. It is a cheap part but difficult to replace.
Apr 11, 2008 | Washing Machines
Loud noise thourghout the cycle
I would have the counter-balancing system checked for proper motion.
Jun 07, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
56 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
