A. SYMPHONIC – CD CHANGER (CD-5001): 1. Where can I buy a remote controller? 2. How do I fix Rotary Disc Tray to retract and advance automatically?
SOURCE: cd changer won't open
try to open by hand,see if the tray is stuck.
opening by hand is you turn the motor.
if you put a power supply direct to the motor the pcb will be burnt
(giving a bigger problem).
Look for mechanical problems.
Posted on Mar 09, 2008
  • 4234 Answers
SOURCE: Sony CD Changer does not recognize cd
The C601 will not spin up the disc unless one is detected. If the optics are bad and do not realize that the disc is there...
Try cleaning the lens using a cotton swab and alcohol. If that does not resolve the problem, the optics are bad. The optics in this unit are KSS-240 (I think). This part costs about $30-$40 depending upon where you get it. You can try to replace it or have a shop replace it for you. Add in the local labor rate for the total repair cost. This is a relatively simple repair. I have done 100s. It usually takes about 45 minutes plus the testing time.
Dan
Posted on Apr 15, 2008
tech48
  • 624 Answers
SOURCE: bose 6 disc cd changer
Some bose cd changers have a gear the get cracked and must be replaced. You did not specify which bose you have, so I have told you of the most common problem with the bose 6 cd changers.
If this is in one of the silver slimline type of units, it is very difficult to get them apart if you have not dome it before. The gear is also very hard to get to in the changer. it would be a good idea to let a professional service technician look at it. You will need to take it to an authorized bose service center because bose does not sell parts to any service centers unless they are bose authorized. They just started that about 2 years ago.
I hope this was helpful to you, let me know if I can assist you further.
Dave
Posted on Jul 01, 2008
SOURCE: Panasonic SCAK16 5-Disc CD Changer Problem
You need to clean up the cd sistem and put it on time again
Posted on Nov 04, 2008
SOURCE: Bose multi cd changer wont work, reads "Disc error"
I think there may be a problem with the system (defective parts) - I, too, am having this issue. I am going to contact the BBB - maybe if enough of us complain we will get a recall. To file a complaint:
http://www.bbb.org/boston/business-reviews/department-stores/the-tjx-companies-inc-in-framingham-ma-97/
Bose
PO Box 9168
The Mountains
Framingham, MA 01701
Posted on Nov 03, 2009
Is there an easy fix to the problem given in the details section below?
No there will not be a easy fix for this. You can keep putting up with this the way you have been or buy a new receiver and try to sell this one on craigslist, eBay, etc.
Jan 20, 2016 | Sony CDP-CE375 5-Disc CD Changer
My aiwa cd disc rotating tray is not working i don,t know what's wrong with it
hi there i know wht is problem rotary changer systems like 5 disic or 3 dics chnager.i have 2 oprions for that 1 is,from cd chnager belt small belt between motor another also mechanism like small tears lack white if there not good oily enaugh,maybe stock with tooth,DO u hear motor when u tray chnage disc 1;2;3? if motor burn rotary change then never will work,Some times belts getting older in cd rotary changers.the gey slepery,like flashy,but i hope will help your problem.Regards,Emil
Sep 13, 2012 | Aiwa NSX-DS55 CD Shelf System
I have a kenwwod ddx 6027 double din head unit in my car, what cd interchangers will work with my head unit?
Any kenwood changer will work. That head unit also supports DUAL changers
Any FM Modulated changer wil also work.
Changer Control Features
  • Dual Disc Changer Control Capability (CH1/CH2 & AUX)
  • DNPS (Disc Name Presets) with Compatible CD Changers
  • DNPP (Disc Name Preset Play) by Remote
  • CD Text Ready with Compatible CD Changers
  • Direct Access with Remote
  • Random/Repeat/Scan Play (Disc/Track)
Jan 09, 2009 | Car Audio & Video
Record won't retract
If it isn't making any move to retract the tray it's probably the trip switch. If you look in the back and follow the mechanics under the tone arm you'll see how it closes a switch as the arm goes to the centre of the record. Clean the switch or adjust it.
If it is half returning the tray it is the tray stack all gummed up. Use Servisol Silicon spray or have it rebuilt by someone who knows how.
Dec 06, 2007 | Wurlitzer Jukebox 1015 One More Time...
CD player damage
This can be a messy and frustrating problem to fix. You have to insure that the gears which control the opening and closing of the disc tray are correctly aligned with the apparatus inside. I have fixed this successfully on my own, but I must say it wasn't easy and involves removing the cover to give you better access, taking the tray out again and fiddling with it until everything is lined up properly. Might be worth sending for repairs.
Nov 21, 2007 | Yamaha CDC-765 5-Disc CD Changer
Cd cassete stuck in unit
make sure the disc tray is fully retracted, then some disassembly is required... if you made is this far, there is a metal tab/lever under the top circuit board, at the back of the unit, slide it over gently and the disc shuttle will eject.
Jun 14, 2007 | Kenwood KDC-C667 6-Disc CD Changer
USA SPEC MERC99
Unplug all the cables, leave it out for several hours then replug it in and eject. This happen to me, I called 1-800 Mercedes and that's what they told me and it worked.
Sep 27, 2006 | USA Spec MERC99 6-Disc CD Changer
56 people viewed this question
 Grubhead
Grubhead
