My laptop has thin line on the left side of the screen. How can I fix this?
    Sergeant:
  • 223 Answers
Press on the screen top and bottom on the plastic at the two points where the line hits the plastic. these contact points sometimes get loose and cause the line to appear. (not connecting inside) Trouble is, you may get it to come back with this method, but it will likely return.
Posted on Aug 25, 2010
Horizontal lines in laptop screen
Brand source customer service
Oct 02, 2017 | Computers & Internet
Blue line on my acer laptop screen
my friend had the same prob. ur laptop is well... dying. and it will get bigger everyday. :( sirry
Jul 05, 2009 | Computers & Internet
Thin blue line
Hi!
This is a phisical hardware problem with the screen.
If the system is under warranty better take back so your vendor replace the screen.
I think is the only solution.
This is a progressive problem, day a day you will be seen more and more lines until the screen become death.
Jan 19, 2009 | HP Pavilion dv8000t Notebook
Vertical lines in my laptop screen
Try connecting an external monitor to the Dell Inspiron 9300 and see if the vertical line is also present on the monitor. If the monitor display is fine, then your laptop’s LCD display panel is defective. If the monitor also displays the vertical line, then your problem is with either the video card or motherboard located inside your laptop.
Not sure if the Compaq Presario has an external monitor plug, but if it does the above procedure can be applied to that one as well.
Your responses are intended to improve the level of service provided. Please rate your experience.
Thank You.
Oct 19, 2008 | Dell Inspiron 9300 Notebook
My understanding is that you have 2 laptops with the same problem, if that is the case, you need to replace the lcd. When you have lines on lcd's, that is a sign of a bad lcd.
Jun 10, 2008 | Toshiba G15-AV501 Qosmio Notebook
Yes the problem is with your video system hardware, most likely. A repair may be possible as it could be the delicate ribbon cable that provides the video signal from a connection on the motherboard to the actual display screen. It could be the display screen. If some tech-savy friend with a good rep and an anti-static mat, good tools, and good lighting wants to assist you or check it for you, you may give that a try. Consider first that if you have or can get an extended warranty from the manufacturer then you can have a higher likelihood of a good resolution of the problem of the vertical lines that distract from viewing the display.
Jun 04, 2008 | HP Compaq Presario C500t Notebook
what i recommend you to test is to press behind your monitor and see that the line goes off or not.If it does..that mean you have a loose connection,it can be fix.Incase no then you have problem with your LCD.Normally if its LCD problem then you fix this problem,all you have to do is change the LCD.
goodluck,takecare.
May 04, 2008 | Toshiba Satellite P30 P35 Series Notebook
thats monitor problem dude, better go to the nearest repair center of your toshiba to assist you bout this problem.
Mar 10, 2008 | AMD Compaq Presario Turion 64 Notebook
Check it on External monitor prior to replacing the screen.. If the problems there as well its not the screen..
Feb 06, 2008 | Toshiba Satellite P35-S609 Notebook
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
