Question about Funai CR202TT9 20" TV
I dont have a remote and i would like to play xbox. how do u get it on input?
How do you get your xbox 360 to play, on a 65'' mitubishi projection tv,its connected but nothing comes on screen when i put a movie in just a blank screen and no sound,if i'm on a channel,the channel...
Hello
The Xbox 360 connects to a TV using either
- COMPONENT (red blue green for video, red and white for audio
- COMPOSITE (yellow for video, red and white for audio)
- HDMI
So, if your TV is on a "Channel", it is not on the correct input to view the Xbox 360.
Check the Xbox and verify which cables it is using to connect to the TV. When you find this, follow the cable to the back of the TV and find the input selection. It should be listed as the type and a number (i.e. HDMI 2, COMPONENT 1).
Have the Xbox on. Use the TV remote and use either the INPUT or the MENU options to change the input to the input that matches the port that the Xbox is connected to.
This should make the Xbox work.
When you are done with the Xbox, use the INPUT or MENU to change back to the tuner to watch TV.
Nov 03, 2013 | Mitsubishi WD-73734 73" Television
One for all urs-3021 input code for a samsunge tv with vcr
Hi mamita
0522 is the code for the xbox on your remote.
Mar 23, 2008 | One For All URC-3021 Remote Control
Cant change to input without remote sumphonic mts/sap
You can't select its input without its remote control.
Feb 13, 2013 | Symphonic ST420FF 20" TV
I cant connect my xbox 360 to my rca colortrak plus stereo monitor pip model f27676bc and i dont have a remote, i dont have a remote so i want to know how to cha nge the input maualy so i can play my xbox...
go to the manu in TV and put aux, and connect the xbox 350
and try it. However will be a good idea that you will your instr. manual for tv download free.
wwww.fitness.manualsonline.com
God bless you
Sep 28, 2012 | Televison & Video
No remote..want to play xbox...how can i do this without remote? TV has no input button
Just get a cheap universal remote, and program it to the TV. Some TVs don't have the dedicated buttons to switch inputs, without the remote.
Jul 10, 2012 | Televison & Video
How to put input on a samsung plasma? I have a samsung plasma and I am trying to connect an Xbox, can someone help?
you will have to use component cables with rca's
from xbox plug to rca to plasmas component input
use your plasmas remote to locate a channel to tune int channel o your xbox,when you turn on xbox the start screen should show,dont need a disk for tuning just playing
go forth and have fun .
Cheers MISTERDJ
Apr 11, 2010 | Samsung (TN-RBNG10) TV Input
Where is the input button!
Bottom left corner.. Might say. Video source instead of input
Aug 20, 2008 | RCA 4-in-1 Universal Remote Control
Tv
Do you have original remote if so, look for input, aux, or source to switch back and forth. If no remote look for same on set. SOme set you can plug xbox in and reprogram and it will pick up signal and program it for you.
Aug 21, 2007 | Sansui DTV2760 27" TV
Funai CR202TT9 20" TV Logo
24 people viewed this question
Top Funai Televison & Video Experts
Jaime Hernandez
Are you a Funai Televison and Video Expert? Answer questions, earn points and help others
