Question about Panasonic Viera TH-42PX80U Plasma TV
My panasonic tv volume is not working - Panasonic Viera TH-42PX80U Plasma TV
My tv volume is locked how i can release panasonic Tc 2101
Try to reset the TV to factory defaults:
1. Get the original Panasonic TV remote control.
2. Press and HOLD the volume-down button on the TV itself (not on the remote)
3. While you're holding the VOL- button on the TV, point the remote to the TV and press OK
This should do a soft-reset (most of your setting will stay).
If this doesn't work, try a full reset: Repeat the above steps; however, press the MENU button on the remote, while holding the VOL- button on the TV.
Note: When you do the full reset, the TV will lose all it's settings and customization that you did. It will go back to its out-of-the-box state.
Mar 15, 2016 | Panasonic Televison & Video
Turn up volume on panasonic tv
Hit volume on the remote or on the TV---if using a cable box make sure volume is up full from the,box
Mar 03, 2015 | Panasonic TH-42PZ77U TV
What code do I use to set up my sky hd remote to control my panasonic tx-p42x10b tv
With you sky remote follow the steps below:
TV
RED + SELECT ( flashes twice )
TV
0051
now try the volume button. If this works then press SELECT to save. If not press TV and then volume again. Repeat this step until the volume works then dont forget to press the SELECT button to store the code.
Job Done. Please leave a thumbs
Cheers
Little Dish Fitter
Oct 06, 2009 | Panasonic Televison & Video
MY PANASONIC FLAT SCREEN VOLUME AND TV CONTROL DOES NOT WORK!!
Try unplug the power cord while the tv is still on. plug it back after 5 mins. it should work.
Aug 23, 2009 | Panasonic TH-42PX60U Television
Unable to reset Lamp Hour Meter on Panasonic PT-50LC14
Try this, using the Panasonic remote, wait until the notice about your lamp goes AWAY (it wont work with the message still up).
Hold the volume down on your tv while holding the split/play button on the remote.
You will get a notice about 4-5 seconds later that it was reset.
May 29, 2009 | Panasonic PT-50LC14 Television
I want the sky remote to put the volume up and down on my panasonic tv so i need a code, model no th-42px80b,thanks if u can help.Colin
Hello Colin
please follow the steps below:
TV
RED + SELECT (flashes twice)
TV
0051
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Apr 26, 2009 | Panasonic TX-28DK2 TV
TV volume is half of want it should be.
the problem is not the cable into your house, but the amplifier it self, if the amplifier is not been powered if a rightful voltage, that can happen. if you are not happy with the output than take your tv to a repair shop, so that an amplifier can be worked on.
Mar 16, 2009 | Panasonic TH-42PZ77U TV
Remote code for PV-M1349
The secret is that the VCR code turns the set on/off and the TV code controlls the volume...try this:
Program the Verizon remote AUX button using the panasonic VCR codes until it turns the set on/off, program the remote for TV using the panasonic TV codes until it controls volume, then program the STB button to control all 3... STB, TV, and AUX. If you are missing any VCR or TV funtions try another respective panasonic code until all functions are available.
Panasonic VCR codes are 1089, 0062, 0189, 0252, 0643, 1062.
Panasonic TV codes are 0277, 0078, 0677, 1437.
To figure this out, I had to use the "what if none of the codes worked" section and figured I'd try the VCR codes since the TV codes would not turn it on/off.
Good Luck!
Nov 25, 2007 | Panasonic PV-M1349 Combo
Panasonic Viera TH-42PX80U Plasma TV Logo
696 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
