Question about Lexmark W840 Printer
MESSAGE "929.00 SERVICE PC CARTRIDGE" HELP !!1
    Genius:
  • 1,087 Answers
This error usually requires service. But try another known working pc unit or a new one. The problem can be the pc unit or the pc cartridge sensor. If problem continues after replacing pc unit, I strongly suggest you contact Lexmark technical support or an authorized service provider for assitance. Thank you for choosing Lexmark.
Posted on Aug 26, 2010
My HP L7680 printer gives message "print carriage access door or ink cartridge cover is open" but it isn't any ideas how to get rid of message and get printer to work
To resolve print carriage access door or ink cartridge cover open error just dial toll free number HP Customer Service Phone Number +1-800-281-3707 24*7 available for your service with the help of qualified technicians. HP Customer Support Phone Number 1 8002813707Help
Jan 27, 2017 | HP Officejet Pro L7680 All-In-One Printer
Error message "cartridge error"
Try cleaning the nozzles and contacts of the cartridge with a damp cloth. After installing the cartridge, powercycle the printer. Just unplug the power adapter of the printer for about 30 seconds then plug it back in.
If it doesn't help, replace the cartridge.
Dec 17, 2012 | Lexmark X5650 AIO 4-in-1 Printer
There is an error message on my printer that says that there is an interferance with the black ink cartridge communication. This started happening when I changed my empty cartridges for full ones. ...
Use Service Center to solve printer problems The Service Center provides step-by-step troubleshooting help and contains links to printer maintenance tasks and customer support. To open the Service Center, use one of these methods: Method 1 If it appears on an error message dialog, click the For additional assistance, use the Service Center link. Method 2 1 Click or Start. 2 Click All Programs or Programs, and then select the printer program folder from the list. 3 Select Printer Home. 4 From the Support tab, select Service Center.
Jan 30, 2011 | Dell V313w AllInOne InkJet Printer
F4-02 Improper Cartridge message on Sharp AR-M450N multi-function Tried everything -- unplugging everything -- turning everything back on then tried #*C* 14 enter 1 enter also tried 15 enter 1...
You may just have a Bad Toner Cartridge... It will happen from time to time..... There is a IC chip on the back of the cartridge, it may be bad or the toner feed screw is bound up... Replace the cartride with a new one..... Also, is it a OEM toner cartridge or a genaric one?
May 04, 2010 | Sharp AR-M450N Copier
Error message: Incorrect Printer cartridge, when
the printer scan whatever been placed for it, so if you place a color it will read color and so on…now the printer read that the b lack cartridge is wrong according to your investigations, then the issue is between the ink cartridge and the printer scanner, so take out the black ink cartridge and do the followings, remove any type of materials that may cover the ink tank and make sure that he vent hole is clear, put the ink back after doing the same to the color and cleaning the inside housing, then use the software for self cleaning and alignment..
Let me know how this worked for you and please do not forget to rate my service so we are able to improve on it. The rating as follows 1 the service was not related to the post. 2 the service was related but not did not help at all. 3 the service was to the point and somewhat complete. 4 the service was excellent and to the point.
Sep 29, 2009 | HP OfficeJet V40 All-In-One InkJet Printer
Lexmark t640 error message
"Remanufactured cartridges" How do you define that?
Given that Lexmark does not support or condone the use of third party products in their printers.
When a cartridge is new from the factory, all of the components inside the cartridge are new.
When Lexmark sell a recycled cartridge, all of the components within the cartridge are ETN components (Equivalent to new).
That means all of the rollers have been change and the PC is new.
It seems you purchased a cartridge which has a defect.
Return it to your point of sale and see what happens with the next one.
Don
May 29, 2009 | Lexmark T640 Laser Printer
No cartridge error message after power-on
plz follow some step:-
1. try to reinstall cartideg and check.
2. check printer with new cartirdeg or check your printer cartidge in any other printer .
your cartidge may by faulty 90%
3.now the problem in your printer sencer so do service of your printer if u can.
thanks
Apr 29, 2009 | Lexmark X342n All-In-One Laser Printer
Brought c5180 two 1/2 years ago. starting using product 8 months ago, printed maybe 500 pages. replace ink when needed. now printer say i need to replace cyan ink which i did twice. brought it in for...
Complete the steps below in the order presented to resolve the problem. It might not be necessary to complete all of the steps.
NOTE: The printer will not operate unless all six ink cartridges are installed. Also, HP cannot guarantee the quality of refilled or remanufactured ink cartridges. Step one: Reset the printer CAUTION: Do NOT perform any other type of reset on the printer before the ink initialization process has been completed.
  1. Without turning the power off, remove the power cord from the back of the printer and from the wall socket.
  2. Wait 30 seconds and reconnect the power cord to the printer and to the wall socket. Turn the unit on if it is not already turned on.
  3. Check the printer for the error message. If the error message still displays, go to the next step.
Step two: Clean the cartridge contacts
  1. Lift the top cover. Figure 1: Lifting the top cover c00372271.gif
  2. Locate the ink cartridge indicated in the error message. Squeeze the gray tab below the cartridge slot to release the latch and then lift the latch. Figure 2: Unlatching the cartridge c00372272.gif 1 - Black cartridge 2 - Color cartridges
  3. Remove the cartridge indicated in the error message. Figure 3: Removing the cartridge c00372273.gif
  4. Gather the following cleaning materials:
    • Distilled, filtered, or bottled water. Do not use tap water, alcohol, or platen cleaners.
    • Lint-free cloth or swab. Eyeglass wipes and coffee filters work well.
  5. Lightly moisten the swab or cloth and squeeze out the excess moisture.
  6. Holding the cartridge by its handle, wipe the copper contacts. Figure 4: Wiping the contacts c00372274.gif 1 - Copper contacts
  7. Replace the cartridge and then close the latch and the printer top cover.
  8. Check the printer for the error message. If the error message still displays, go to the next step.
    NOTE: The printer may take up to 15 seconds to clear the error and recognize the cartridge after closing the cover.
Step three: Replace the cartridge If the error message still displays, replace the indicated cartridge with a new cartridge.
Or Please let me know what is the exact error message you are getting.
Mar 21, 2009 | HP Photosmart C5180 All-In-One InkJet...
Error message: "Door Open"
HI there,
Follow the steps below:
Step one: Close the print cartridge access door
1.Verify that the print cartridge access door is completely closed. It may appear to be closed, but if it is not completely closed, the error message will display. Verify that there are no obstructions blocking the door.
2.If you are unsure how to close the print cartridge access door on your model, consult your User Guide for more information.
Figure 1: Examples of closing the print cartridge access door (your model may vary)
f3e57be.gif If you have attempted to completely close the access door and the error still appears, there may be a problem with the door sensor and the unit may require service.
Step two: Service your product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Good Luck!!!
neo
Feb 28, 2009 | HP OfficeJet Pro L7580 Color All-in-One...
Help Epson CX3200
I just like to ask to where specifically you can see the red light. It will help us determine what cause the red light. To give you heads up as well, the Printer's LCD screen can help us determine what exactly the offline condition of the CX3200 is:
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200.
May 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Lexmark W840 Printer Logo
771 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
