Question about GE GSS25LGM Side by Side Refrigerator
My GE Side by side is not freezing checked vfreezer temp 25 degrees f.
  • GE Master
  • 43,501 Answers
<span style="FONT-FAMILY: Arial; BACKGROUND: white; COLOR: black; FONT-SIZE: 10.5pt">Hi,</span><br /> <span style="FONT-FAMILY: Arial; BACKGROUND: white; COLOR: black; FONT-SIZE: 10.5pt"><br />As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.</span><br /> <span style="FONT-FAMILY: Arial; BACKGROUND: white; COLOR: black; FONT-SIZE: 10.5pt"><br />If your refrigerator is running but warm, then&hellip;</span><br /> <span style="FONT-FAMILY: Arial; BACKGROUND: white; COLOR: black; FONT-SIZE: 10.5pt"><span style="mso-tab-count: 1"> </span><br />Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...<br /><br />Refrigerator Condenser Coil Cleaning Refrigerator Repair<br /><a rel='nofollow' href="http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning" target="_blank">http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning</a><br /><br />Refrigerator Troubleshooting Refrigerator Compressor<br /><a rel='nofollow' href="http://www.fixya.com/support/r3885294-refrigerator_troubleshooting" target="_blank">http://www.fixya.com/support/r3885294-refrigerator_troubleshooting</a><br /><br />Refrigerator Compressor Start Capacitor and Start Relay<br /><a rel='nofollow' href="http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor" target="_blank">http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor</a><br /><br />heatman101 <br style="mso-special-character: line-break" /><br style="mso-special-character: line-break" /></span><span style="FONT-FAMILY: Arial; COLOR: black; FONT-SIZE: 10.5pt"></span>
Posted on Aug 26, 2010
.fresh produce is freezing and temp set at 2. what do I need to replace/check
Hi Robert,
I would suggest 2 degrees is too low. Try setting it to 5 and maybe monitor for a few hours. If you feel the produce should be slightly cooler then reduce to 4 degrees. Fresh produce shouldn't be any cooler than this.
I hope this helps
Andy
Nov 13, 2013 | GE (PSS26MSRSS) Side by Side Refrigerator
Won't dispense ice
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking same part needs replaced.The water valve at the bottom rear of fridge.
Thank you for using fixya
imufo2
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Jul 27, 2011 | GE Profile Arctica 25.4 Cubic Feet...
Freezer is freezing about 25 degree,but the ref. will not get below 40 degree.
It's quite normal if freezing is not reach on 40 degree, it's already high temperature. Remember the lower the temperature setting the higher the freezing of refrigerator, the higher the setting the lesser the freezing.
It's simple as that friend. Good luck!
Jun 12, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Side By Side refrigerator. Freezer melts ice together
Call GE since this refrig is still under warranty . But , you should turn your freezer to 0 degrees first .
Jan 28, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Stuff in the freezer is melting, motor is running, no cold
turn your freezer temp dial to off and wait 30 seconds, then turn it back on to max setting. if you have temp gauage you can try to check temp inside freezer, if not cold enough (less than 30 degrees) you could be losing freon gas. you need to call technician.
Sep 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Climate control drawer is 20 degrees, freezes everything,
on the bottom part of refrigerator right wall , theres a thermister, i bet is faulty
Jul 11, 2009 | GE Monogram® ZISS420DMSS Side by Side...
GE Profile Artica refrig is freezing food
Replace the cold control
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 09, 2009 | Refrigerators
Our GE monogram refrig compartment is constantly below freezing.
2 possibilties most likely is a bad temp sensor it thinks its warmer in the refrig than it actually is. the next possibilty is a motherboard has gone bad in the unit.
Jan 21, 2009 | GE GSS20IEP Side by Side Refrigerator
Ge Fridge freezing in fridge area
The freezer should be set to 0 degrees and the fridge 37 degrees according to the manual. If your unit has only numbers then it would number 4 or 5 for the freezer and 6 or 7 for the fridge.
Jun 20, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE 25 side by side refrigerator ice maker problem
Assuming the temp inside the freezer is at around 0 or -2 degrees, it should dump ice every ~50 minutes or so. Again, depending on temp's, an Ice Bin should fill within 24 to 48 hours. If your freezer temp is running at around 10 degrees, everything will obviously still be frozen (below 32), but the ice maker will take longer to freeze the water than it would if it were at 0 degrees. Open both doors and place the palm of your hand on the partition between the freezer and Fresh Food compartments... (where the door gaskets seat when they're closed). The temp of the partition should be about 5 or 10 degrees warmer than body temp., If it's hotter than that, you found the problem. Either the condenser coils are dirty and need a good cleaning OR your condenser fan motor (the fan in back, near the floor in the compressor area) is failed or about to fail.
Jul 29, 2007 | Maytag MSD2756G Side by Side Refrigerator
GE GSS25LGM Side by Side Refrigerator Logo
23 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
