Question about Dryers
Dryer gets too hot and shutts off till it cools down
    Champion:
  • 245 Answers
CHECK YOUR VENT HOSE FOR OBSTRUCTION OR CRIMPAGE! RATE ME IF I AM CORRECT!
Posted on Aug 26, 2010
L2050 kubota tractor after engine gets hot if i shutdown it will not crank over after cool down starts back up.
Nest time it is hot and does not start, check for spark. U could have a thermal issue where the ignition coil gets hot and stops working till it cools down.
U mentioned glow plugs - is this a diesel powered unit? Check for proper oil level in unit? Oil pump? Poor lubrication will cause an engine to expand when hot and not restart till it cools down.
Oct 13, 2015 | Kubota Garden
I have a kenmore dry that seems to hum very load once it heats up. If you turn it off and rest for 30 minutes it will sound fine again until it is 15 minutes into the cycle. What would be the likely...
Hello Bill,
Sorry to be the bearer of bad news,but what your describing sounds exactly what a bad motor will do...run whiles is realitivly cool,cut off when hot the restart after a cool down period and run for a while till hot again.
GENE
Sep 12, 2011 | Kenmore 84072 Electric Dryer
The igniter glow bar gets bright and hot on the first burn in the drying cycle, however on subsequent urns it doesn't glow bright or long enough to ignite. What's up?
The ignitor is either going to be good or bad. If it fires off it is fine and if it is shutting down then the flame sensor is also working. That tells me your coils are weak and old.
Here is how it works and why I believe you need to get new coils: When the dryer is cool first thing in the morning the initial start up the fuse and control besidethemobilian_2632.jpg
it allow power to the gas assembly, the flame detector/sensor allows power to get to the ignitor and it begins to glow. 1800 degrees is what that baby puts out and at that point the flame sensor bi-metal bends and shuts down the ignitor. The holding coil and secondary coil will then have enough power partially because the ignitor is off and partially because the ignitor is now acting as a thermocouple. If for some reason the gas did not ignite then the ignitor would cool down and shut off the gas. themobilian_2633.jpg
When the temp inside the drum gets to 160f that control beside the fuse shuts off the gas assembly, IF it don't shut down the gas then that fuse melts and shuts down the power to the gas assembly but it doe not shut down the dryer. The fuse is good though because you are getting power to the gas assembly AND the gas assembly is shutting down at 160f. The dryer keeps a tumbling around till the temp in the drum drops to 105f at that time the dryer wants another blast of hot air, trouble is the coils have gotten hot now, the ignitor is doing its thang, the flame sensor is doing its thang, the control is doing its thang. The only thing that ain't happening now is the coils ain't allowing gas to come out. Replace the coils and party on! More here
Jul 18, 2011 | Kenmore 400 6942 Dryer
My engine light is on now & will not shutt off. Also a symbol that looks like a wrench won't shutt off!!!!!
Get it scanned. It wont shut off till the pcm is cleared. If the problem is not fixed the light will come right back on.
Jan 20, 2011 | 2001 Mercury Cougar
KEEPS GOIN OFF AFTER THE FAN MAKE NOISES, SHUTTS OFF VERY OFTEN AND GETS VERY HOT
Need the make & model & O.S. to help you. You can install this software any way to control the fan. Set the fan to always on and see if it cools down. If the fan is noisy it should be replaced and clean inside of laptop. Dust will clog fan and overheat laptop. Over heat causing the shut down condition. This is a great toll to keep Dell laptop's cool. Let me know if it works.
http://www.diefer.de/i8kfan/faq.html
Jun 06, 2010 | Dell Computers & Internet
Whirlpool wgd5300sq0 dryer get hot then cools down. I replaced the thermal fuse as this was the cause the last time this problem was obsereved, however this time the problem has not be resolved. If I shut...
Sounds like the thermal cut-off is kicking in. Try checking the vent to make sure its not blocked and causing it to overheat, this would cause the cool down (the other candidate is a bad fuse, but if you fixed that already I would leave that for last)
Nov 15, 2009 | Whirlpool GGQ8831L Gas Dryer
When it gets hot it stop and then start again when cooled down
This problem is usually caused from restrictions in the vent hose and the unit getting to hot causing the limit control to shut down until it cools. Check your filter, your dryer vent line for obstructions and the outside for pieces of lint plugging it and slowing the air flow. I have found lint build up in the line, at the base of the dryer where the exhaust line connects, and in the exhaust mounted on the outside wall.
Oct 09, 2009 | Kenmore 63942 Dryer
98 honda shutts off and will not start until cooled off
you say the engine shuts down when it gets hot if it runs rough before doing so it could be the coolant temperature sensor allowing the engine to  overfuel  if the engine cuts out in a couple of seconds but sounds smooth it could be the fuel pump , if it cuts out instantly its electrical.
Mar 21, 2009 | 1998 Honda Civic
Dryers Logo
18 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
